J’ai un appareil qui ne veut pas fonctionner normalement, c’est une sonde de température et humidité avec un relais.
Mais je n’ai aucune remontée, même le ON/OFF ne fonctionne pas. Est-il possible de l’intégrer
? Merci de votre aide.
[11/12/2025 20:29:23] z2m: Publish 'get' 'state' to 'Sonde de température Extérieure' failed: 'Error: ZCL command 0xa4c138739ca6706e/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 46238 - 1 - 88 - 6 - 1 after 10000ms)'
[11/12/2025 20:31:08] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:08.209Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:09] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:08.982Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:09] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:09.182Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:10] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:09.591Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:10] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:09.786Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:10] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:09.995Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:11] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:10.382Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:11] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:10.786Z","linkquality":255,"state":"OFF"}'
[11/12/2025 20:31:12] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Sonde de température Extérieure', payload '{"device":{"applicationVersion":64,"dateCode":"","friendlyName":"Sonde de température Extérieure","hardwareVersion":1,"ieeeAddr":"0xa4c138739ca6706e","manufacturerID":4417,"manufacturerName":"_TZE21C_i2ij4rb3","model":"TS0001","networkAddress":46238,"powerSource":"Mains (single phase)","stackVersion":1,"type":"Router","zclVersion":3},"last_seen":"2025-12-11T19:31:11.382Z","linkquality":255,"state":"OFF"}'
