Somfy rts gateway
Hi
i am not skill in radio frequency
i would like to build a gateway between my homeautomation system (like jeedom) and my somfy technology Radio Somfy RTS 433,42 MHz (like blinds, shutter, etc).
i can manage my somfy RTS equipments with my remote control but it should be great to manage with my homeautomation system
What is the best choice to build such gateway ?
Do you have links for my to start ?
thanks in advance
There are different paths possible.
You may use the Tahoma Box I believe (not the option I’m using)
Or you may use a RF433 antenna which would emulate the remote control from Jeedom.
It would require something like that: Amazon Link
The downside of the second method (it is the one I’m using) is that Jeedom will not know the state of your shutters. You may add further sensors to be certain of the state.
In my use case, I don’t care much of the state as I have a 99% efficiency. The range is also rather impressive.
From there you may seek for more information.
