Suite au passage sous Debian 10 qui m’a basculé en PHP '7.3 j’ai ces lignes dans le log ‹ cron execution › (près de 40 ko à l’heure !!! ).
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/asuswrt/core/class/asuswrt.class.php on line 134
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/asuswrt/core/class/asuswrt.class.php on line 138
Jeedom est en 4.1.15, AssusWRT du ‹ 2020-10-19 01:07:05 ›
EDIT 1 :
J’ai trouvé une solution, il suffit de faire un intval sur ‹ $result[‹ rxtotal ›] ›
Une fois fait sur les deux lignes, plus de soucis
bonjour comment tu a fait svp, car j’ai le même problème
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1217
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1085
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1090
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1094
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1095
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1164
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1166
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1167
PHP Warning: Invalid argument supplied for foreach() in /var/www/html/plugins/octoprint/core/class/octoprint.class.php on line 46
PHP Warning: Invalid argument supplied for foreach() in /var/www/html/plugins/octoprint/core/class/octoprint.class.php on line 82
PHP Warning: stream_set_blocking() expects parameter 1 to be resource, string given in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 662
PHP Warning: stream_get_contents() expects parameter 1 to be resource, string given in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 663
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1097
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1210
PHP Notice: A non well formed numeric value encountered in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1213
PHP Notice: Undefined variable: hddtotal in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1274
PHP Notice: Undefined variable: hddused in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1275
PHP Notice: Undefined variable: hddpourcused in /var/www/html/plugins/Monitoring/core/class/Monitoring.class.php on line 1276
