Sirène Tuya TZE204_t1blo2bj.TS0601
Je possède une sirène Tuya modèle : TZE200_t1blo2bj qui fonctionne correctement avec la clé CONBEE II et le plugin zigbee.
J’ai fait l’acquisition d’une nouvelle sirène Tuya qui ne fonctionne pas car elle n’est pas reconnu. Modèle :
TZE204_t1blo2bj.TS0601.
Ci dessous, les erreurs remontées :
[2023-08-07 18:37:39][ERROR] : Erreur exécution de la commande [Aucun][TZE204_t1blo2bj.TS0601 a4:c1:38:ea:22:01:07:39][On] : Erreur lors de la requete : http://127.0.0.1:8484/device/command(PUT), data : {"ieee":"a4:c1:38:ea:22:01:07:39","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[a4:c1:38:ea:22:01:07:39][zdevices.command] Cluster not found : on_off","code":0}
[2023-08-07 18:37:42][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2023-08-07 18:37:42][DEBUG] : {"ieee":"a4:c1:38:ea:22:01:07:39","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2023-08-07 18:37:42][ERROR] : Erreur exécution de la commande [Aucun][TZE204_t1blo2bj.TS0601 a4:c1:38:ea:22:01:07:39][Off] : Erreur lors de la requete : http://127.0.0.1:8484/device/command(PUT), data : {"ieee":"a4:c1:38:ea:22:01:07:39","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[a4:c1:38:ea:22:01:07:39][zdevices.command] Cluster not found : on_off","code":0}
[2023-08-07 18:37:43][DEBUG] : {"devices":{"04:cf:8c:df:3c:8e:32:82":{"1":{"64704":{"247":{"value":"b\"d\x10\x01\x03(\x1c\x989)\x96B\x959=\xb8oD\x969\x00\x00\x0cE\x979\x00\xd0\xa7C\x05!\x14\x00\x9a \x00\x08!\x16\x01\x07'\x00\x00\x00\x00\x00\x00\x00\x00	!\x02
\x0b \x00\x9b\x10\x01\"","cluster_name":"Manufacturer Specific"}},"2820":{"1291":{"value":"751.8000030517578","cluster_name":"Electrical Measurement"},"772":{"value":"958878.7231445312","cluster_name":"Electrical Measurement"},"1285":{"value":"224.0","cluster_name":"Electrical Measurement"}},"1794":[{"value":"958878.7231445312","cluster_name":"MeteringCluster"}],"2":[{"value":"2800","cluster_name":"Device Temperature"}]}}}}
[2023-08-07 18:37:44][DEBUG] : Search attribut for 04:cf:8c:df:3c:8e:32:82 logicalId : 1::64704::247 => b"d\x10\x01\x03(\x1c\x989)\x96B\x959=\xb8oD\x969\x00\x00\x0cE\x979\x00\xd0\xa7C\x05!\x14\x00\x9a \x00\x08!\x16\x01\x07'\x00\x00\x00\x00\x00\x00\x00\x00	!\x02
\x0b \x00\x9b\x10\x01" convert to b"d\x10\x01\x03(\x1c\x989)\x96B\x959=\xb8oD\x969\x00\x00\x0cE\x979\x00\xd0\xa7C\x05!\x14\x00\x9a \x00\x08!\x16\x01\x07'\x00\x00\x00\x00\x00\x00\x00\x00	!\x02
[2023-08-07 18:37:44][DEBUG] : Search attribut for 04:cf:8c:df:3c:8e:32:82 logicalId : 1::2820::1291 => 751.8000030517578 convert to 751.8000030517578
[2023-08-07 18:37:44][DEBUG] : Search attribut for 04:cf:8c:df:3c:8e:32:82 logicalId : 1::2820::772 => 958878.7231445312 convert to 958878.7231445312
[2023-08-07 18:37:44][DEBUG] : Search attribut for 04:cf:8c:df:3c:8e:32:82 logicalId : 1::2820::1285 => 224.0 convert to 224.0
[2023-08-07 18:37:44][DEBUG] : Search attribut for 04:cf:8c:df:3c:8e:32:82 logicalId : 1::1794::0 => 958878.7231445312 convert to 958878.7231445312
[2023-08-07 18:37:44][DEBUG] : Search attribut for 04:cf:8c:df:3c:8e:32:82 logicalId : 1::2::0 => 2800 convert to 2800
[2023-08-07 18:37:58][DEBUG] : {"devices":{"a4:c1:38:cb:27:d9:e2:87":{"1":[{"1":{"value":"70","cluster_name":"Basic"},"65506":{"value":"54","cluster_name":"Basic"},"65508":{"value":"0","cluster_name":"Basic"}}]}}}
[2023-08-07 18:37:58][DEBUG] : Search attribut for a4:c1:38:cb:27:d9:e2:87 logicalId : 1::0::1 => 70 convert to 70
[2023-08-07 18:37:58][DEBUG] : Search attribut for a4:c1:38:cb:27:d9:e2:87 logicalId : 1::0::65506 => 54 convert to 54
[2023-08-07 18:37:58][DEBUG] : Search attribut for a4:c1:38:cb:27:d9:e2:87 logicalId : 1::0::65508 => 0 convert to 0
Serait-il possible d’intégrer cette nouvelle sirène Tuya dans la plugin ZIGBEE.
  • merci de mettre vos logs entre balises
  • le plugin zigbee n’aura pas de nouvelle intégration, il faut passer au nouveau jeezigbee.
