Je viens d’installer une carte reseau dans mon APC 750 XL.
J’ai donc modifier le fichier apcupsd.conf avec l’ip de mon ups
# NISIP <dotted notation ip address>
# IP address on which NIS server will listen for incoming connections.
# This is useful if your server is multi-homed (has more than one
# network interface and IP address). Default value is 0.0.0.0 which
# means any incoming request will be serviced. Alternatively, you can
# configure this setting to any specific IP address of your server and
# NIS will listen for connections only on that interface. Use the
# loopback address (127.0.0.1) to accept connections only from the
# local machine.
NISIP 192.168.0.211
# NISPORT <port> default is 3551 as registered with the IANA
# port to use for sending STATUS and EVENTS data over the network.
# It is not used unless NETSERVER is on. If you change this port,
# you will need to change the corresponding value in the cgi directory
# and rebuild the cgi programs.
NISPORT 3551
Dans le fichier d’apccontrol j’ai bien la ligne avec mon API Key
#!/bin/sh
# Copyright (C) 1999-2002 Riccardo Facchetti <riccardo@master.oasi.gpa.it>
# for apcupsd release 3.14.12 (29 March 2014) - debian
# platforms/apccontrol. Generated from apccontrol.in by configure.
# Note, this is a generic file that can be used by most
# systems. If a particular system needs to have something
# special, start with this file, and put a copy in the
# platform subdirectory.
# These variables are needed for set up the autoconf other variables.
wget --no-check-certificate -qO- "http://127.0.0.1:80/core/api/jeeApi.php?api=__MON_API__&messagetype=saveEvent&type=apcups&hostname=127.0.0.1&event=$1"
prefix=/usr
exec_prefix=${prefix}
APCPID=/var/run/apcupsd.pid
APCUPSD=/sbin/apcupsd
SHUTDOWN=/sbin/shutdown
SCRIPTSHELL=/bin/sh
SCRIPTDIR=/etc/apcupsd
WALL=wall
Mais je n’ai aucune remontée sur mon équipement
Voici ce que me remonte les logs APC
2019-11-03 23:00:11][DEBUG] : => apply outpower case
[2019-11-03 23:00:11][DEBUG] : => update command outpower with 0
[2019-11-03 23:00:11][DEBUG] : Update command status
[2019-11-03 23:00:11][DEBUG] : => apply default case
[2019-11-03 23:00:11][DEBUG] : => update command status with 0
[2019-11-03 23:00:11][DEBUG] : Update command timeleft
[2019-11-03 23:00:11][DEBUG] : => update command timeleft with 0
[2019-11-03 23:00:11][DEBUG] : Update command battv
[2019-11-03 23:00:11][DEBUG] : => update command battv with 0
[2019-11-03 23:00:12][DEBUG] : Get information string Terminating due to configuration file errors. from apcaccess
[2019-11-03 23:00:12][DEBUG] : The information row Terminating due to configuration file errors. is not parsable
[2019-11-03 23:00:12][DEBUG] : Update command bcharge
[2019-11-03 23:00:12][DEBUG] : => apply default case
[2019-11-03 23:00:12][DEBUG] : => update battery status
[2019-11-03 23:00:12][DEBUG] : => update command bcharge with
[2019-11-03 23:00:12][DEBUG] : Update command timeleft
Merci d’avance pour vos infos.
