Bonjour @druid
est ce que ce sujet à évolué j’essaye de faire communiquer une harmonia 3 avec le plugin moi les message diffèrent des tiens au niveau des codes, mais sinon les erreurs sont les mêmes :
2025-01-24 00:40:42.593] DEBUG : SIATCPHandler::process response: 730C0025"NAK"0000L0R0A0[]_00:40:42,01-24-2025
[2025-01-24 00:40:53.992] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\n65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]\r')
[2025-01-24 00:40:53.992] DEBUG : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]
[2025-01-24 00:40:53.993] ERROR : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL], exc: SIAEvent::__init__ line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL] (no matches found)
[2025-01-24 00:40:53.993] DEBUG : SIATCPHandler::process response: 31F30025"NAK"0000L0R0A0[]_00:40:53,01-24-2025
[2025-01-24 00:41:05.392] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\n65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]\r')
[2025-01-24 00:41:05.392] DEBUG : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]
[2025-01-24 00:41:05.392] ERROR : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL], exc: SIAEvent::__init__ line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL] (no matches found)
[2025-01-24 00:41:05.392] DEBUG : SIATCPHandler::process response: 3C360025"NAK"0000L0R0A0[]_00:41:05,01-24-2025
[2025-01-24 00:41:16.992] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\n65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]\r')
[2025-01-24 00:41:16.992] DEBUG : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]
[2025-01-24 00:41:16.992] ERROR : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL], exc: SIAEvent::__init__ line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL] (no matches found)
[2025-01-24 00:41:16.992] DEBUG : SIATCPHandler::process response: B9300025"NAK"0000L0R0A0[]_00:41:16,01-24-2025
[2025-01-24 00:41:28.392] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\n65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]\r')
[2025-01-24 00:41:28.392] DEBUG : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]
[2025-01-24 00:41:28.392] ERROR : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL], exc: SIAEvent::__init__ line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL] (no matches found)
[2025-01-24 00:41:28.392] DEBUG : SIATCPHandler::process response: ADDC0025"NAK"0000L0R0A0[]_00:41:28,01-24-2025
[2025-01-24 00:41:39.792] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\n65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]\r')
[2025-01-24 00:41:39.792] DEBUG : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]
[2025-01-24 00:41:39.792] ERROR : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL], exc: SIAEvent::__init__ line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL] (no matches found)
[2025-01-24 00:41:39.792] DEBUG : SIATCPHandler::process response: EF230025"NAK"0000L0R0A0[]_00:41:39,01-24-2025
[2025-01-24 00:41:51.192] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\n65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]\r')
[2025-01-24 00:41:51.192] DEBUG : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL]
[2025-01-24 00:41:51.192] ERROR : SIATCPHandler::process line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL], exc: SIAEvent::__init__ line: 65A70027"SIA-DCS"0001R0L0#12345[12345|Nri01/CL] (no matches found)
[2025-01-24 00:41:51.192] DEBUG : SIATCPHandler::process response: F6CB0025"NAK"0000L0R0A0[]_00:41:51,01-24-2025
[2025-01-24 00:42:50.491] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:42:50.491] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:42:50.491] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:42:50.491] DEBUG : SIATCPHandler::process response: 34750025"NAK"0000L0R0A0[]_00:42:50,01-24-2025
[2025-01-24 00:43:01.891] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:43:01.891] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:43:01.891] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:43:01.891] DEBUG : SIATCPHandler::process response: F2450025"NAK"0000L0R0A0[]_00:43:01,01-24-2025
[2025-01-24 00:43:13.291] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:43:13.291] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:43:13.291] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:43:13.291] DEBUG : SIATCPHandler::process response: B4BE0025"NAK"0000L0R0A0[]_00:43:13,01-24-2025
[2025-01-24 00:43:24.691] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:43:24.691] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:43:24.691] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:43:24.691] DEBUG : SIATCPHandler::process response: BC4E0025"NAK"0000L0R0A0[]_00:43:24,01-24-2025
[2025-01-24 00:43:36.291] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:43:36.291] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:43:36.291] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:43:36.291] DEBUG : SIATCPHandler::process response: FAB50025"NAK"0000L0R0A0[]_00:43:36,01-24-2025
[2025-01-24 00:43:47.691] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:43:47.691] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:43:47.691] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:43:47.691] DEBUG : SIATCPHandler::process response: 7E430025"NAK"0000L0R0A0[]_00:43:47,01-24-2025
[2025-01-24 00:43:59.090] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:43:59.091] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:43:59.091] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:43:59.091] DEBUG : SIATCPHandler::process response: 28A80025"NAK"0000L0R0A0[]_00:43:59,01-24-2025
[2025-01-24 00:44:10.490] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:44:10.490] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:44:10.490] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:44:10.491] DEBUG : SIATCPHandler::process response: B2FD0025"NAK"0000L0R0A0[]_00:44:10,01-24-2025
[2025-01-24 00:44:22.090] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:44:22.090] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:44:22.090] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:44:22.091] DEBUG : SIATCPHandler::process response: B6010025"NAK"0000L0R0A0[]_00:44:22,01-24-2025
[2025-01-24 00:44:33.490] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:44:33.490] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:44:33.490] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:44:33.490] DEBUG : SIATCPHandler::process response: F4FE0025"NAK"0000L0R0A0[]_00:44:33,01-24-2025
[2025-01-24 00:44:44.890] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:44:44.890] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:44:44.890] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:44:44.890] DEBUG : SIATCPHandler::process response: 78000025"NAK"0000L0R0A0[]_00:44:44,01-24-2025
[2025-01-24 00:44:56.290] DEBUG : SIATCPHandler::handle IP: 192.168.2.101,raw: bytearray(b'\nA66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]\r')
[2025-01-24 00:44:56.290] DEBUG : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP]
[2025-01-24 00:44:56.290] ERROR : SIATCPHandler::process line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP], exc: SIAEvent::__init__ line: A66F0027"SIA-DCS"0001R0L0#12345[12345|Nri01/OP] (no matches found)
[2025-01-24 00:44:56.290] DEBUG : SIATCPHandler::process response: 3EFB0025"NAK"0000L0R0A0[]_00:44:56,01-24-2025
