Depuis la mise à jour, le démon ne fonctionne plus. La seule façon de le faire fonctionner normalement est de le réinstaller.
De plus, il ne me laisse pas installer les dépendances et ne me donne pas beaucoup plus d’informations.
Merci beaucoup pour votre aide.
WebapiError: [object Object]
at _toError (/var/www/html/plugins/spotify/ressources/node_modules/spotify-web-api-node/src/http-manager.js:47:10)
at /var/www/html/plugins/spotify/ressources/node_modules/spotify-web-api-node/src/http-manager.js:71:25
at Request.callback (/var/www/html/plugins/spotify/ressources/node_modules/superagent/lib/node/index.js:905:3)
at IncomingMessage.<anonymous> (/var/www/html/plugins/spotify/ressources/node_modules/superagent/lib/node/index.js:1127:20)
at Stream.emit (node:events:390:28)
at Unzip.<anonymous> (/var/www/html/plugins/spotify/ressources/node_modules/superagent/lib/node/unzip.js:53:12)
at Unzip.emit (node:events:390:28)
at endReadableNT (node:internal/streams/readable:1343:12)
at processTicksAndRejections (node:internal/process/task_queues:83:21) {
body: {},
headers: {
'cache-control': 'private, max-age=0',
'retry-after': '9649',
'access-control-allow-origin': '*',
'access-control-allow-headers': 'Accept, App-Platform, Authorization, Content-Type, Origin, Retry-After, Spotify-App-Version, X-Cloud-Trace-Context, client-token, content-access-token',
'access-control-allow-methods': 'GET, POST, OPTIONS, PUT, DELETE, PATCH',
'access-control-allow-credentials': 'true',
'access-control-max-age': '604800',
'content-encoding': 'gzip',
'strict-transport-security': 'max-age=31536000',
'x-content-type-options': 'nosniff',
date: 'Mon, 27 Sep 2021 05:35:05 GMT',
server: 'envoy',
via: 'HTTP/2 edgeproxy, 1.1 google',
'alt-svc': 'clear',
connection: 'close',
'transfer-encoding': 'chunked'
statusCode: 429
[2021-09-27 07:48:07][DEBUG] : --- DEPENDANCY INFO ---
[2021-09-27 07:48:07][DEBUG] : --- DEPENDANCY INSTALL ---
[2021-09-27 07:48:11][DEBUG] : --- DEPENDANCY INFO ---
[2021-09-27 07:48:12][DEBUG] : --- DEPENDANCY INFO ---
[2021-09-27 07:48:16][DEBUG] : --- DEPENDANCY INFO ---
[2021-09-27 07:48:17][DEBUG] : --- DEPENDANCY INFO ---
