suite à la mise à jour du plugin, les dépendances n’arrivent pas à s’installer.
voici le log kroomba_update:
== 16/02/2024 08:45:30 == Dependencies installation for kroomba
[ 5% ] : Clean apt...
[ 9% ] : Clean apt : [ OK ]
[ 10% ] : Update apt...
[ 19% ] : Update apt : [ OK ]
[ 20% ] : Install apt packages...
[ 39% ] : Install apt packages : [ OK ]
[ 40% ] : Creating python 3 virtual environment...
[ 49% ] : Creating python 3 virtual environment : [ OK ]
[ 50% ] : Setting up virtual environment...
[ 69% ] : Setting up virtual environment : [ OK ]
[ 70% ] : Install the required python packages...
[ 99% ] : Install the required python packages : ERROR
[100% ] : Finished !
== KO == Installation Error
== ANALYSING ERRORS...
== NO KNOWN ERROR DETECTED
== Error in step : Install the required python packages
== Line 158
== Command `/var/www/html/plugins/kroomba/resources/venv/bin/python3 -m pip install --no-cache-dir -r requirements.txt' have an issue
== Return code is 1
== Error message :
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting requests>=2.25.1 (from -r requirements.txt (line 1))
Downloading https://www.piwheels.org/simple/requests/requests-2.31.0-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 535.8 kB/s eta 0:00:00
Collecting paho-mqtt>=2.0.0 (from -r requirements.txt (line 2))
Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-2.0.0-py3-none-any.whl (66 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 66.9/66.9 kB 642.2 kB/s eta 0:00:00
ERROR: Ignored the following yanked versions: 3.8.2, 4.0.0a0, 4.0.0a1
ERROR: Ignored the following versions that require a different python version: 3.9.0 Requires-Python >=3.8; 3.9.0b0 Requires-Python >=3.8; 3.9.0b1 Requires-Python >=3.8; 3.9.0rc0 Requires-Python >=3.8; 3.9.1 Requires-Python >=3.8; 3.9.2 Requires-Python >=3.8; 3.9.3 Requires-Python >=3.8
ERROR: Could not find a version that satisfies the requirement aiohttp>=3.9.1 (from versions: 0.1, 0.2, 0.3, 0.4, 0.4.1, 0.4.2, 0.4.3, 0.4.4, 0.5.0, 0.6.0, 0.6.1, 0.6.2, 0.6.3, 0.6.4, 0.6.5, 0.7.0, 0.7.1, 0.7.2, 0.7.3, 0.8.0, 0.8.1, 0.8.2, 0.8.3, 0.8.4, 0.9.0, 0.9.1, 0.9.2, 0.9.3, 0.10.0, 0.10.1, 0.10.2, 0.11.0, 0.12.0, 0.13.0, 0.13.1, 0.14.0, 0.14.1, 0.14.2, 0.14.3, 0.14.4, 0.15.0, 0.15.1, 0.15.2, 0.15.3, 0.16.0, 0.16.1, 0.16.2, 0.16.3, 0.16.4, 0.16.5, 0.16.6, 0.17.0, 0.17.1, 0.17.2, 0.17.3, 0.17.4, 0.18.0, 0.18.1, 0.18.2, 0.18.3, 0.18.4, 0.19.0, 0.20.0, 0.20.1, 0.20.2, 0.21.0, 0.21.1, 0.21.2, 0.21.4, 0.21.5, 0.21.6, 0.22.0a0, 0.22.0b0, 0.22.0b1, 0.22.0b2, 0.22.0b3, 0.22.0b4, 0.22.0b5, 0.22.0b6, 0.22.0, 0.22.1, 0.22.2, 0.22.3, 0.22.4, 0.22.5, 1.0.0, 1.0.1, 1.0.2, 1.0.3, 1.0.5, 1.1.0, 1.1.1, 1.1.2, 1.1.3, 1.1.4, 1.1.5, 1.1.6, 1.2.0, 1.3.0, 1.3.1, 1.3.2, 1.3.3, 1.3.4, 1.3.5, 2.0.0rc1, 2.0.0, 2.0.1, 2.0.2, 2.0.3, 2.0.4, 2.0.5, 2.0.6.post1, 2.0.7, 2.1.0, 2.2.0, 2.2.1, 2.2.2, 2.2.3, 2.2.4, 2.2.5, 2.3.0a4, 2.3.0, 2.3.1, 2.3.2b2, 2.3.2b3, 2.3.2, 2.3.3, 2.3.4, 2.3.5, 2.3.6, 2.3.7, 2.3.8, 2.3.9, 2.3.10, 3.0.0b0, 3.0.0b1, 3.0.0b2, 3.0.0b3, 3.0.0b4, 3.0.0, 3.0.1, 3.0.2, 3.0.3, 3.0.4, 3.0.5, 3.0.6, 3.0.7, 3.0.8, 3.0.9, 3.1.0, 3.1.1, 3.1.2, 3.1.3, 3.2.0, 3.2.1, 3.3.0a0, 3.3.0, 3.3.1, 3.3.2a0, 3.3.2, 3.4.0a0, 3.4.0a3, 3.4.0b1, 3.4.0b2, 3.4.0, 3.4.1, 3.4.2, 3.4.3, 3.4.4, 3.5.0a1, 3.5.0b1, 3.5.0b2, 3.5.0b3, 3.5.0, 3.5.1, 3.5.2, 3.5.3, 3.5.4, 3.6.0a0, 3.6.0a1, 3.6.0a2, 3.6.0a3, 3.6.0a4, 3.6.0a5, 3.6.0a6, 3.6.0a7, 3.6.0a8, 3.6.0a9, 3.6.0a11, 3.6.0a12, 3.6.0b0, 3.6.0, 3.6.1b3, 3.6.1b4, 3.6.1, 3.6.2a0, 3.6.2a1, 3.6.2a2, 3.6.2, 3.6.3, 3.7.0b0, 3.7.0b1, 3.7.0, 3.7.1, 3.7.2, 3.7.3, 3.7.4, 3.7.4.post0, 3.8.0a7, 3.8.0b0, 3.8.0, 3.8.1, 3.8.3, 3.8.4, 3.8.5, 3.8.6)
ERROR: No matching distribution found for aiohttp>=3.9.1
voici la page santé:
Merci d’avance.
