Bonjour, J’ai un problème sur le plugin jeezigbee, j’ai installé des modules d’arrosage Sonoff et les commandes numériques ne fonctionnent pas.
[2025-06-17 14:30:31] e[31merrore[39m: z2m: Publish 'set' 'cyclic_quantitative_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20489":{"value":[10,0,null,0,0,0,null,0,0,0,100],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:31:11] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:31:11.318Z","linkquality":51,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:11] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:31:11.318Z","linkquality":51,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:11] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:31:11.330Z","linkquality":48,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:11] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:31:11.333Z","linkquality":51,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:13] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:31:13.802Z","linkquality":36,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:16] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:31:16.377Z","linkquality":33,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:16] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:31:16.378Z","linkquality":36,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:16] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:31:16.383Z","linkquality":33,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:16] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:31:16.859Z","linkquality":36,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:31:18] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:31:18.899Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:32:10] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:32:10.269Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:32:43] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:32:43.194Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:32:43] e[31merrore[39m: z2m: Publish 'set' 'cyclic_quantitative_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20489":{"value":[10,0,null,0,0,6,1671,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:32:52] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:32:52.182Z","linkquality":45,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:32:52] e[31merrore[39m: z2m: Publish 'set' 'cyclic_quantitative_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20489":{"value":[10,0,33,0,0,0,null,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:32:54] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:32:54.207Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:32:54] e[31merrore[39m: z2m: Publish 'set' 'cyclic_timed_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20488":{"value":[10,0,null,0,0,178,45669,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:33:33] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:33:33.580Z","linkquality":51,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:33:33] e[31merrore[39m: z2m: Publish 'set' 'cyclic_timed_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20488":{"value":[10,0,null,0,0,0,null,0,0,120,30857],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:33:34] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:33:34.596Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:33:34] e[31merrore[39m: z2m: Publish 'set' 'cyclic_quantitative_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20489":{"value":[10,0,null,0,0,0,null,0,0,96,24686],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:33:42] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:33:42.160Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:33:42] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:33:42.162Z","linkquality":48,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:33:42] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:33:42.166Z","linkquality":48,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:33:44] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:33:44.628Z","linkquality":33,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:33:49] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:33:49.631Z","linkquality":33,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:33:49] e[31merrore[39m: z2m: Publish 'set' 'cyclic_timed_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20488":{"value":[10,0,19,0,0,0,null,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:34:02] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:34:02.595Z","linkquality":33,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:34:16] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:34:16.569Z","linkquality":33,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:34:23] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:34:23.601Z","linkquality":33,"state":"ON","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:34:23] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:34:23.603Z","linkquality":33,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:34:23] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0.1,"last_seen":"2025-06-17T12:34:23.607Z","linkquality":33,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:34:24] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:34:24.093Z","linkquality":39,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:34:43] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:34:43.047Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:34:43] e[31merrore[39m: z2m: Publish 'set' 'cyclic_timed_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20488":{"value":[10,0,43,0,0,0,null,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:35:41] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:35:41.903Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:35:41] e[31merrore[39m: z2m: Publish 'set' 'cyclic_quantitative_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20489":{"value":[10,0,49,0,0,0,null,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:35:42] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:35:42.917Z","linkquality":45,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:35:42] e[31merrore[39m: z2m: Publish 'set' 'cyclic_quantitative_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20489":{"value":[10,0,null,0,0,13,3342,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:35:44] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:35:44.409Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:35:44] e[31merrore[39m: z2m: Publish 'set' 'cyclic_timed_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20488":{"value":[10,0,null,0,0,231,59246,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:35:46] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:35:46.404Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:35:46] e[31merrore[39m: z2m: Publish 'set' 'cyclic_quantitative_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20489":{"value":[10,0,null,0,0,0,null,0,0,154,39497],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:35:48] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:35:48.401Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:35:48] e[31merrore[39m: z2m: Publish 'set' 'cyclic_timed_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20488":{"value":[10,0,null,0,0,0,null,0,0,188,48137],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
[2025-06-17 14:35:49] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf4b3b1fffe5220c5', payload '{"auto_close_when_water_shortage":"DISABLE","battery":100,"current_device_status":"normal_state","device":{"applicationVersion":16,"dateCode":"20240705","friendlyName":"0xf4b3b1fffe5220c5","hardwareVersion":16,"ieeeAddr":"0xf4b3b1fffe5220c5","manufacturerID":4742,"manufacturerName":"SONOFF","model":"SWV","networkAddress":13437,"powerSource":"Battery","softwareBuildID":"1.0.3","type":"EndDevice","zclVersion":8},"flow":0,"last_seen":"2025-06-17T12:35:49.895Z","linkquality":48,"state":"OFF","update":{"installed_version":4099,"latest_version":4100,"state":"available"}}'
[2025-06-17 14:35:49] e[31merrore[39m: z2m: Publish 'set' 'cyclic_timed_irrigation' to '0xf4b3b1fffe5220c5' failed: 'Error: ZCL command 0xf4b3b1fffe5220c5/1 customClusterEwelink.write({"20488":{"value":[10,0,79,0,0,0,null,0,0,0,null],"type":66}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'INVALID_VALUE')'
Je suis sur une clé zigbee sonoff 3.0. J’ai uniquement la commande de marche/arret qui fonctionne, le retour du débit d’eau egalement.
Je vous remercie par avance
