Suite a l’achat d’une siréne ABUS, elle est en inconnu mais les commandes ON/OFF et batterie ont été crées.
Je ne sais pas trop ce qu’il faut fournir donc je met les infos dont je dispose
"state" : "ok",
"code" : 0,
"result" : {
"associations" : [
"instances" : {
"1" : {
"updateTime" : 1,
"commandClasses" : {
"37" : {
"data" : {
"0" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Bool",
"genre" : "User",
"read_only" : false,
"expected_data" : null,
"poll_intensity" : 0,
"name" : "Switch",
"val" : false,
"pendingState" : null,
"type" : "bool",
"data_items" : "True or False",
"value_id" : 72057594311163900,
"units" : "",
"write_only" : false
"updateTime" : 1
"name" : "COMMAND_CLASS_SWITCH_BINARY"
"94" : {
"data" : {
"0" : {
"updateTime" : 1638377799,
"help" : "",
"typeZW" : "Byte",
"genre" : "System",
"read_only" : true,
"name" : "ZWave+ Version",
"val" : 1,
"type" : "int",
"data_items" : "Read only",
"value_id" : 72057594320486400,
"units" : "",
"1" : {
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"read_only" : true,
"name" : "InstallerIcon",
"val" : 3840,
"type" : "int",
"value_id" : 72057594320486420,
"units" : "",
"2" : {
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"read_only" : true,
"name" : "UserIcon",
"val" : 3840,
"type" : "int",
"value_id" : 72057594320486430,
"units" : "",
"name" : "COMMAND_CLASS_ZWAVE_PLUS_INFO"
"115" : {
"data" : {
"0" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "List",
"genre" : "System",
"name" : "Powerlevel",
"val" : "Normal",
"type" : "List",
"data_items" : "-1dB;-2dB;-3dB;-4dB;-5dB;-6dB;-7dB;-8dB;-9dB;Normal",
"value_id" : 72057594320830460,
"units" : "dB",
"1" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Byte",
"genre" : "System",
"name" : "Timeout",
"val" : 0,
"type" : "int",
"data_items" : "A byte between 0 and 255",
"value_id" : 72057594320830480,
"units" : "seconds",
"2" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Button",
"genre" : "System",
"name" : "Set Powerlevel",
"val" : null,
"type" : "bool",
"value_id" : 72057594320830500,
"units" : "",
"write_only" : true
"3" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Byte",
"genre" : "System",
"name" : "Test Node",
"val" : 0,
"type" : "int",
"value_id" : 72057594320830510,
"units" : "",
"4" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "List",
"genre" : "System",
"name" : "Test Powerlevel",
"val" : "Normal",
"type" : "List",
"value_id" : 72057594320830530,
"units" : "dB",
"5" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"name" : "Frame Count",
"val" : 0,
"type" : "int",
"data_items" : "A short between 4294934528 and 32767",
"value_id" : 72057594320830540,
"units" : "",
"6" : {
"updateTime" : 1,
"help" : "",
"genre" : "System",
"name" : "Test",
"val" : null,
"type" : "bool",
"value_id" : 72057594320830560,
"units" : "",
"write_only" : true
"7" : {
"updateTime" : 1,
"help" : "",
"genre" : "System",
"name" : "Report",
"val" : null,
"type" : "bool",
"value_id" : 72057594320830600,
"units" : "",
"write_only" : true
"8" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "List",
"genre" : "System",
"read_only" : true,
"name" : "Test Status",
"val" : "Failed",
"type" : "List",
"units" : "",
"9" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"read_only" : true,
"name" : "Acked Frames",
"val" : 0,
"type" : "int",
"value_id" : 72057594320830610,
"units" : "",
"updateTime" : 1
"name" : "COMMAND_CLASS_POWERLEVEL"
"128" : {
"data" : {
"0" : {
"updateTime" : 1638378043,
"help" : "",
"typeZW" : "Byte",
"genre" : "User",
"read_only" : true,
"name" : "Battery Level",
"val" : 100,
"type" : "int",
"value_id" : 72057594312654850,
"units" : "%",
"name" : "COMMAND_CLASS_BATTERY"
"134" : {
"data" : {
"0" : {
"updateTime" : 1638377803,
"help" : "",
"typeZW" : "String",
"genre" : "System",
"read_only" : true,
"name" : "Library Version",
"val" : "3",
"type" : "String",
"value_id" : 72057594321141760,
"units" : "",
"1" : {
"help" : "",
"genre" : "System",
"read_only" : true,
"name" : "Protocol Version",
"val" : "5.03",
"type" : "String",
"value_id" : 72057594321141780,
"units" : "",
"2" : {
"help" : "",
"genre" : "System",
"read_only" : true,
"name" : "Application Version",
"val" : "1.02",
"type" : "String",
"value_id" : 72057594321141800,
"units" : "",
"name" : "COMMAND_CLASS_VERSION"
"152" : {
"data" : {
"0" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Bool",
"genre" : "System",
"read_only" : true,
"name" : "Secured",
"val" : false,
"type" : "bool",
"value_id" : 72057594321436670,
"units" : "",
"updateTime" : 1
"name" : "COMMAND_CLASS_SECURITY"
"updateTime" : 1,
"data" : {
"updateTime" : 1
"groups" : {
"1" : {
"associations" : [
1,
0
"maximumAssociations" : 5,
"pending" : 1,
"label" : "Group 1"
"command_classes" : {
"0" : {
"hex" : "0x00",
"name" : "COMMAND_CLASS_NO_OPERATION"
"32" : {
"hex" : "0x20",
"name" : "COMMAND_CLASS_BASIC"
"37" : {
"hex" : "0x25",
"90" : {
"hex" : "0x5a",
"name" : "COMMAND_CLASS_DEVICE_RESET_LOCALLY"
"94" : {
"hex" : "0x5e",
"114" : {
"hex" : "0x72",
"name" : "COMMAND_CLASS_MANUFACTURER_SPECIFIC"
"115" : {
"hex" : "0x73",
"128" : {
"hex" : "0x80",
"133" : {
"hex" : "0x85",
"name" : "COMMAND_CLASS_ASSOCIATION"
"134" : {
"hex" : "0x86",
"142" : {
"hex" : "0x8e",
"name" : "COMMAND_CLASS_MULTI_INSTANCE_ASSOCIATION"
"152" : {
"hex" : "0x98",
"last_notification" : {
"code" : 1,
"help" : "Messages that timeout will send a Notification with this code",
"description" : "Timeout",
"next_wakeup" : null,
"receiveTime" : 1638377803
"data" : {
"isReady" : {
"value" : true
"isRouting" : {
"value" : true
"isZwavePlus" : {
"value" : true
"basicType" : {
"value" : 4
"isListening" : {
"value" : true
"is_enable" : {
"value" : true
"is_manufacturer_specific_ok" : {
"enabled" : true,
"value" : true
"genericType" : {
"value" : 16
"isAwake" : {
"value" : true
"manufacturerProductId" : {
"hex" : "0x0000",
"value" : 0
"statistics" : {
"delivered" : 100,
"total" : 17,
"deliveryTime" : 28
"isEnable" : {
"value" : true
"specificType" : {
"value" : 5
"neighbours" : {
"value" : [
8,
1,
13
"maxBaudRate" : {
"value" : 40000
"isSecurity" : {
"value" : false
"state" : {
"value" : "Complete"
"version" : {
"value" : 4
"location" : {
"value" : ""
"manufacturerId" : {
"hex" : "0x0403",
"value" : 1027
"type" : {
"value" : "Siren"
"product_name" : {
"value" : "Unknown: type=0003, id=0000"
"pending_changes" : {
"count" : 0
"battery_level" : {
"value" : 100
"description" : {
"product_name" : "Unknown: type=0003, id=0000",
"name" : "Unknown",
"location" : ""
"isVirtual" : {
"value" : ""
"isFrequentListening" : {
"value" : false
"wakeup_interval" : {
"value" : null
"is_neighbours_ok" : {
"neighbors" : 3,
"enabled" : true,
"value" : true
"can_wake_up" : {
"value" : false
"lastReceived" : {
"isBeaming" : {
"value" : true
"name" : {
"value" : ""
"manufacturerProductType" : {
"hex" : "0x0003",
"value" : 3
"is_groups_ok" : {
"enabled" : true,
"value" : true
"isSecured" : {
"enabled" : true,
"value" : false
"vendorString" : {
"value" : "Unknown: id=0403"
"isInfoReceived" : {
"value" : true
"isFailed" : {
"value" : false
"security" : {
"value" : 0
"multi_instance" : {
"instances" : 1,
"support" : true
