Après avoir stoppé le daemon du plugin Enpahsesecur j’ai réalisé sa mise à jour dans la dernière version proposée par l’outil de mise à jour. Et depuis je n’arrive pas à remettre le daemon en route
C’est bon !!!
L’installation a dû se faire correctement cette fois-ci :
* Installation des dépendances *
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 238 not upgraded.
The following additional packages will be installed:
icu-devtools libicu-dev libicu63 libxml2 libxslt1.1
Suggested packages:
icu-doc
icu-devtools libicu-dev libxml2-dev libxslt1-dev
The following packages will be upgraded:
3 upgraded, 4 newly installed, 0 to remove and 235 not upgraded.
Need to get 19.5 MB of archives.
After this operation, 49.2 MB of additional disk space will be used.
Get:1 http://security.debian.org buster/updates/main arm64 libxml2 arm64 2.9.4+dfsg1-7+deb10u6 [625 kB]
Get:2 http://deb.debian.org/debian buster/main arm64 libicu63 arm64 63.1-6+deb10u3 [8154 kB]
Get:3 http://security.debian.org buster/updates/main arm64 libxml2-dev arm64 2.9.4+dfsg1-7+deb10u6 [749 kB]
Get:4 http://security.debian.org buster/updates/main arm64 libxslt1.1 arm64 1.1.32-2.2~deb10u2 [225 kB]
Get:5 http://security.debian.org buster/updates/main arm64 libxslt1-dev arm64 1.1.32-2.2~deb10u2 [518 kB]
Get:6 http://deb.debian.org/debian buster/main arm64 icu-devtools arm64 63.1-6+deb10u3 [179 kB]
Get:7 http://deb.debian.org/debian buster/main arm64 libicu-dev arm64 63.1-6+deb10u3 [9064 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 19.5 MB in 4s (4755 kB/s)
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 60092 files and directories currently installed.)
Preparing to unpack .../0-libicu63_63.1-6+deb10u3_arm64.deb ...
Unpacking libicu63:arm64 (63.1-6+deb10u3) over (63.1-6+deb10u1) ...
Preparing to unpack .../1-libxml2_2.9.4+dfsg1-7+deb10u6_arm64.deb ...
Unpacking libxml2:arm64 (2.9.4+dfsg1-7+deb10u6) over (2.9.4+dfsg1-7+deb10u2) ...
Selecting previously unselected package icu-devtools.
Preparing to unpack .../2-icu-devtools_63.1-6+deb10u3_arm64.deb ...
Unpacking icu-devtools (63.1-6+deb10u3) ...
Selecting previously unselected package libicu-dev:arm64.
Preparing to unpack .../3-libicu-dev_63.1-6+deb10u3_arm64.deb ...
Unpacking libicu-dev:arm64 (63.1-6+deb10u3) ...
Selecting previously unselected package libxml2-dev:arm64.
Preparing to unpack .../4-libxml2-dev_2.9.4+dfsg1-7+deb10u6_arm64.deb ...
Unpacking libxml2-dev:arm64 (2.9.4+dfsg1-7+deb10u6) ...
Preparing to unpack .../5-libxslt1.1_1.1.32-2.2~deb10u2_arm64.deb ...
Unpacking libxslt1.1:arm64 (1.1.32-2.2~deb10u2) over (1.1.32-2.2~deb10u1) ...
Selecting previously unselected package libxslt1-dev:arm64.
Preparing to unpack .../6-libxslt1-dev_1.1.32-2.2~deb10u2_arm64.deb ...
Unpacking libxslt1-dev:arm64 (1.1.32-2.2~deb10u2) ...
Setting up libicu63:arm64 (63.1-6+deb10u3) ...
Setting up icu-devtools (63.1-6+deb10u3) ...
Setting up libicu-dev:arm64 (63.1-6+deb10u3) ...
Setting up libxml2:arm64 (2.9.4+dfsg1-7+deb10u6) ...
Setting up libxml2-dev:arm64 (2.9.4+dfsg1-7+deb10u6) ...
Setting up libxslt1.1:arm64 (1.1.32-2.2~deb10u2) ...
Setting up libxslt1-dev:arm64 (1.1.32-2.2~deb10u2) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10) ...
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org buster/updates InRelease
Get:4 http://deb.debian.org/debian buster-backports InRelease [51.4 kB]
Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
Hit:6 http://mirror.vinehost.net/armbian/apt buster InRelease
Fetched 51.4 kB in 2s (21.8 kB/s)
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 235 not upgraded.
python3-dev is already the newest version (3.7.3-1).
python3-venv is already the newest version (3.7.3-1).
The directory '/var/www/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/var/www/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: cython<3.0.0 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (0.29.36)
Requirement already satisfied: pyyaml in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (6.0.1)
Requirement already satisfied: pyjwt in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (2.8.0)
Requirement already satisfied: serial in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (0.0.97)
Requirement already satisfied: typing-extensions; python_version <= "3.7" in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from pyjwt) (4.7.1)
Requirement already satisfied: future>=0.17.1 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from serial) (0.18.3)
Requirement already satisfied: pyyaml>=3.13 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from serial) (6.0.1)
Requirement already satisfied: iso8601>=0.1.12 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from serial) (2.0.0)
Requirement already satisfied: html5lib in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (1.1)
Requirement already satisfied: pyudev in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (0.24.1)
Requirement already satisfied: six>=1.9 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from html5lib) (1.16.0)
Requirement already satisfied: webencodings in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from html5lib) (0.5.1)
Requirement already satisfied: asyncio in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (3.4.3)
Requirement already satisfied: httpx in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (0.24.1)
Requirement already satisfied: httpcore<0.18.0,>=0.15.0 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from httpx) (0.17.3)
Requirement already satisfied: certifi in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from httpx) (2023.7.22)
Requirement already satisfied: sniffio in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from httpx) (1.3.0)
Requirement already satisfied: idna in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from httpx) (3.4)
Requirement already satisfied: anyio<5.0,>=3.0 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from httpcore<0.18.0,>=0.15.0->httpx) (3.7.1)
Requirement already satisfied: h11<0.15,>=0.13 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from httpcore<0.18.0,>=0.15.0->httpx) (0.14.0)
Requirement already satisfied: exceptiongroup; python_version < "3.11" in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from anyio<5.0,>=3.0->httpcore<0.18.0,>=0.15.0->httpx) (1.1.2)
Requirement already satisfied: typing-extensions; python_version < "3.8" in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from anyio<5.0,>=3.0->httpcore<0.18.0,>=0.15.0->httpx) (4.7.1)
Collecting lxml
Downloading https://files.pythonhosted.org/packages/30/39/7305428d1c4f28282a4f5bdbef24e0f905d351f34cf351ceb131f5cddf78/lxml-4.9.3.tar.gz (3.6MB)
Installing collected packages: lxml
Running setup.py install for lxml: started
Running setup.py install for lxml: still running...
Running setup.py install for lxml: finished with status 'done'
Successfully installed lxml-4.9.3
Requirement already satisfied: html-parser in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (0.2)
Requirement already satisfied: ply in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from html-parser) (3.11)
Requirement already satisfied: six in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (1.16.0)
Requirement already satisfied: requests in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (2.31.0)
Requirement already satisfied: urllib3<3,>=1.21.1 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from requests) (2.0.4)
Requirement already satisfied: certifi>=2017.4.17 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from requests) (2023.7.22)
Requirement already satisfied: charset-normalizer<4,>=2 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from requests) (3.2.0)
Requirement already satisfied: idna<4,>=2.5 in /var/www/html/plugins/enphasesecur/resources/venv/lib/python3.7/site-packages (from requests) (3.4)
* Installation des dépendances OK *
