bonjour,
je refais un post car plus de reponse sur l ancien .
pi4b SSD et clé sonoff Z
plugin zigbeelinker
impossible de lancer le demon qui decroche en 1min et s arrete
voici le log
Zigbee2MQTT:error 2024-04-08 06:18:06: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-04-08 06:18:06: Failed to start zigbee
Zigbee2MQTT:error 2024-04-08 06:18:06: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2024-04-08 06:18:06: Exiting…
Zigbee2MQTT:error 2024-04-08 06:18:06: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
at ZnpAdapterManager.beginCommissioning (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:347:23)
at ZnpAdapterManager.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:92:17)
at Controller.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:62:27)
at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:109:27)
at start (/opt/zigbee2mqtt/index.js:107:5
