Avec les récentes mises à jour de l’application Google Home, les périphériques de type « Capteur » prennent de plus en plus d’intérêt. C’est pourquoi je propose de rajouter au plug-in GSH un trait qui n’est actuellement pas implémenté. Il concerne l’occupation d’une pièce associé au type générique « Présence ».
Ci-dessous le code de la classe gsh_OccupancySensing.class.php. Testé fonctionnel sur mon installation.
<?php
/* This file is part of Jeedom.
* Jeedom is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Jeedom is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with Jeedom. If not, see <http://www.gnu.org/licenses/>.
/* * ***************************Includes********************************* */
require_once dirname(__FILE__) . '/../../../../core/php/core.inc.php';
class gsh_OccupancySensing {
/* * *************************Attributs****************************** */
private static $_PRESENCE = array('PRESENCE');
/* * ***********************Methode static*************************** */
public static function discover($_device, $_eqLogic) {
$return = array('traits' => array(), 'customData' => array(), 'attributes' => array());
$return['attributes']['dataTypesSupported'] = array();
foreach ($_eqLogic->getCmd() as $cmd) {
if (in_array($cmd->getGeneric_type(), self::$_PRESENCE)) {
$return['customData']['OccupancySensing_cmdGetOccupancy'] = $cmd->getId();
if (!in_array('action.devices.traits.OccupancySensing', $return['traits'])) {
$return['traits'][] = 'action.devices.traits.OccupancySensing';
$return['attributes']['occupancySensorConfiguration'][] = array(
'occupancySensorType' => 'PIR',
'occupiedToUnoccupiedDelaySec' => 30,
'unoccupiedToOccupiedDelaySec' => 0,
'unoccupiedToOccupiedEventThreshold' => 1,
return $return;
public static function needGenericType() {
return array(
__('Présence', __FILE__) => self::$_PRESENCE
public static function exec($_device, $_executions, $_infos) {
$return = array('status' => 'ERROR');
return $return;
public static function query($_device, $_infos) {
$return = array();
$return['online'] = true;
$return['on'] = true;
$eqLogic = $_device->getLink();
$return['occupancy'] = 'UNKNOWN_OCCUPANCY_STATE';
foreach ($_infos['customData'] as $key => $cmd_id) {
$cmd = cmd::byId($cmd_id);
if (!is_object($cmd)) {
continue;
$type = str_replace('OccupancySensing_cmdGet', '', $key);
$value = $cmd->execCmd();
switch ($type) {
case 'Occupancy':
$value = ($value == 1) ? 'OCCUPIED' : 'UNOCCUPIED';
break;
$return['occupancy'] = $value;
return $return;
/* * *********************Méthodes d'instance************************* */
/* * **********************Getteur Setteur*************************** */
Après avoir rajouté cette classe, il suffit d’inclure le fichier dans gsh.class.php :
include_file('core', 'gsh_OccupancySensing', 'class', 'gsh');
Puis rajouter le trait au device de type « Capteur » :
'action.devices.types.SENSOR' => array('name' => __('Capteur', __FILE__), 'traits' => array('OnOff', 'SensorState', 'TemperatureControl', 'Brightness', 'HumiditySetting', 'OccupancySensing')),
Et le tour est joué ! Pour que ce soit parfait, il ne reste plus qu’à rajouter les traductions du type générique « Présence » mais cela n’est pas bien long à réaliser.
Ça serait super que vous pouviez rajouter cette fonctionnalité dans le plugin officiel GSH.
Merci d’avance,
Alexis
