Hello à tous
Achat et installation du plugin SIA PRO - OK
Installation dépendance - OK
PORT SIA 8585 / Socket Interne 55025 - OK
Lancement du demon SIA PRO - OK
[2022-07-30 11:32:17][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=siapro function=remove callInstallFunction=1
[2022-07-30 11:32:41][INFO] : Début d'activation du plugin
[2022-07-30 11:32:42][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-07-30 11:32:42][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=siapro function=install callInstallFunction=1
[2022-07-30 11:34:56][INFO] : Lancement démon SIA : /usr/bin/python3 /var/www/html/plugins/siapro/resources/siaprod/siaprod.py --loglevel info --siaport 8585 --socketport 55025 --sockethost 127.0.0.1 --callback http://127.0.0.1:80/plugins/siapro/core/php/jeeSIAPro.php --apikey hfT7pRYL6h1fhjLyFMyEpOfZUlhgkmj4uVd6ehZkstX9Oh87wjNmG3IiOsYBpEUy --pidfile /tmp/jeedom/siapro/deamon.pid
[2022-07-30 11:34:56.116][INFO] : Starting SIAPro Daemon (Version 0.1)
[2022-07-30 11:34:56.116][INFO] : Log level: info
[2022-07-30 11:34:56.116][INFO] : Socket port: 55025
[2022-07-30 11:34:56.116][INFO] : Socket host: 127.0.0.1
[2022-07-30 11:34:56.116][INFO] : SIA Port: 8585
[2022-07-30 11:34:56.116][INFO] : PID file: /tmp/jeedom/siapro/deamon.pid
[2022-07-30 11:34:56.116][INFO] : Apikey: hfT7pRYL6h1fhjLyFMyEpOfZUlhgkmj4uVd6ehZkstX9Oh87wjNmG3IiOsYBpEUy
[2022-07-30 11:34:56.116][INFO] : Callback: http://127.0.0.1:80/plugins/siapro/core/php/jeeSIAPro.php
[2022-07-30 11:34:56.120][INFO] : Start listening on: [127.0.0.1:55025]
[2022-07-30 11:34:56.121][INFO] : Starting SIAServer daemon on: [*:8585]
[2022-07-30 11:34:56.121][INFO] : SIAServer daemon started on: [*:8585]
Paramétrage AX PRO
protocole SIA-DCS / IP du jeedom / port 8080 / code compte PHN77 / TCP / Enable essai périodique
Et voila l’erreur que j’ai
[2022-07-30 11:39:31.127][DEBUG] : SIATCPHandler::process line: BC48003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:26,07-30-2022
[2022-07-30 11:39:31.128][ERROR] : SIATCPHandler::process line: BC48003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:26,07-30-2022, exc: SIAEvent::__init__ line: BC48003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:26,07-30-2022 (no matches found)
[2022-07-30 11:39:31.128][DEBUG] : SIATCPHandler::process response: 229F0025"NAK"0000L0R0A0[]_11:39:31,07-30-2022
[2022-07-30 11:39:33.387][DEBUG] : SIATCPHandler::handle IP: 192.168.xx.xx,raw: bytearray(b'
3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022
[2022-07-30 11:39:33.388][DEBUG] : SIATCPHandler::process line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022
[2022-07-30 11:39:33.388][ERROR] : SIATCPHandler::process line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022, exc: SIAEvent::__init__ line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022 (no matches found)
[2022-07-30 11:39:33.388][DEBUG] : SIATCPHandler::process response: E5660025"NAK"0000L0R0A0[]_11:39:33,07-30-2022
[2022-07-30 11:39:34.397][DEBUG] : SIATCPHandler::handle IP: 192.168.xx.xx,raw: bytearray(b'
[2022-07-30 11:39:34.398][DEBUG] : SIATCPHandler::process line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022
[2022-07-30 11:39:34.398][ERROR] : SIATCPHandler::process line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022, exc: SIAEvent::__init__ line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022 (no matches found)
[2022-07-30 11:39:34.398][DEBUG] : SIATCPHandler::process response: 2E930025"NAK"0000L0R0A0[]_11:39:34,07-30-2022
[2022-07-30 11:39:35.407][DEBUG] : SIATCPHandler::handle IP: 192.168.xx.xx,raw: bytearray(b'\n3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022\r')
[2022-07-30 11:39:35.408][DEBUG] : SIATCPHandler::process line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022
[2022-07-30 11:39:35.408][ERROR] : SIATCPHandler::process line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022, exc: SIAEvent::__init__ line: 3542003C"SIA-DCS"0001L0#PHN77[#PHN77|Nri0000/RP]_09:39:30,07-30-2022 (no matches found)
[2022-07-30 11:39:35.409][DEBUG] : SIATCPHandler::process response: ED6E0025"NAK"0000L0R0A0[]_11:39:35,07-30-2022
