Depuis que j’ai refais mon installation, je n’arrive pas à inclure mon module de température Xiaomi Mijia. Je n’avais pas eu de souci avant (modèle https://projetsdiy.fr/deal-sonde-temperature-humidite-sht30-xiaomi-mi-smart-home-promo).
Dans le réseau, il est détecté, mais ne reconnait pas son modèle et a comme status « Découverte des endpoints OK ».
Dans les logs j’ai :
[2021-06-17 01:41:38][DEBUG] : {"device_removed":"00:15:8d:00:02:08:fa:ca"}
[2021-06-18 00:36:39][DEBUG] : {"device_joined":"00:15:8d:00:02:08:fa:ca"}
[2021-06-18 00:39:41][DEBUG] : [{"ieee":"cc:cc:cc:ff:fe:a5:f0:a6","nwk":"0x0000","lqi":255,"rssi":0,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[{"ieee":"00:15:8d:00:06:be:c0:58","nwk":"0x05a0","lqi":186,"rssi":-60,"pan_id":"ef:1a:c0:74:a0:6d:6e:24","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.sensor_magnet.aq2","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:06:c0:4a:b6","nwk":"0xaf0c","lqi":206,"rssi":-47,"pan_id":"ef:1a:c0:74:a0:6d:6e:24","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.sensor_magnet.aq2","manufacturer":"LUMI","offline":false,"supported":true}]},{"ieee":"00:15:8d:00:06:c0:4a:b6","nwk":"0xaf0c","lqi":212,"rssi":-47,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:be:c0:58","nwk":"0x05a0","lqi":160,"rssi":-60,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:be:c5:b7","nwk":"0xe8fe","lqi":176,"rssi":-56,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:06:be:bf:6e","nwk":"0xac8d","lqi":160,"rssi":-60,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.sensor_magnet.aq2","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:02:c9:fd:9c","nwk":"0x2578","lqi":184,"rssi":-54,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:02:08:fa:ca","nwk":"0xdd81","lqi":164,"rssi":-59,"device_type":"EndDevice","manufacturer":null,"model":null,"offline":false,"neighbours":[]},{"ieee":"00:12:4b:00:22:eb:fd:0d","nwk":"0x0720","lqi":220,"rssi":-45,"device_type":"EndDevice","manufacturer":"eWeLink","model":"TH01","offline":false,"neighbours":[]}]
[2021-06-18 00:39:41][DEBUG] : [{"ieee":"cc:cc:cc:ff:fe:a5:f0:a6","nwk":0,"status":2,"lqi":"255","rssi":"0","last_seen":"1623969461.111431","node_descriptor":"00:40:8f:cd:ab:52:80:00:41:2c:80:00:00","endpoints":[{"id":1,"status":1,"device_type":48879,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[],"input_clusters":[]},{"id":242,"status":1,"device_type":41440,"profile_id":260,"manufacturer":null,"model":null
Même souci sur un Aquara, pourtant j’en ai d’autres qui n’ont pas de souci. J’ai essayé pleins de fois des supprimer, des les inclures, dans les options de faire reset…etc, rien n’y fait, ça ne passe pas
Une idée du souci ?
