je voulais savoir si les config de type RAID sur Delta étaient supportées par le plugin ?
Car sur la révo j’arrivais bien a récupérer les infos disque, là quand je tente la recherche j’ai systématiquement une erreur (après avoir supprimé l’équipement et relancé une détection) :
Mon Jul 13 09:42:30.098277 2020] [php7:error] [pid 12389] [client 192.168.0.1:62054] PHP Fatal error: Uncaught ArgumentCountError: Too few arguments to function Freebox_OS::AddEqLogic(), 2 passed in /var/www/html/plugins/Freebox_OS/core/class/FreeboxAPI.class.php on line 239 and exactly 6 expected in /var/www/html/plugins/Freebox_OS/core/class/Freebox_OS.class.php:99
Stack trace:
#0 /var/www/html/plugins/Freebox_OS/core/class/FreeboxAPI.class.php(239): Freebox_OS::AddEqLogic('Disque Dur', 'Disque')
#1 /var/www/html/plugins/Freebox_OS/core/ajax/Freebox_OS.ajax.php(73): FreeboxAPI->disques()
#2 {main}
thrown in /var/www/html/plugins/Freebox_OS/core/class/Freebox_OS.class.php on line 99, referer: https://192.168.0.101/index.php?v=d&p=Freebox_OS&m=Freebox_OS&id=159
[2020-07-13 09:42:30][DEBUG] : ┌───────── Début de Mise à jour
[2020-07-13 09:42:30][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.free.fr/api/v3/storage/disk/([])
[2020-07-13 09:42:30][DEBUG] : │ [FreeboxRequest] {"success":true,"result":[{"idle_duration":6,"spinning":true,"table_type":"raid","firmware":"04.01A04","type":"sata","idle":true,"connector":2,"id":1000,"state":"disabled","time_before_spindown":594,"total_bytes":1000000000000,"model":"WDC WD10SPZX-08Z10","active_duration":0,"temp":46,"serial":"WD-WXN1AA8283Z5","partitions":[{"fstype":"raid","total_bytes":0,"label":"Volume 1000Go","id":1000,"internal":false,"fsck_result":"no_run_yet","state":"umounted","disk_id":1000,"free_bytes":0,"used_bytes":0,"path":"L1ZvbHVtZSAxMDAwR28="}]},{"idle_duration":6,"spinning":true,"table_type":"raid","firmware":"04.01A04","type":"sata","idle":true,"connector":3,"id":2000,"state":"disabled","time_before_spindown":594,"total_bytes":1000000000000,"model":"WDC WD10SPZX-08Z10","active_duration":0,"temp":43,"serial":"WD-WXA1A981J4DT","partitions":[{"fstype":"raid","total_bytes":0,"label":"Volume 1000Go 1","id":2000,"internal":false,"fsck_result":"no_run_yet","state":"umounted","disk_id":2000,"free_bytes":0,"used_bytes":0,"path":"L1ZvbHVtZSAxMDAwR28gMQ=="}]},{"idle_duration":6,"spinning":true,"table_type":"raid","firmware":"02.01A02","type":"sata","idle":true,"connector":0,"id":3000,"state":"disabled","time_before_spindown":594,"total_bytes":1000000000000,"model":"WDC WD10JUCX-56WPNY0","active_duration":0,"temp":49,"serial":"WD-WXC1A6813LS4","partitions":[{"fstype":"raid","total_bytes":0,"label":"Volume 1000Go 2","id":3000,"internal":false,"fsck_result":"no_run_yet","state":"umounted","disk_id":3000,"free_bytes":0,"used_bytes":0,"path":"L1ZvbHVtZSAxMDAwR28gMg=="}]},{"type":"raid","total_bytes":2000000000000,"connector":0,"id":4000,"active_duration":0,"partitions":[{"fstype":"ext4","total_bytes":1960000000000,"label":"Freebox","id":4000,"internal":false,"fsck_result":"no_run_yet","state":"mounted","disk_id":4000,"free_bytes":1510000000000,"used_bytes":449350000000,"path":"L0ZyZWVib3g="}],"idle_duration":0,"state":"enabled","idle":false,"spinning":false,"model":"","table_type":"superfloppy","temp":0,"serial":"","firmware":""}]}
[2020-07-13 09:42:30][DEBUG] : └─────────
[2020-07-13 09:42:30][DEBUG] : ┌───────── Update Disque
[2020-07-13 09:42:30][DEBUG] : │ Occupation [sata] - 1000: 0/0 => NAN%
J’ai vu que l’api proposait bien des infos pour les disk et partitions, mais rien pour le raid a proprement dit.
Cependant, les infos des disques sont bien retournées, juste pas exploitable visiblement.
