Je cherche à faire fonctionner un scénario avec mon bouton Heiman. l’appairage Zigbee c’est fait parfaitement. et je reçois bien les évènements à chaque appuis :
[2022-03-01 12:41:04][DEBUG][zigate](ZiGate-Decode data) : Received response 0x8401: b'4101050002dcbe800000520000'
[2022-03-01 12:41:04][DEBUG][zigate](ZiGate-Decode data) : RESPONSE 0x8401 - IAS Zone Status Change : sequence:65, endpoint:1, cluster:1280, address_mode:2, addr:dcbe, zone_status:1000000000000000, status:0, zone_id:82, delay:0, lqi:165
[2022-03-01 12:41:04][DEBUG][zigate](ZiGate-Decode data) : Acquire Lock on device HEIMAN DoorBell-EM (dcbe) 000d6f00161f6918
[2022-03-01 12:41:04][DEBUG][zigate](ZiGate-Decode data) : Release Lock on device HEIMAN DoorBell-EM (dcbe) 000d6f00161f6918
[2022-03-01 12:41:04][DEBUG][root](ZiGate-Decode data) : External command ZIGATE_ATTRIBUTE_UPDATED : {'zigate': <zigate.core.ZiGate object at 0x7f2b4f34c400>, 'device': HEIMAN DoorBell-EM (dcbe) 000d6f00161f6918, 'attribute': {'endpoint': 1, 'cluster': 1280, 'addr': 'dcbe', 'attribute': 82, 'data': '1000000000000000', 'name': 'zone_status', 'value': {'alarm1': False, 'alarm2': False, 'tamper': False, 'low_battery': False, 'supervision': False, 'restore': False, 'trouble': False, 'ac_fault': False, 'test_mode': False, 'battery_defect': False}, 'type': <class 'dict'>, 'expire': 10, 'expire_value': {'alarm1': False, 'alarm2': False, 'tamper': False, 'low_battery': False, 'supervision': False, 'restore': False, 'trouble': False, 'ac_fault': False, 'test_mode': False, 'battery_defect': False}}}
[2022-03-01 12:41:05][DEBUG][root](Thread-1) : Send to jeedom : {'action': 'ZIGATE_ATTRIBUTE_UPDATED', 'device': HEIMAN DoorBell-EM (dcbe) 000d6f00161f6918, 'attribute': {'endpoint': 1, 'cluster': 1280, 'addr': 'dcbe', 'attribute': 82, 'data': '1000000000000000', 'name': 'zone_status', 'value': {'alarm1': False, 'alarm2': False, 'tamper': False, 'low_battery': False, 'supervision': False, 'restore': False, 'trouble': False, 'ac_fault': False, 'test_mode': False, 'battery_defect': False}, 'type': <class 'dict'>, 'expire': 10, 'expire_value': {'alarm1': False, 'alarm2': False, 'tamper': False, 'low_battery': False, 'supervision': False, 'restore': False, 'trouble': False, 'ac_fault': False, 'test_mode': False, 'battery_defect': False}}}
[2022-03-01 12:41:05][DEBUG] : Array ( [action] => ZIGATE_ATTRIBUTE_UPDATED [device] => Array ( [addr] => dcbe [info] => Array ( [addr] => dcbe [ieee] => 000d6f00161f6918 [mac_capability] => 10000000 [rejoin_status] => [lqi] => 165 [last_seen] => 2022-03-01 12:41:04 [manufacturer_code] => 120b [max_rx] => 82 [max_tx] => 82 [server_mask] => 11264 [descriptor_capability] => 00000000 [max_buffer] => 82 [bit_field] => 0100000000000010 ) [endpoints] => Array ( [0] => Array ( [endpoint] => 1 [clusters] => Array ( [0] => Array ( [cluster] => 1280 [attributes] => Array ( [0] => Array ( [attribute] => 82 [data] => 1000000000000000 [name] => zone_status [value] => Array ( [alarm1] => [alarm2] => [tamper] => [low_battery] => [supervision] => [restore] => [trouble] => [ac_fault] => [test_mode] => [battery_defect] => ) [type] => dict [expire] => 10 [expire_value] => Array ( [alarm1] => [alarm2] => [tamper] => [low_battery] => [supervision] => [restore] => [trouble] => [ac_fault] => [test_mode] => [battery_defect] => ) ) ) ) [1] => Array ( [cluster] => 0 [attributes] => Array ( [0] => Array ( [attribute] => 4 [data] => HEIMAN [name] => manufacturer [value] => HEIMAN ) [1] => Array ( [attribute] => 5 [data] => DoorBell-EM [name] => type [value] => DoorBell-EM [type] => str ) ) ) [2] => Array ( [cluster] => 1 [attributes] => Array ( [0] => Array ( [attribute] => 33 [data] => 181 [name] => battery_percent [value] => 181 [type] => int ) [1] => Array ( [attribute] => 32 [data] => 30 [name] => battery_voltage [value] => 3 [type] => float ) ) ) ) [profile] => 0 [device] => 0 [in_clusters] => Array ( ) [out_clusters] => Array ( ) ) ) [generictype] => [discovery] => auto-discovered [name] => ) [attribute] => Array ( [endpoint] => 1 [cluster] => 1280 [addr] => dcbe [attribute] => 82 [data] => 1000000000000000 [name] => zone_status [value] => Array ( [alarm1] => [alarm2] => [tamper] => [low_battery] => [supervision] => [restore] => [trouble] => [ac_fault] => [test_mode] => [battery_defect] => ) [type] => dict [expire] => 10 [expire_value] => Array ( [alarm1] => [alarm2] => [tamper] => [low_battery] => [supervision] => [restore] => [trouble] => [ac_fault] => [test_mode] => [battery_defect] => ) ) )
[2022-03-01 12:41:05][DEBUG][zigate](ZiGate-Decode data) : Received response 0x8012: b'00010102dcbe090701'
[2022-03-01 12:41:05][DEBUG][zigate](ZiGate-Decode data) : Received response 0x8011: b'00dcbe01050009'
[2022-03-01 12:41:05][DEBUG][zigate](ZiGate-Decode data) : RESPONSE 0x8011 - APS_DATA_ACK : status:0, addr:dcbe, endpoint:1, cluster:1280, additional:b' ', lqi:0
Cependant je n’arrive pas a configurer mon scénario pour qu’il ce déclenche lors de la réception des infos .
Mon scénario est pourtant configuré en « Provoqué » sur la sonnette je veux bien un peu d’aide svp
Franck
