[2021-12-16 19:20:09][DEBUG] : executing functools.partial(<built-in method close of sqlite3.Cursor object at 0x73b40ea0>)
[2021-12-16 19:20:09][DEBUG] : operation functools.partial(<built-in method close of sqlite3.Cursor object at 0x73b40ea0>) completed
[2021-12-16 19:20:09][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x73ba38a0>, 'SELECT * FROM unsupported_attributes_v7', [])
[2021-12-16 19:20:09][DEBUG] : returning exception no such table: unsupported_attributes_v7
[2021-12-16 19:20:09][ERROR] : [start_zigbee] Fatal error : no such table: unsupported_attributes_v7
[2021-12-16 19:20:09][INFO] : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py", line 102, in start_zigbee
start_radio=True,
File "/usr/local/lib/python3.7/dist-packages/zigpy/application.py", line 61, in new
await app._load_db()
File "/usr/local/lib/python3.7/dist-packages/zigpy/application.py", line 53, in _load_db
await self._dblistener.load()
File "/usr/local/lib/python3.7/dist-packages/zigpy/appdb.py", line 387, in load
await self._load_unsupported_attributes()
File "/usr/local/lib/python3.7/dist-packages/zigpy/appdb.py", line 434, in _load_unsupported_attributes
f"SELECT * FROM unsupported_attributes{DB_V}"
File "/usr/local/lib/python3.7/dist-packages/aiosqlite/context.py", line 41, in __aenter__
self._obj = await self._coro
File "/usr/local/lib/python3.7/dist-packages/aiosqlite/core.py", line 184, in execute
cursor = await self._execute(self._conn.execute, sql, parameters)
File "/usr/local/lib/python3.7/dist-packages/aiosqlite/core.py", line 129, in _execute
return await future
File "/usr/local/lib/python3.7/dist-packages/aiosqlite/core.py", line 102, in run
result = function()
sqlite3.OperationalError: no such table: unsupported_attributes_v7
[2021-12-16 19:20:09][INFO] : Shutdown
[2021-12-16 19:20:09][INFO] : Removing PID file /tmp/jeedom/zigbee/deamon_1.pid
[2021-12-16 19:20:09][INFO] : Exit 0
Tout d’abord bonsoir ou bonjour à votre choix, (c’est un minimum avant de poser une question)
Cela ne veux rien dire, aucune info sur votre version de Jeedom, votre version d’OS, de quelle manière vous avez installé Jeedom, pas de copie a minima de la page santé serait utile donc je vous invite à lire le sujet suivant afin de nous apporter les informations manquantes.
Bonsoir iPapy,
Désolé pour le manque d’informations, ayant renseigné toutes ces infos lors de mon inscription, je pensais qu’elles étaient disponibles.
Il semble que ce ne soit pas le cas, les voilà donc :
Merci cstan pour ton aide.
Le port (USB) est OK, contrôlé avec :
pour le port (TCP), initialement, c’était 8089, mais sans plus de succès.
Les différentes pages d’aide proposaient de le changer, je l’ai donc fait.
Cette erreur semble récurrente (au moins deux sujets du même type sans réponse) mais un conseil proposait de poster un nouveau sujet.
La clé popp est en direct sur le pi avec une clé USB et l’antenne rfxcom…
j’ai essayé de mettre le port sur auto, sans succès (ma première tentative en fait).
Oula cela fait beaucoup de choses pour l’alim du Pi, je vous conseille d’utiliser un Hub USB muni d’une alimentation afin de décharger celle du Pi, vous en trouverez un pas très cher sur l site de Domadoo qui est recommandé pour Jeedom, je l’utilise personnellement, ma popp plantait régulièrement avant mais depuis quelle est sur ce hub je n’ai plus aucun souci.
J’ai commandé un hub USB alimenté.
Celà dit, le démon ne démarre pas du tout alors que le device est reconnu par le système.
Ou plutôt, il démarre puis « tombe » au bout d’une à deux secondes.
une fois le démon tombé, le device est toujours reconnu.
Je pense que le hub USB assurera la fiabilité de l’usage de la clé Popp, mais celà ne résout pas le souci du démon qui ne démarre pas
C’est le symptôme que j’avais au départ, après avoir tout enlevé ce que j’avais en usb sauf la clé popp cela démarrait bien mais au bout de 48h plus rien n’était reconnu alors que le demon était toujours au vert, j’ai ensuite mis cette clé sur une petite rallonge pour éviter les interférences et pas mieux, plus rien au bout de 48h, j’ai fini par acheter un hub (celui de Domadoo) et depuis plus de souci, d’où mon conseil.
