Bonjour à tous
J’essaye de connecter mon compte SmartLife sur le plugin #plugin-smartlife mais vraisembalblement ça ne marche pas.
je suis sur de mes ID .
J’ai lu de grosses mises à jours de la part de la plateforme Smartlife / Tuya en novembre.
Possibe que ça vienne de là ?
L’erreur est la suivante
Get accesstoken failed. Username or password error!
Les logs donnent pas bien plus d’infos… :
[2021-12-11 14:16:27][INFO] : CHECK CONNECTION : === BEGIN ===================================================
[2021-12-11 14:16:27][DEBUG] : NEW SESSION : XXXXXX@gmail.com (33) smart_life - 5 s
[2021-12-11 14:16:27][ERROR] : CHECK CONNECTION : Get accesstoken failed. Username or password error!
[2021-12-11 14:16:27][DEBUG] : CHECK CONNECTION : Exception Object ( [message:protected] => Get accesstoken failed. Username or password error! [string:Exception:private] => [code:protected] => 0 [file:protected] => /var/www/html/plugins/SmartLife/vendor/sabinus52/tuyacloudapi/src/Session/Session.php [line:protected] => 224 [trace:Exception:private] => Array ( [0] => Array ( [file] => /var/www/html/plugins/SmartLife/vendor/sabinus52/tuyacloudapi/src/Session/Session.php [line] => 176 [function] => checkResponse [class] => Sabinus\TuyaCloudApi\Session\Session [type] => -> [args] => Array ( [0] => Array ( [responseStatus] => error [errorMsg] => Get accesstoken failed. Username or password error! ) [1] => Get accesstoken failed. Username or password error! ) ) [1] => Array ( [file] => /var/www/html/plugins/SmartLife/vendor/sabinus52/tuyacloudapi/src/Session/Session.php [line] => 117 [function] => _createToken [class] => Sabinus\TuyaCloudApi\Session\Session [type] => -> [args] => Array ( ) ) [2] => Array ( [file] => /var/www/html/plugins/SmartLife/vendor/sabinus52/tuyacloudapi/src/TuyaCloudApi.php [line] => 62 [function] => getToken [class] => Sabinus\TuyaCloudApi\Session\Session [type] => -> [args] => Array ( ) ) [3] => Array ( [file] => /var/www/html/plugins/SmartLife/core/class/SmartLife.class.php [line] => 81 [function] => checkConnection [class] => Sabinus\TuyaCloudApi\TuyaCloudApi [type] => -> [args] => Array ( ) ) [4] => Array ( [file] => /var/www/html/plugins/SmartLife/core/ajax/SmartLife.ajax.php [line] => 34 [function] => checkConnection [class] => SmartLife [type] => :: [args] => Array ( ) ) ) [previous:Exception:private] => )
[2021-12-11 14:16:27][INFO] : CHECK CONNECTION : === END =====================================================
merci
