Hello Flobul,
ci-après la récup.
PLUGIN : {"SmartThingsVersion":"[beta] 1.206","JeedomVersion":"4.3.19","History":"0","Notifications":"0","Meteo":"0","Refresh":"* * * * *"}
EQLOGICS : {"03bc8b14-ddc3-48f8-a28b-1ea6967f9146":[["Rafraîchir","refresh",[]],["Coordonnées GPS","location",[]],["Échelle de température","temp_scale",[]],["Fuseau horaire","timezone",[]],["Précision","radius",{"minValue":"","maxValue":""}]],"87e21012-555a-844a-7614-7641270f1b07":[["Couper le son","main::audioMute::mute::",{"component":"main","capability":"audioMute","command":"mute"}],["Executer une commande","main::execute::execute",{"component":"main","capability":"execute","command":"execute","linkedCmdToValue":"#message#"}],["Type de journal","main::sec.diagnosticsInformation::logType",{"component":"main","capability":"sec.diagnosticsInformation","command":"logType"}],["Remettre le son","main::audioMute::unmute",{"component":"main","capability":"audioMute","command":"unmute"}],["Données","main::execute::data",[]],["Activer le son","main::audioMute::setMuteunmuted",{"component":"main","capability":"audioMute","command":"setMute","arguments":"unmuted","linkedCmdId":"11713","linkedCmdToValue":"0"}],["Allumer","main::switch::on",{"component":"main","capability":"switch","command":"on","linkedCmdId":"11686","linkedCmdToValue":"1"}],["Chaîne +","main::tvChannel::channelUp",{"component":"main","capability":"tvChannel","command":"channelUp"}],["Chaîne -","main::tvChannel::channelDown",{"component":"main","capability":"tvChannel","command":"channelDown"}],["Changer la chaîne","main::tvChannel::setTvChannel",{"component":"main","capability":"tvChannel","command":"setTvChannel","linkedCmdId":"11704","linkedCmdToValue":"#message#"}],["Modifier le Mode image","main::custom.picturemode::setPictureMode",{"listValue":"modeIntelligent|Image adaptative (modeIntelligent)","component":"main","capability":"custom.picturemode","command":"setPictureMode","linkedCmdId":"11710","linkedCmdToValue":"#select#"}],["Changer le nom de la chaîne","main::tvChannel::setTvChannelName",{"component":"main","capability":"tvChannel","command":"setTvChannelName","linkedCmdId":"11709","linkedCmdToValue":"#message#"}],["Changer la source dentrée","main::mediaInputSource::setInputSource",{"listValue":"digitalTv|TV numérique;HDMI1|HDMI1;HDMI2|HDMI2","component":"main","capability":"mediaInputSource","command":"setInputSource","linkedCmdId":"11684","linkedCmdToValue":"#select#"}],["Changer la source dentrée (Map)","main::samsungvd.mediaInputSource::setInputSource",{"listValue":"dtv|TV (dtv);HDMI1|Orange (HDMI1);HDMI2|Chromecast (HDMI2)","component":"main","capability":"samsungvd.mediaInputSource","command":"setInputSource","linkedCmdId":"11701","linkedCmdToValue":"#select#"}],["Changer le volume","main::audioVolume::setVolume",{"minValue":0,"maxValue":100,"component":"main","capability":"audioVolume","command":"setVolume","linkedCmdId":"11697","linkedCmdToValue":"#slider#"}],["Désactiver le son","main::audioMute::setMutemuted",{"component":"main","capability":"audioMute","command":"setMute","arguments":"muted","linkedCmdId":"11713","linkedCmdToValue":"1"}],["Type de vidage","main::sec.diagnosticsInformation::dumpType",{"component":"main","capability":"sec.diagnosticsInformation","command":"dumpType"}],["Point final","main::sec.diagnosticsInformation::endpoint",{"component":"main","capability":"sec.diagnosticsInformation","command":"endpoint"}],["Éteindre","main::switch::off",{"component":"main","capability":"switch","command":"off","linkedCmdId":"11686","linkedCmdToValue":"0"}],["Version minimale","main::sec.diagnosticsInformation::minVersion",{"component":"main","capability":"sec.diagnosticsInformation","command":"minVersion"}],["Identifiant du constructeur","main::sec.diagnosticsInformation::mnId",{"component":"main","capability":"sec.diagnosticsInformation","command":"mnId"}],["Mode image","main::custom.picturemode::pictureMode",{"setter":"setPictureMode","component":"main","capability":"custom.picturemode","command":"pictureMode"}],["Mode son","main::custom.soundmode::soundMode",{"component":"main","capability":"custom.soundmode","command":"soundMode"}],["Changer la version du firmware","main::samsungvd.firmwareVersion::setFirmwareVersion",{"component":"main","capability":"samsungvd.firmwareVersion","command":"setFirmwareVersion","linkedCmdId":"11695","linkedCmdToValue":"#message#"}],["Désactivation du son","main::audioMute::mute",{"setter":"setMute","component":"main","capability":"audioMute","command":"mute"}],["Nom de la chaîne","main::tvChannel::tvChannelName",{"setter":"setTvChannelName","component":"main","capability":"tvChannel","command":"tvChannelName"}],["Chaîne","main::tvChannel::tvChannel",{"setter":"setTvChannel","component":"main","capability":"tvChannel","command":"tvChannel"}],["Type de protocole","main::sec.diagnosticsInformation::protocolType",{"component":"main","capability":"sec.diagnosticsInformation","command":"protocolType"}],["Actualiser","main::refresh::refresh",{"component":"main","capability":"refresh","command":"refresh"}],["Rafraîchir les infos","refreshInfo",[]],["Santé","health",[]],["Identifiant de configuration","main::sec.diagnosticsInformation::setupId",{"component":"main","capability":"sec.diagnosticsInformation","command":"setupId"}],["Source dentrée","main::mediaInputSource::inputSource",{"setter":"setInputSource","component":"main","capability":"mediaInputSource","command":"inputSource"}],["Source dentrée (Map)","main::samsungvd.mediaInputSource::inputSource",{"setter":"setInputSource","component":"main","capability":"samsungvd.mediaInputSource","command":"inputSource"}],["Marche","main::switch::switch",{"setter":"switch","component":"main","capability":"switch","command":"switch"}],["Allumage par OCF pris en charge","main::samsungvd.supportsPowerOnByOcf::supportsPowerOnByOcf",{"component":"main","capability":"samsungvd.supportsPowerOnByOcf","command":"supportsPowerOnByOcf"}],["Version du firmware","main::samsungvd.firmwareVersion::firmwareVersion",{"setter":"setFirmwareVersion","component":"main","capability":"samsungvd.firmwareVersion","command":"firmwareVersion"}],["Volume","main::audioVolume::volume",{"minValue":"0","maxValue":"100","setter":"setVolume","component":"main","capability":"audioVolume","command":"volume"}],["Volume +","main::audioVolume::volumeUp",{"component":"main","capability":"audioVolume","command":"volumeUp"}],["Volume -","main::audioVolume::volumeDown",{"component":"main","capability":"audioVolume","command":"volumeDown"}]]}
DEVICES : {"87e21012-555a-844a-7614-7641270f1b07":{"device":{"deviceId":"87e21012-555a-844a-7614-7641270f1b07","name":"Samsung QN95AA 55 TV","label":"Samsung QN95AA 55 TV","manufacturerName":"Samsung Electronics","presentationId":"VD-STV-2021","deviceManufacturerCode":"Samsung Electronics","locationId":"03bc8b14-ddc3-48f8-a28b-1ea6967f9146","ownerId":"364af4bd-c438-513c-1544-738f0414695d","roomId":"a4a3d13a-e4ba-4e24-b0a7-a72839e1de27","deviceTypeName":"Samsung OCF TV","components":[{"id":"main","label":"main","capabilities":[{"id":"ocf","version":1},{"id":"switch","version":1},{"id":"audioVolume","version":1},{"id":"audioMute","version":1},{"id":"tvChannel","version":1},{"id":"mediaInputSource","version":1},{"id":"mediaPlayback","version":1},{"id":"mediaTrackControl","version":1},{"id":"powerConsumptionReport","version":1},{"id":"custom.error","version":1},{"id":"custom.picturemode","version":1},{"id":"custom.soundmode","version":1},{"id":"custom.accessibility","version":1},{"id":"custom.launchapp","version":1},{"id":"custom.recording","version":1},{"id":"custom.tvsearch","version":1},{"id":"custom.disabledCapabilities","version":1},{"id":"samsungvd.remoteControl","version":1},{"id":"samsungvd.ambient","version":1},{"id":"samsungvd.ambientContent","version":1},{"id":"samsungvd.mediaInputSource","version":1},{"id":"samsungvd.supportsFeatures","version":1},{"id":"samsungim.fixedFindNode","version":1},{"id":"samsungvd.thingStatus","version":1},{"id":"refresh","version":1},{"id":"execute","version":1},{"id":"samsungvd.firmwareVersion","version":1},{"id":"samsungvd.supportsPowerOnByOcf","version":1}],"categories":[{"name":"Television","categoryType":"manufacturer"}]}],"createTime":"2022-04-10T08:38:38.413Z","profile":{"id":"d14b2553-505c-3543-92a5-af6f4b909ee2"},"ocf":{"ocfDeviceType":"oic.d.tv","name":"Samsung QN95AA 55 TV","specVersion":"core.1.1.0","verticalDomainSpecVersion":"res.1.1.0,sh.1.1.0","manufacturerName":"Samsung Electronics","modelNumber":"QE55QN95AATXXC","platformVersion":"6.0","platformOS":"Tizen","hwVersion":"","firmwareVersion":"T-NKM2DEUC-2141.2","vendorId":"VD-STV-2021","vendorResourceClientServerVersion":"3.0.41","locale":"fr_FR","lastSignupTime":"2022-04-10T08:38:33.711Z"},"type":"OCF","restrictionTier":0,"allowed":null},"status":{"components":{"main":{"mediaPlayback":{"supportedPlaybackCommands":{"value":["play","pause","stop","fastForward","rewind"],"timestamp":"2022-04-10T08:38:38.617Z"},"playbackStatus":{"value":null}},"samsungim.fixedFindNode":[],"samsungvd.supportsPowerOnByOcf":{"supportsPowerOnByOcf":{"value":"true","timestamp":"2022-11-07T18:35:00.907Z"}},"mediaInputSource":{"supportedInputSources":{"value":["digitalTv","HDMI1","HDMI2"],"timestamp":"2023-08-31T06:03:32.406Z"},"inputSource":{"value":"HDMI1","timestamp":"2023-11-13T18:26:45.295Z"}},"switch":{"switch":{"value":"off","timestamp":"2023-11-23T07:30:13.175Z"}},"ocf":{"st":{"value":"2023-08-29T18:15:41Z","timestamp":"2023-08-31T06:03:37.627Z"},"mndt":{"value":"2021-01-01","timestamp":"2022-04-10T08:38:38.592Z"},"mnfv":{"value":"T-NKM2DEUC-2141.2","timestamp":"2023-08-20T20:37:27.353Z"},"mnhw":{"value":"","timestamp":"2022-04-10T08:38:38.592Z"},"di":{"value":"87e21012-555a-844a-7614-7641270f1b07","timestamp":"2022-04-10T08:38:38.592Z"},"mnsl":{"value":"","timestamp":"2022-04-10T08:38:38.592Z"},"dmv":{"value":"res.1.1.0,sh.1.1.0","timestamp":"2022-04-10T08:38:38.592Z"},"n":{"value":"Samsung QN95AA 55 TV","timestamp":"2022-04-10T08:38:38.592Z"},"mnmo":{"value":"QE55QN95AATXXC","timestamp":"2022-04-10T08:38:38.592Z"},"vid":{"value":"VD-STV-2021","timestamp":"2022-04-10T08:38:38.592Z"},"mnmn":{"value":"Samsung Electronics","timestamp":"2022-04-10T08:38:38.592Z"},"mnml":{"value":"","timestamp":"2022-04-10T08:38:38.592Z"},"mnpv":{"value":"6.0","timestamp":"2022-04-10T08:38:38.592Z"},"mnos":{"value":"Tizen","timestamp":"2022-04-10T08:38:38.592Z"},"pi":{"value":"87e21012-555a-844a-7614-7641270f1b07","timestamp":"2022-04-10T08:38:38.592Z"},"icv":{"value":"core.1.1.0","timestamp":"2022-04-10T08:38:38.592Z"}},"samsungvd.supportsFeatures":{"imeAdvSupported":{"value":null},"mobileCamSupported":{"value":null}},"custom.accessibility":[],"custom.disabledCapabilities":{"disabledCapabilities":{"value":["samsungim.fixedFindNode","samsungvd.supportsFeatures","samsungim.findNodeGeolocation","powerConsumptionReport"],"timestamp":"2023-08-31T06:03:33.807Z"}},"samsungvd.remoteControl":[],"custom.launchapp":[],"samsungvd.thingStatus":{"updatedTime":{"value":null},"status":{"value":null}},"samsungvd.firmwareVersion":{"firmwareVersion":{"value":"3.5.0","timestamp":"2022-04-10T08:38:40.856Z"}},"audioVolume":{"volume":{"value":7,"unit":"%","timestamp":"2023-11-13T21:05:06.778Z"}},"powerConsumptionReport":{"powerConsumption":{"value":null}},"samsungvd.mediaInputSource":{"supportedInputSourcesMap":{"value":[{"id":"dtv","name":"TV"},{"id":"HDMI1","name":"Orange"},{"id":"HDMI2","name":"Chromecast"}],"timestamp":"2023-07-16T22:57:06.202Z"},"inputSource":{"value":"HDMI1","timestamp":"2023-11-13T18:26:45.295Z"}},"custom.tvsearch":[],"samsungvd.ambient":[],"refresh":[],"custom.error":{"error":{"value":null}},"execute":{"data":{"value":{"payload":{"rt":["x.com.samsung.tv.deviceinfo"],"if":["oic.if.r","oic.if.baseline"],"x.com.samsung.tv.btmac":"10:2B:41:35:ED:79","x.com.samsung.tv.blemac":"10:2B:41:35:ED:79","x.com.samsung.tv.wifimac":"10:2b:41:35:ed:78","x.com.samsung.tv.ethmac":"d8:a3:5c:fd:dc:ef","x.com.samsung.tv.p2pmac":"12:2b:41:35:ed:78","x.com.samsung.tv.udn":"14d63aa3-285c-48d0-99d0-9b6b427598ff","x.com.samsung.tv.category":"tv","x.com.samsung.tv.onsupport":false,"x.com.samsung.tv.ambientsupport":true,"x.com.samsung.country":"FRA","x.com.samsung.modelid":"21_NIKEM2_QTV","x.com.samsung.infolinkversion":"T-INFOLINK2021-1010","x.com.samsung.tv.countrycode":"FR","x.com.samsung.tv.swmodel":"QAQ95","x.com.samsung.tv.sn":"0J123HDT100001X","x.com.samsung.tv.paneltime":1770,"x.com.samsung.tv.thingversion":"3.5.0","x.com.samsung.tv.mnid":"0AJK","x.com.samsung.tv.setupid":"101","x.com.samsung.tv.vendorcode":"Samsung","x.com.samsung.tv.language":"fr_FR","x.com.samsung.tv.year":2021,"x.com.samsung.tv.duid":"C4PBC5XIWO2PT"}},"data":{"href":"/sec/tv/deviceinfo"},"timestamp":"2022-09-24T17:19:09.173Z"}},"tvChannel":{"tvChannel":{"value":"","timestamp":"2023-11-13T21:28:21.941Z"},"tvChannelName":{"value":"","timestamp":"2023-11-13T21:28:21.941Z"}},"custom.picturemode":{"pictureMode":{"value":"Image adaptative","timestamp":"2023-11-13T18:18:06.860Z"},"supportedPictureModes":{"value":["Image adaptative"],"timestamp":"2023-11-13T18:18:06.860Z"},"supportedPictureModesMap":{"value":[{"id":"modeIntelligent","name":"Image adaptative"}],"timestamp":"2023-11-13T18:18:06.860Z"}},"samsungvd.ambientContent":{"supportedAmbientApps":{"value":["weather"],"timestamp":"2023-08-31T06:03:33.477Z"}},"custom.recording":[],"custom.soundmode":{"supportedSoundModesMap":{"value":[{"id":"modeAmplify","name":"Amplifier"},{"id":"modeStandard","name":"Standard"}],"timestamp":"2023-10-30T13:35:07.125Z"},"soundMode":{"value":"Amplifier","timestamp":"2022-04-10T08:38:40.815Z"},"supportedSoundModes":{"value":["Amplifier","Standard"],"timestamp":"2023-10-30T13:35:07.125Z"}},"audioMute":{"mute":{"value":"unmuted","timestamp":"2023-11-23T06:41:39.651Z"}},"mediaTrackControl":{"supportedTrackControlCommands":{"value":null}}}}}}}
