Je suis sur Smart en Version : 4.2.11 et les plugins à jour.
Les packages sont à jour (Règlages / Système / Configuration / >_ OS/DB / Vérification des packages système)
Package Jeedom.pdf (408,9 Ko)
Mon système fonctionne mais si je lance
sudo apt update
j’ai « 165 packages can be upgraded »
Puis je rester comme cela ? ou est-ce préférable de mettre ces paquets à jour et pourquoi ?
sudo apt list --upgradable
Listing...
apache2-bin/oldstable 2.4.38-3+deb10u7 arm64 [upgradable from: 2.4.38-3+deb10u3]
apache2-data/oldstable 2.4.38-3+deb10u7 all [upgradable from: 2.4.38-3+deb10u3]
apache2-utils/oldstable 2.4.38-3+deb10u7 arm64 [upgradable from: 2.4.38-3+deb10u3]
apache2/oldstable 2.4.38-3+deb10u7 arm64 [upgradable from: 2.4.38-3+deb10u3]
apt-transport-https/oldstable,oldstable-updates 1.8.2.3 all [upgradable from: 1.8.2.1]
base-files/oldstable 10.3+deb10u11 arm64 [upgradable from: 10.3+deb10u4]
ca-certificates/oldstable,oldstable-updates 20200601~deb10u2 all [upgradable from: 20200601~deb10u1]
chromium-common/oldstable,oldstable 89.0.4389.114-1~deb10u1 arm64 [upgradable from: 83.0.4103.116-1~deb10u3]
chromium/oldstable,oldstable 89.0.4389.114-1~deb10u1 arm64 [upgradable from: 83.0.4103.116-1~deb10u3]
curl/oldstable,oldstable 7.64.0-4+deb10u2 arm64 [upgradable from: 7.64.0-4+deb10u1]
dbus-user-session/oldstable 1.12.20-0+deb10u1 arm64 [upgradable from: 1.12.16-1]
dbus/oldstable 1.12.20-0+deb10u1 arm64 [upgradable from: 1.12.16-1]
debconf-i18n/oldstable 1.5.71+deb10u1 all [upgradable from: 1.5.71]
debconf/oldstable 1.5.71+deb10u1 all [upgradable from: 1.5.71]
debian-archive-keyring/oldstable 2019.1+deb10u1 all [upgradable from: 2019.1]
device-tree-compiler/oldstable 1.4.7-4 arm64 [upgradable from: 1.4.7-3]
distro-info-data/oldstable 0.41+deb10u4 all [upgradable from: 0.41+deb10u2]
espeak-data/oldstable 1.48.04+dfsg-7+deb10u1 arm64 [upgradable from: 1.48.04+dfsg-7]
espeak/oldstable 1.48.04+dfsg-7+deb10u1 arm64 [upgradable from: 1.48.04+dfsg-7]
ffmpeg/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
file/oldstable 1:5.35-4+deb10u2 arm64 [upgradable from: 1:5.35-4+deb10u1]
glib-networking-common/oldstable 2.58.0-2+deb10u2 all [upgradable from: 2.58.0-2]
glib-networking-services/oldstable 2.58.0-2+deb10u2 arm64 [upgradable from: 2.58.0-2]
glib-networking/oldstable 2.58.0-2+deb10u2 arm64 [upgradable from: 2.58.0-2]
iputils-ping/oldstable 3:20180629-2+deb10u2 arm64 [upgradable from: 3:20180629-2+deb10u1]
isc-dhcp-client/oldstable 4.4.1-2+deb10u1 arm64 [upgradable from: 4.4.1-2]
isc-dhcp-common/oldstable 4.4.1-2+deb10u1 arm64 [upgradable from: 4.4.1-2]
klibc-utils/oldstable 2.0.6-1+deb10u1 arm64 [upgradable from: 2.0.6-1]
libapache2-mod-php7.3/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
libapt-inst2.0/oldstable,oldstable-updates 1.8.2.3 arm64 [upgradable from: 1.8.2.1]
libapt-pkg5.0/oldstable,oldstable-updates 1.8.2.3 arm64 [upgradable from: 1.8.2.1]
libavahi-client3/oldstable 0.7-4+deb10u1 arm64 [upgradable from: 0.7-4+b1]
libavahi-common-data/oldstable 0.7-4+deb10u1 arm64 [upgradable from: 0.7-4+b1]
libavahi-common3/oldstable 0.7-4+deb10u1 arm64 [upgradable from: 0.7-4+b1]
libavcodec58/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libavdevice58/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libavfilter7/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libavformat58/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libavresample4/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libavutil56/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libbrotli1/oldstable,oldstable 1.0.7-2+deb10u1 arm64 [upgradable from: 1.0.7-2]
libbsd0/oldstable 0.9.1-2+deb10u1 arm64 [upgradable from: 0.9.1-2]
libcairo-gobject2/oldstable 1.16.0-4+deb10u1 arm64 [upgradable from: 1.16.0-4]
libcairo2/oldstable 1.16.0-4+deb10u1 arm64 [upgradable from: 1.16.0-4]
libcups2/oldstable 2.2.10-6+deb10u4 arm64 [upgradable from: 2.2.10-6+deb10u3]
libcurl3-gnutls/oldstable,oldstable 7.64.0-4+deb10u2 arm64 [upgradable from: 7.64.0-4+deb10u1]
libcurl4/oldstable,oldstable 7.64.0-4+deb10u2 arm64 [upgradable from: 7.64.0-4+deb10u1]
libdbi-perl/oldstable 1.642-1+deb10u2 arm64 [upgradable from: 1.642-1+b1]
libdbus-1-3/oldstable 1.12.20-0+deb10u1 arm64 [upgradable from: 1.12.16-1]
libdns-export1104/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u6 arm64 [upgradable from: 1:9.11.5.P4+dfsg-5.1+deb10u1]
libespeak1/oldstable 1.48.04+dfsg-7+deb10u1 arm64 [upgradable from: 1.48.04+dfsg-7]
libexpat1-dev/oldstable 2.2.6-2+deb10u2 arm64 [upgradable from: 2.2.6-2+deb10u1]
libexpat1/oldstable 2.2.6-2+deb10u2 arm64 [upgradable from: 2.2.6-2+deb10u1]
libfreetype6/oldstable,oldstable 2.9.1-3+deb10u2 arm64 [upgradable from: 2.9.1-3+deb10u1]
libgcrypt20/oldstable 1.8.4-5+deb10u1 arm64 [upgradable from: 1.8.4-5]
libglib2.0-data/oldstable 2.58.3-2+deb10u3 all [upgradable from: 2.58.3-2+deb10u2]
libgnutls30/oldstable 3.6.7-4+deb10u7 arm64 [upgradable from: 3.6.7-4+deb10u4]
libgssapi-krb5-2/oldstable 1.17-3+deb10u3 arm64 [upgradable from: 1.17-3]
libgstreamer-plugins-base1.0-0/oldstable,oldstable 1.14.4-2+deb10u1 arm64 [upgradable from: 1.14.4-2]
libhogweed4/oldstable,oldstable 3.4.1-1+deb10u1 arm64 [upgradable from: 3.4.1-1]
libicu63/oldstable 63.1-6+deb10u2 arm64 [upgradable from: 63.1-6+deb10u1]
libinput-bin/oldstable 1.12.6-2+deb10u1 arm64 [upgradable from: 1.12.6-2]
libinput10/oldstable 1.12.6-2+deb10u1 arm64 [upgradable from: 1.12.6-2]
libisc-export1100/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u6 arm64 [upgradable from: 1:9.11.5.P4+dfsg-5.1+deb10u1]
libjson-c3/oldstable,oldstable 0.12.1+ds-2+deb10u1 arm64 [upgradable from: 0.12.1+ds-2]
libk5crypto3/oldstable 1.17-3+deb10u3 arm64 [upgradable from: 1.17-3]
libklibc/oldstable 2.0.6-1+deb10u1 arm64 [upgradable from: 2.0.6-1]
libkrb5-3/oldstable 1.17-3+deb10u3 arm64 [upgradable from: 1.17-3]
libkrb5support0/oldstable 1.17-3+deb10u3 arm64 [upgradable from: 1.17-3]
libldap-2.4-2/oldstable,oldstable 2.4.47+dfsg-3+deb10u6 arm64 [upgradable from: 2.4.47+dfsg-3+deb10u2]
libldap-common/oldstable,oldstable 2.4.47+dfsg-3+deb10u6 all [upgradable from: 2.4.47+dfsg-3+deb10u2]
libldb1/oldstable,oldstable 2:1.5.1+really1.4.6-3+deb10u1 arm64 [upgradable from: 2:1.5.1+really1.4.6-3]
libllvm7/oldstable 1:7.0.1-8+deb10u2 arm64 [upgradable from: 1:7.0.1-8]
liblz4-1/oldstable,oldstable 1.8.3-1+deb10u1 arm64 [upgradable from: 1.8.3-1]
libmagic-mgc/oldstable 1:5.35-4+deb10u2 arm64 [upgradable from: 1:5.35-4+deb10u1]
libmagic1/oldstable 1:5.35-4+deb10u2 arm64 [upgradable from: 1:5.35-4+deb10u1]
libnettle6/oldstable,oldstable 3.4.1-1+deb10u1 arm64 [upgradable from: 3.4.1-1]
libnss3/oldstable 2:3.42.1-1+deb10u5 arm64 [upgradable from: 2:3.42.1-1+deb10u2]
libopenmpt0/oldstable,oldstable 0.4.3-1+deb10u1 arm64 [upgradable from: 0.4.3-1]
libp11-kit0/oldstable,oldstable 0.23.15-2+deb10u1 arm64 [upgradable from: 0.23.15-2]
libpam-systemd/oldstable,oldstable 241-7~deb10u8 arm64 [upgradable from: 241-7~deb10u4]
libperl5.28/oldstable 5.28.1-6+deb10u1 arm64 [upgradable from: 5.28.1-6]
libpolkit-agent-1-0/oldstable 0.105-25+deb10u1 arm64 [upgradable from: 0.105-25]
libpolkit-backend-1-0/oldstable 0.105-25+deb10u1 arm64 [upgradable from: 0.105-25]
libpolkit-gobject-1-0/oldstable 0.105-25+deb10u1 arm64 [upgradable from: 0.105-25]
libportaudio2/oldstable 19.6.0-1+deb10u1 arm64 [upgradable from: 19.6.0-1]
libpostproc55/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libproxy1v5/oldstable,oldstable 0.4.15-5+deb10u1 arm64 [upgradable from: 0.4.15-5]
libpython3.7-dev/oldstable 3.7.3-2+deb10u3 arm64 [upgradable from: 3.7.3-2+deb10u2]
libpython3.7-minimal/oldstable 3.7.3-2+deb10u3 arm64 [upgradable from: 3.7.3-2+deb10u2]
libpython3.7-stdlib/oldstable 3.7.3-2+deb10u3 arm64 [upgradable from: 3.7.3-2+deb10u2]
libpython3.7/oldstable 3.7.3-2+deb10u3 arm64 [upgradable from: 3.7.3-2+deb10u2]
libqt5core5a/oldstable 5.11.3+dfsg1-1+deb10u4 arm64 [upgradable from: 5.11.3+dfsg1-1+deb10u3]
libqt5dbus5/oldstable 5.11.3+dfsg1-1+deb10u4 arm64 [upgradable from: 5.11.3+dfsg1-1+deb10u3]
libqt5gui5/oldstable 5.11.3+dfsg1-1+deb10u4 arm64 [upgradable from: 5.11.3+dfsg1-1+deb10u3]
libqt5network5/oldstable 5.11.3+dfsg1-1+deb10u4 arm64 [upgradable from: 5.11.3+dfsg1-1+deb10u3]
libqt5printsupport5/oldstable 5.11.3+dfsg1-1+deb10u4 arm64 [upgradable from: 5.11.3+dfsg1-1+deb10u3]
libqt5widgets5/oldstable 5.11.3+dfsg1-1+deb10u4 arm64 [upgradable from: 5.11.3+dfsg1-1+deb10u3]
libsmbclient/oldstable 2:4.9.5+dfsg-5+deb10u3 arm64 [upgradable from: 2:4.9.5+dfsg-5+deb10u1]
libsndfile1/oldstable,oldstable 1.0.28-6+deb10u1 arm64 [upgradable from: 1.0.28-6]
libsqlite3-0/oldstable 3.27.2-3+deb10u1 arm64 [upgradable from: 3.27.2-3]
libswresample3/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libswscale5/oldstable 7:4.1.8-0+deb10u1 arm64 [upgradable from: 7:4.1.6-1~deb10u1]
libsystemd0/oldstable,oldstable 241-7~deb10u8 arm64 [upgradable from: 241-7~deb10u4]
libunwind8/oldstable 1.2.1-10~deb10u1 arm64 [upgradable from: 1.2.1-9]
libwbclient0/oldstable 2:4.9.5+dfsg-5+deb10u3 arm64 [upgradable from: 2:4.9.5+dfsg-5+deb10u1]
libwebp6/oldstable,oldstable 0.6.1-2+deb10u1 arm64 [upgradable from: 0.6.1-2]
libwebpdemux2/oldstable,oldstable 0.6.1-2+deb10u1 arm64 [upgradable from: 0.6.1-2]
libwebpmux3/oldstable,oldstable 0.6.1-2+deb10u1 arm64 [upgradable from: 0.6.1-2]
libx11-6/oldstable,oldstable 2:1.6.7-1+deb10u2 arm64 [upgradable from: 2:1.6.7-1]
libx11-data/oldstable,oldstable 2:1.6.7-1+deb10u2 all [upgradable from: 2:1.6.7-1]
libx11-xcb1/oldstable,oldstable 2:1.6.7-1+deb10u2 arm64 [upgradable from: 2:1.6.7-1]
libxml2/oldstable 2.9.4+dfsg1-7+deb10u2 arm64 [upgradable from: 2.9.4+dfsg1-7+b3]
libzmq5/oldstable,oldstable 4.3.1-4+deb10u2 arm64 [upgradable from: 4.3.1-4+deb10u1]
libzstd1/oldstable,oldstable 1.3.8+dfsg-3+deb10u2 arm64 [upgradable from: 1.3.8+dfsg-3]
linux-libc-dev/unknown 5.16.4-20220130-odroid arm64 [upgradable from: 4.19.118-2+deb10u1]
mariadb-client-10.3/oldstable 1:10.3.31-0+deb10u1 arm64 [upgradable from: 1:10.3.22-0+deb10u1]
mariadb-client-core-10.3/oldstable 1:10.3.31-0+deb10u1 arm64 [upgradable from: 1:10.3.22-0+deb10u1]
mariadb-client/oldstable 1:10.3.31-0+deb10u1 all [upgradable from: 1:10.3.22-0+deb10u1]
mariadb-common/oldstable 1:10.3.31-0+deb10u1 all [upgradable from: 1:10.3.22-0+deb10u1]
mariadb-server-10.3/oldstable 1:10.3.31-0+deb10u1 arm64 [upgradable from: 1:10.3.22-0+deb10u1]
mariadb-server-core-10.3/oldstable 1:10.3.31-0+deb10u1 arm64 [upgradable from: 1:10.3.22-0+deb10u1]
mariadb-server/oldstable 1:10.3.31-0+deb10u1 all [upgradable from: 1:10.3.22-0+deb10u1]
nmap-common/oldstable 7.70+dfsg1-6+deb10u2 all [upgradable from: 7.70+dfsg1-6+deb10u1]
nmap/oldstable 7.70+dfsg1-6+deb10u2 arm64 [upgradable from: 7.70+dfsg1-6+deb10u1]
nodejs/unknown 14.19.0-deb-1nodesource1 arm64 [upgradable from: 14.18.1-deb-1nodesource1]
openssl/oldstable,oldstable 1.1.1d-0+deb10u7 arm64 [upgradable from: 1.1.1d-0+deb10u3]
perl-base/oldstable 5.28.1-6+deb10u1 arm64 [upgradable from: 5.28.1-6]
perl-modules-5.28/oldstable 5.28.1-6+deb10u1 all [upgradable from: 5.28.1-6]
perl/oldstable 5.28.1-6+deb10u1 arm64 [upgradable from: 5.28.1-6]
php7.3-cli/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-common/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-curl/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-dev/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-gd/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-imap/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-json/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-ldap/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-mbstring/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-mysql/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-opcache/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-readline/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-soap/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-xml/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-xmlrpc/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3-zip/oldstable 7.3.31-1~deb10u1 arm64 [upgradable from: 7.3.19-1~deb10u1]
php7.3/oldstable 7.3.31-1~deb10u1 all [upgradable from: 7.3.19-1~deb10u1]
policykit-1/oldstable 0.105-25+deb10u1 arm64 [upgradable from: 0.105-25]
psmisc/oldstable 23.2-1+deb10u1 arm64 [upgradable from: 23.2-1]
python-apt-common/oldstable,oldstable 1.8.4.3 all [upgradable from: 1.8.4.1]
python3-apt/oldstable,oldstable 1.8.4.3 arm64 [upgradable from: 1.8.4.1]
samba-common/oldstable 2:4.9.5+dfsg-5+deb10u3 all [upgradable from: 2:4.9.5+dfsg-5+deb10u1]
samba-libs/oldstable 2:4.9.5+dfsg-5+deb10u3 arm64 [upgradable from: 2:4.9.5+dfsg-5+deb10u1]
setup-odroid/unknown 0.0.1-68 all [upgradable from: 0.0.1-55]
sudo/oldstable,oldstable 1.8.27-1+deb10u3 arm64 [upgradable from: 1.8.27-1+deb10u2]
systemd-sysv/oldstable,oldstable 241-7~deb10u8 arm64 [upgradable from: 241-7~deb10u4]
tzdata/oldstable-updates 2021a-0+deb10u3 all [upgradable from: 2020a-0+deb10u1]
wpasupplicant/oldstable,oldstable 2:2.7+git20190128+0c1e29f-6+deb10u3 arm64 [upgradable from: 2:2.7+git20190128+0c1e29f-6+deb10u2]
xserver-common/oldstable 2:1.20.4-1+deb10u4 all [upgradable from: 2:1.20.4-1]
xvfb/oldstable 2:1.20.4-1+deb10u4 arm64 [upgradable from: 2:1.20.4-1]
