Voici
"date_code": "NULL",
"definition": {
"description": "Touch thermostat",
"exposes": [
"access": 5,
"description": "Current temperature measured from the floor sensor",
"label": "Outdoor temperature",
"name": "outdoor_temperature",
"property": "outdoor_temperature",
"type": "numeric",
"unit": "\u00b0C"
"features": [
"access": 7,
"description": "Temperature setpoint",
"label": "Occupied heating setpoint",
"name": "occupied_heating_setpoint",
"property": "occupied_heating_setpoint",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 40,
"value_min": 0,
"value_step": 0.1
"access": 7,
"label": "Unoccupied heating setpoint",
"name": "unoccupied_heating_setpoint",
"property": "unoccupied_heating_setpoint",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 40,
"value_min": 0,
"value_step": 0.1
"access": 5,
"description": "Current temperature measured on the device",
"label": "Local temperature",
"name": "local_temperature",
"property": "local_temperature",
"type": "numeric",
"unit": "\u00b0C"
"access": 7,
"description": "Offset to add\/subtract to the local temperature",
"label": "Local temperature calibration",
"name": "local_temperature_calibration",
"property": "local_temperature_calibration",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 3,
"value_min": -3,
"value_step": 0.1
"access": 7,
"description": "Mode of this device",
"label": "System mode",
"name": "system_mode",
"property": "system_mode",
"type": "enum",
"values": [
"off",
"auto",
"heat"
"access": 5,
"description": "The current running state",
"label": "Running state",
"name": "running_state",
"property": "running_state",
"type": "enum",
"values": [
"idle",
"heat"
"type": "climate"
"access": 7,
"description": "Enable\/disable away mode",
"label": "Away mode",
"name": "away_mode",
"property": "away_mode",
"type": "binary",
"value_off": "OFF",
"value_on": "ON"
"access": 7,
"description": "Enables\/disables physical input on the device",
"label": "Child lock",
"name": "child_lock",
"property": "child_lock",
"type": "binary",
"value_off": "LOCK",
"value_on": "UNLOCK"
"access": 1,
"category": "diagnostic",
"description": "Instantaneous measured power",
"label": "Power",
"name": "power",
"property": "power",
"type": "numeric",
"unit": "W"
"access": 1,
"description": "Instantaneous measured electrical current",
"label": "Current",
"name": "current",
"property": "current",
"type": "numeric",
"unit": "A"
"access": 1,
"description": "Measured electrical potential value",
"label": "Voltage",
"name": "voltage",
"property": "voltage",
"type": "numeric",
"unit": "V"
"access": 1,
"description": "Sum of consumed energy",
"label": "Energy",
"name": "energy",
"property": "energy",
"type": "numeric",
"unit": "kWh"
"access": 7,
"description": "OLED brightness when operating the buttons. Default: Medium.",
"label": "Lcd brightness",
"name": "lcd_brightness",
"property": "lcd_brightness",
"type": "enum",
"values": [
"low",
"mid",
"high"
"access": 7,
"description": "Key beep volume and vibration level. Default: Low.",
"label": "Button vibration level",
"name": "button_vibration_level",
"property": "button_vibration_level",
"type": "enum",
"values": [
"off",
"low",
"high"
"access": 7,
"description": "Type of the external floor sensor. Default: NTC 10K\/25.",
"label": "Floor sensor type",
"name": "floor_sensor_type",
"property": "floor_sensor_type",
"type": "enum",
"values": [
"10k",
"15k",
"50k",
"100k",
"12k"
"access": 7,
"description": "The sensor used for heat control. Default: Room Sensor.",
"label": "Sensor",
"name": "sensor",
"property": "sensor",
"type": "enum",
"values": [
"air",
"floor",
"both"
"access": 7,
"description": "The mode after a power reset. Default: Previous Mode.",
"label": "Powerup status",
"name": "powerup_status",
"property": "powerup_status",
"type": "enum",
"values": [
"default",
"last_status"
"access": 7,
"description": "The tempearatue calibration for the external floor sensor, between -3 and 3 in 0.1\u00b0C. Default: 0.",
"label": "Floor sensor calibration",
"name": "floor_sensor_calibration",
"property": "floor_sensor_calibration",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 3,
"value_min": -3,
"value_step": 0.1
"access": 7,
"description": "The duration of Dry Mode, between 5 and 100 minutes. Default: 5.",
"label": "Dry time",
"name": "dry_time",
"property": "dry_time",
"type": "numeric",
"unit": "min",
"value_max": 100,
"value_min": 5
"access": 7,
"description": "The mode after Dry Mode. Default: Auto.",
"label": "Mode after dry",
"name": "mode_after_dry",
"property": "mode_after_dry",
"type": "enum",
"values": [
"off",
"manual",
"auto",
"away"
"access": 7,
"description": "The temperature on the display. Default: Room Temperature.",
"label": "Temperature display",
"name": "temperature_display",
"property": "temperature_display",
"type": "enum",
"values": [
"room",
"floor"
"access": 7,
"description": "The threshold to detect window open, between 0.0 and 8.0 in 0.5 \u00b0C. Default: 0 (disabled).",
"label": "Window open check",
"name": "window_open_check",
"property": "window_open_check",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 8,
"value_min": 0,
"value_step": 0.5
"access": 7,
"description": "Hysteresis setting, between 0.5 and 2 in 0.1 \u00b0C. Default: 0.5.",
"label": "Hysterersis",
"name": "hysterersis",
"property": "hysterersis",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 2,
"value_min": 0.5,
"value_step": 0.1
"access": 7,
"label": "Display auto off enabled",
"name": "display_auto_off_enabled",
"property": "display_auto_off_enabled",
"type": "enum",
"values": [
"disabled",
"enabled"
"access": 7,
"description": "Room temperature alarm threshold, between 20 and 60 in \u00b0C. 0 means disabled. Default: 45.",
"label": "Alarm airtemp overvalue",
"name": "alarm_airtemp_overvalue",
"property": "alarm_airtemp_overvalue",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 60,
"value_min": 20
"access": 1,
"description": "Link quality (signal strength)",
"label": "Linkquality",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "SR-ZG9092A",
"options": [
"access": 2,
"description": "Calibrates the power value (percentual offset), takes into effect on next report of device.",
"label": "Power calibration",
"name": "power_calibration",
"property": "power_calibration",
"type": "numeric"
"access": 2,
"description": "Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.",
"label": "Power precision",
"name": "power_precision",
"property": "power_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "Calibrates the current value (percentual offset), takes into effect on next report of device.",
"label": "Current calibration",
"name": "current_calibration",
"property": "current_calibration",
"type": "numeric"
"access": 2,
"description": "Number of digits after decimal point for current, takes into effect on next report of device. This option can only decrease the precision, not increase it.",
"label": "Current precision",
"name": "current_precision",
"property": "current_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "Calibrates the voltage value (percentual offset), takes into effect on next report of device.",
"label": "Voltage calibration",
"name": "voltage_calibration",
"property": "voltage_calibration",
"type": "numeric"
"access": 2,
"description": "Number of digits after decimal point for voltage, takes into effect on next report of device. This option can only decrease the precision, not increase it.",
"label": "Voltage precision",
"name": "voltage_precision",
"property": "voltage_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "Calibrates the energy value (percentual offset), takes into effect on next report of device.",
"label": "Energy calibration",
"name": "energy_calibration",
"property": "energy_calibration",
"type": "numeric"
"access": 2,
"description": "Number of digits after decimal point for energy, takes into effect on next report of device. This option can only decrease the precision, not increase it.",
"label": "Energy precision",
"name": "energy_precision",
"property": "energy_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "Controls the temperature unit of the thermostat (default celsius).",
"label": "Thermostat unit",
"name": "thermostat_unit",
"property": "thermostat_unit",
"type": "enum",
"values": [
"celsius",
"fahrenheit"
"supports_ota": false,
"vendor": "Sunricher"
"disabled": false,
"endpoints": {
"1": {
"bindings": [
"cluster": "genBasic",
"target": {
"endpoint": 1,
"ieee_address": "0x00212effff09df6e",
"type": "endpoint"
"cluster": "genIdentify",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "hvacThermostat",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "seMetering",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "haElectricalMeasurement",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "genAlarms",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "msOccupancySensing",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "genTime",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "hvacUserInterfaceCfg",
"target": {
"endpoint": 1,
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genIdentify",
"genGroups",
"genScenes",
"genAlarms",
"genTime",
"hvacThermostat",
"seMetering",
"output": [
"genIdentify",
"configured_reportings": [
"attribute": "localTemp",
"maximum_report_interval": 3600,
"minimum_report_interval": 0,
"reportable_change": 10
"attribute": "occupiedHeatingSetpoint",
"attribute": "unoccupiedHeatingSetpoint",
"attribute": "keypadLockout",
"minimum_report_interval": 10,
"reportable_change": null
"attribute": "occupancy",
"attribute": "activePower",
"minimum_report_interval": 30,
"attribute": "rmsCurrent",
"reportable_change": 50
"attribute": "rmsVoltage",
"reportable_change": 20
"attribute": "currentSummDelivered",
"minimum_report_interval": 5,
"reportable_change": [
1,
1
"attribute": 4096,
"attribute": 4097,
"attribute": 4098,
"attribute": 4099,
"attribute": 4100,
"attribute": 4101,
"reportable_change": 0
"attribute": 4102,
"attribute": 4103,
"attribute": 4104,
"attribute": 4105,
"attribute": 4106,
"attribute": 4107,
"attribute": 8193,
"attribute": 8194,
"scenes": []
"2": {
"bindings": [],
"clusters": {
"input": [
"genBasic",
"genIdentify"
"output": [
"genIdentify",
"genOta"
"configured_reportings": [],
"scenes": []
"242": {
"bindings": [],
"clusters": {
"input": [],
"output": [
"greenPower"
"scenes": []
"friendly_name": "Rez_Salon_Thermostat",
"ieee_address": "0x1fff000000000082",
"interview_completed": true,
"interviewing": false,
"manufacturer": "Sunricher",
"model_id": "ZG9092",
"network_address": 28687,
"power_source": "Mains (single phase)",
"software_build_id": "6.9.1.0_r4",
"supported": true,
"type": "Router"
