9Bonjour,
je n’arrive pas à faire fonctionner un switch AQARA SSM-U01 (LUMI.lumi.switch.n0agl1), il est bien détecté et inclus, testé avec appli Aqara et google home : il fonctionne.
mais pas avec mon jeedom sur delta v4.1.25 plugin zigbee et compatible Jeedom compatibility
sur chaque commande j’ai l’erreur cluster NOT FOUND
Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {« ieee »:« 54:ef:44:10:00:0f:c5:35 »,« cmd »:[{« endpoint »:1,« cluster »:« on_off »,« command »:« off »,« await »:1}],« allowQueue »:false} erreur : {« state »:« error »,« result »:"[54:ef:44:10:00:0f:c5:35][zdevices.command] Cluster not found : on_off",« code »:0}
`LOIC a écrit ici plugin-ZIGBEE Beta - #1464 par Phil32
et chez moi ce n’est pas pareil !!!
"ieee": "54:ef:44:10:00:0f:c5:35",
"nwk": 11359,
"status": 2,
"lqi": "255",
"rssi": "-52",
"last_seen": "1631920092.286599",
"node_descriptor": "01:40:8e:5f:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.switch.n0agl1",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 21
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.switch.n0agl1"
"id": 6,
"name": "date_code",
"value": "Aug 8 2020"
"id": 7,
"name": "power_source",
"value": 0
"id": 16384,
"name": "sw_build_id",
"value": ""
"id": 2,
"name": "Device Temperature",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 9,
"name": "Alarms",
"attributes": []
"id": 10,
"name": "Time",
"attributes": [
"id": 0,
"name": "time",
"value": 685233847
"id": 1,
"name": "time_status",
"value": 1
"id": 64704,
"name": "Manufacturer Specific",
"attributes": []
"id": 41,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 18,
"name": "MultistateInput",
"attributes": [
"id": 85,
"name": "present_value",
"value": 0
"id": 21,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"name": "AnalogInput",
"attributes": [
"id": 85,
"value": 0
"id": 31,
"status": 1,
"device_type": 256,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 12,
"attributes": [
"id": 85,
"value": 0
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4447,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
2,
3,
4,
5,
9,
10,
64704
25
"41": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
18
"21": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"31": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
12
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
