Donc MAJ version 1048 sur RFXtrx433E
Mes TFA remonte toujours ! 600E et 400E
[2023-07-13 08:28:28][DEBUG] : Message: 0a520709600e00eb430150
[2023-07-13 08:28:28][DEBUG] : Decode : 0a520709600e00eb430150
[2023-07-13 08:28:28][DEBUG] : Test message: 0a520709600e00eb430150
[2023-07-13 08:28:28][DEBUG] : PacketType: 0x52
[2023-07-13 08:28:28][DEBUG] : Length: 11
[2023-07-13 08:28:28][DEBUG] : Start decoding packet type 0x52
[2023-07-13 08:28:28][DEBUG] : Subtype = TH7 is TFA TS34C/Cresta/Honeywell TS33C
[2023-07-13 08:28:28][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x07', 'seqnbr': '0x09', 'id1': '0x60', 'id2': '0x0E', 'temperaturesign': '', 'temperature': 235, 'humidity': 67, 'humidity_status': 1, 'battery': 10, 'rssi': 5}
[2023-07-13 08:28:28][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x07', 'id': '600E', 'temperature': '23.5', 'humidity': 67, 'humidity_status': 1, 'battery': 10, 'rssi': 5}
[2023-07-13 08:28:28][DEBUG] : Device is known id : 600E
[2023-07-13 08:28:28][DEBUG] : Send to jeedom : {'devices': {'600E52': {'packettype': '0x52', 'subtype': '0x07', 'id': '600E', 'temperature': '23.5', 'humidity': 67, 'humidity_status': 1, 'battery': 10, 'rssi': 5}}}
[2023-07-13 08:28:28][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2023-07-13 08:28:28][DEBUG] : {"devices":{"600E52":{"packettype":"0x52","subtype":"0x07","id":"600E","temperature":"23.5","humidity":67,"humidity_status":1,"battery":10,"rssi":5}}}
[2023-07-13 08:28:28][DEBUG] :********
[2023-07-13 08:28:31][DEBUG] : Message: 0a52010a320100f1410159
[2023-07-13 08:28:31][DEBUG] : Decode : 0a52010a320100f1410159
[2023-07-13 08:28:31][DEBUG] : Test message: 0a52010a320100f1410159
[2023-07-13 08:28:31][DEBUG] : PacketType: 0x52
[2023-07-13 08:28:31][DEBUG] : Length: 11
[2023-07-13 08:28:31][DEBUG] : Start decoding packet type 0x52
[2023-07-13 08:28:31][DEBUG] : Subtype = TH1 is THGN122/123, THGN132, THGR122/228/238/268
[2023-07-13 08:28:31][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x01', 'seqnbr': '0x0A', 'id1': '0x32', 'id2': '0x01', 'temperaturesign': '', 'temperature': 241, 'humidity': 65, 'humidity_status': 1, 'battery': 100, 'rssi': 5}
[2023-07-13 08:28:31][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x01', 'id': '3201', 'temperature': '24.1', 'humidity': 65, 'humidity_status': 1, 'battery': 100, 'rssi': 5}
[2023-07-13 08:28:31][DEBUG] : unknown device id : 3201
[2023-07-13 08:28:39][DEBUG] : Message: 135b010b0b0000000000000000000000001b9079
[2023-07-13 08:28:39][DEBUG] : Decode : 135b010b0b0000000000000000000000001b9079
[2023-07-13 08:28:39][DEBUG] : Test message: 135b010b0b0000000000000000000000001b9079
[2023-07-13 08:28:39][DEBUG] : PacketType: 0x5B
[2023-07-13 08:28:39][DEBUG] : Length: 20
[2023-07-13 08:28:39][DEBUG] : Start decoding packet type 0x5B
[2023-07-13 08:28:39][DEBUG] : Subtype = ELEC4 is CM180i
[2023-07-13 08:28:39][DEBUG] : Data : {'packetlen': '0x13', 'packettype': '0x5B', 'subtype': '0x01', 'seqnbr': '0x0B', 'id1': '0x0B', 'id2': '0x00', 'count': 0, 'ch1': 0, 'ch2': 0, 'ch3': 0, 'total': 7056, 'battery': 100, 'rssi': 7}
[2023-07-13 08:28:39][DEBUG] : Decoded info : {'packettype': '0x5B', 'subtype': '0x01', 'id': '0B00', 'count': 0, 'ch1': 0.0, 'ch2': 0.0, 'ch3': 0.0, 'total': 31.55, 'battery': 100, 'rssi': 7}
[2023-07-13 08:28:39][DEBUG] : unknown device id : 0B00
[2023-07-13 08:28:48][DEBUG] : Message: 0a520a0c490200e6420169
[2023-07-13 08:28:48][DEBUG] : Decode : 0a520a0c490200e6420169
[2023-07-13 08:28:48][DEBUG] : Test message: 0a520a0c490200e6420169
[2023-07-13 08:28:48][DEBUG] : PacketType: 0x52
[2023-07-13 08:28:48][DEBUG] : Length: 11
[2023-07-13 08:28:48][DEBUG] : Start decoding packet type 0x52
[2023-07-13 08:28:48][DEBUG] : Subtype = TH10 is Rubicson,IW008T,TX95,Xiron-EN6,WH5
[2023-07-13 08:28:48][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0A', 'seqnbr': '0x0C', 'id1': '0x49', 'id2': '0x02', 'temperaturesign': '', 'temperature': 230, 'humidity': 66, 'humidity_status': 1, 'battery': 100, 'rssi': 6}
[2023-07-13 08:28:48][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x0A', 'id': '4902', 'temperature': '23.0', 'humidity': 66, 'humidity_status': 1, 'battery': 100, 'rssi': 6}
[2023-07-13 08:28:48][DEBUG] : Device is known id : 4902
[2023-07-13 08:28:48][DEBUG] : Send to jeedom : {'devices': {'490252': {'packettype': '0x52', 'subtype': '0x0A', 'id': '4902', 'temperature': '23.0', 'humidity': 66, 'humidity_status': 1, 'battery': 100, 'rssi': 6}}}
[2023-07-13 08:28:48][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2023-07-13 08:28:48][DEBUG] : {"devices":{"490252":{"packettype":"0x52","subtype":"0x0A","id":"4902","temperature":"23.0","humidity":66,"humidity_status":1,"battery":100,"rssi":6}}}
[2023-07-13 08:28:48][DEBUG] : **********
[2023-07-13 08:28:56][DEBUG] : Message: 0a52070d400e8068370159
[2023-07-13 08:28:56][DEBUG] : Decode : 0a52070d400e8068370159
[2023-07-13 08:28:56][DEBUG] : Test message: 0a52070d400e8068370159
[2023-07-13 08:28:56][DEBUG] : PacketType: 0x52
[2023-07-13 08:28:56][DEBUG] : Length: 11
[2023-07-13 08:28:56][DEBUG] : Start decoding packet type 0x52
[2023-07-13 08:28:56][DEBUG] : Subtype = TH7 is TFA TS34C/Cresta/Honeywell TS33C
[2023-07-13 08:28:56][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x07', 'seqnbr': '0x0D', 'id1': '0x40', 'id2': '0x0E', 'temperaturesign': '-', 'temperature': 104, 'humidity': 55, 'humidity_status': 1, 'battery': 100, 'rssi': 5}
[2023-07-13 08:28:56][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x07', 'id': '400E', 'temperature': '-10.4', 'humidity': 55, 'humidity_status': 1, 'battery': 100, 'rssi': 5}
[2023-07-13 08:28:56][DEBUG] : Device is known id : 400E
[2023-07-13 08:28:56][DEBUG] : Send to jeedom : {'devices': {'400E52': {'packettype': '0x52', 'subtype': '0x07', 'id': '400E', 'temperature': '-10.4', 'humidity': 55, 'humidity_status': 1, 'battery': 100, 'rssi': 5}}}
Sur Rfxmngr
13/07/2023 08:24:32:569= 0A520700600E00EB430150
Packettype = TEMP_HUM
subtype = TH7 - Cresta, TFA TS34C
channel 3
Sequence nbr = 0
ID = 600E decimal:24590
Temperature = 23,5 °C
Humidity = 67
Status = Comfortable
Signal level = 5 -80dBm
Battery = Low
13/07/2023 08:25:11:047= 0A520704400E806A370159
channel 2
Sequence nbr = 4
ID = 400E decimal:16398
Temperature = -10,6 °C
Humidity = 55
Battery = OK
13/07/2023 08:25:19:926= 0A520705600E00EC430150
channel 3
Sequence nbr = 5
Temperature = 23,6 °C
Humidity = 67
Battery = Low
