Pour info, j’ai essayé de faire une restauration et même problème.
Et voici le message d’erreur du demon:
8/6/2020, 6:41:04 PM] Loaded config.json with 6 accessories and 1 platforms.
[8/6/2020, 6:41:04 PM] ---
[8/6/2020, 6:41:06 PM] Loaded plugin: homebridge-alexa
[8/6/2020, 6:41:06 PM] Registering platform 'homebridge-alexa.Alexa'
[8/6/2020, 6:41:06 PM] ---
[8/6/2020, 6:41:08 PM] ====================
[8/6/2020, 6:41:08 PM] ERROR LOADING PLUGIN homebridge-camera-ffmpeg:
[8/6/2020, 6:41:08 PM] Error: Cannot find module './docs'
Require stack:
- /var/www/html/plugins/homebridge/resources/node_modules/googleapis/build/src/apis/index.js
- /var/www/html/plugins/homebridge/resources/node_modules/googleapis/build/src/googleapis.js
- /var/www/html/plugins/homebridge/resources/node_modules/googleapis/build/src/index.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-camera-ffmpeg/drive.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-camera-ffmpeg/ffmpeg.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-camera-ffmpeg/index.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/plugin.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/server.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/cli.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/bin/homebridge
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
at Function.Module._load (internal/modules/cjs/loader.js:841:27)
at Module.require (internal/modules/cjs/loader.js:1025:19)
at require (internal/modules/cjs/helpers.js:72:18)
at Object.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/googleapis/build/src/apis/index.js:85:14)
at Module._compile (internal/modules/cjs/loader.js:1137:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
at Module.load (internal/modules/cjs/loader.js:985:32)
at Function.Module._load (internal/modules/cjs/loader.js:878:14)
[8/6/2020, 6:41:08 PM] Loaded plugin: homebridge-jeedom
internal/modules/cjs/loader.js:968
throw err;
Require stack:
- /var/www/html/plugins/homebridge/resources/node_modules/fakegato-history/lib/googleDrive.js
- /var/www/html/plugins/homebridge/resources/node_modules/fakegato-history/fakegato-storage.js
- /var/www/html/plugins/homebridge/resources/node_modules/fakegato-history/fakegato-history.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js
at Module.require (internal/modules/cjs/loader.js:1025:19) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/var/www/html/plugins/homebridge/resources/node_modules/googleapis/build/src/apis/index.js',
'/var/www/html/plugins/homebridge/resources/node_modules/googleapis/build/src/googleapis.js',
'/var/www/html/plugins/homebridge/resources/node_modules/googleapis/build/src/index.js',
'/var/www/html/plugins/homebridge/resources/node_modules/fakegato-history/lib/googleDrive.js',
'/var/www/html/plugins/homebridge/resources/node_modules/fakegato-history/fakegato-storage.js',
'/var/www/html/plugins/homebridge/resources/node_modules/fakegato-history/fakegato-history.js',
'/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js',
'/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/plugin.js',
'/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/server.js',
'/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/cli.js',
'/var/www/html/plugins/homebridge/resources/node_modules/homebridge/bin/homebridge'
J’ai trouvé ces postes mais moi je n’ai pas touché aux droits et je ne suis pas en beta:
Voici la liste des plugins:
Et aucun plugin dans homebridge.
C.
