j’en ai deux depuis décembre. Intégration ok et fonctionnement Impeccable.
Si cela peut aider, voici les commandes issues de l’intégration via Z2M et les informations brutes
"date_code": "20240524",
"definition": {
"description": "Zigbee water sensor",
"exposes": [
"access": 5,
"category": "diagnostic",
"description": "Remaining battery in %",
"label": "Battery",
"name": "battery",
"property": "battery",
"type": "numeric",
"unit": "%",
"value_max": 100,
"value_min": 0
"access": 1,
"description": "Indicates whether the device detected a water leak",
"label": "Water leak",
"name": "water_leak",
"property": "water_leak",
"type": "binary",
"value_off": false,
"value_on": true
"access": 1,
"description": "Indicates whether the battery of the device is almost empty",
"label": "Battery low",
"name": "battery_low",
"property": "battery_low",
"type": "binary",
"value_off": false,
"value_on": true
"access": 1,
"description": "Link quality (signal strength)",
"label": "Linkquality",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "SNZB-05P",
"options": [],
"supports_ota": false,
"vendor": "SONOFF"
"disabled": false,
"endpoints": {
"1": {
"bindings": [
"cluster": "genPollCtrl",
"target": {
"endpoint": 1,
"ieee_address": "0x70c59cfffe61536e",
"type": "endpoint"
"cluster": "genPowerCfg",
"target": {
"endpoint": 1,
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genPowerCfg",
"genIdentify",
"genPollCtrl",
"ssIasZone",
"manuSpecificAmazonWWAH"
"output": [
"genIdentify",
"genOta"
"configured_reportings": [
"attribute": "batteryPercentageRemaining",
"maximum_report_interval": 65000,
"minimum_report_interval": 3600,
"reportable_change": 10
"scenes": []
"friendly_name": "0x44e2f8fffe1a6e67",
"ieee_address": "0x44e2f8fffe1a6e67",
"interview_completed": true,
"interviewing": false,
"manufacturer": "SONOFF",
"model_id": "SNZB-05P",
"network_address": 15492,
"power_source": "Battery",
"software_build_id": "1.0.2",
"supported": true,
"type": "EndDevice"
