j’utilise le plugin Shelly et j’ai des soucis de remontée des données : toutes les valeurs restent à 0.
Version du plugin Shelly : 2023-09-13 01:02:21
Version du core : 4.2.20
Version du firmware du Shelly Pro 3 EM : 20240522-112847/1.3.2-g34c651b
J’ai configuré le type du module dans la configuration.
Je ne vois pas quelle est mon erreur. Si qqn peut m’aider…
En regardant dans les logs, je vois que le module répond. Il semble que le soucis soit ailleurs :
: Call : http://192.168.1.239/rpc/Shelly.GetStatus, return : 200, content : {"ble":{},"cloud":{"connected":true},"em1:0":{"id":0,"current":2.459,"voltage":229.8,"act_power":553.4,"aprt_power":565.8,"pf":0.98, "freq":50.0,"calibration":"factory"},"em1:1":{"id":1,"current":0.032,"voltage":230.0,"act_power":2.7,"aprt_power":7.3,"pf":0.41, "freq":50.0,"calibration":"factory"},"em1:2":{"id":2,"current":0.028,"voltage":229.9,"act_power":0.0,"aprt_power":6.5,"pf":0.00, "freq":50.0,"calibration":"factory"},"em1data:0":{"id":0,"total_act_energy":856.51,"total_act_ret_energy":0.00},"em1data:1":{"id":1,"total_act_energy":4.44,"total_act_ret_energy":0.00},"em1data:2":{"id":2,"total_act_energy":0.01,"total_act_ret_energy":0.02},"eth":{"ip":"192.168.1.239"},"modbus":{},"mqtt":{"connected":false},"sys":{"mac":"08F9E0EA2BC4","restart_required":false,"time":"13:25","unixtime":1719141905,"uptime":5610,"ram_size":241280,"ram_free":113616,"fs_size":524288,"fs_free":184320,"cfg_rev":12,"kvs_rev":1,"schedule_rev":1,"webhook_rev":1,"available_updates":{},"reset_reason":1},"temperature:0":{"id": 0,"tC":69.6, "tF":157.3},"wifi":{"sta_ip":null,"status":"disconnected","ssid":null,"rssi":0},"ws":{"connected":false}}
0022|[2024-06-23 13:25:05]DEBUG : Call : http://192.168.1.238/rpc/Shelly.GetStatus, return : 200, content : {"ble":{},"cloud":{"connected":true},"eth":{"ip":"192.168.1.238"},"input:0":{"id":0,"state":false},"input:1":{"id":1,"state":false},"input:2":{"id":2,"state":false},"input:3":{"id":3,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"http", "output":true, "apower":2.3, "voltage":230.0, "current":0.011, "pf":0.89, "aenergy":{"total":644.179,"by_minute":[3.173,38.378,38.756],"minute_ts":1719141904},"temperature":{"tC":61.1, "tF":142.1}},"switch:1":{"id":1, "source":"http", "output":true, "apower":1.9, "voltage":230.0, "current":0.016, "pf":-0.51, "aenergy":{"total":654.793,"by_minute":[2.664,32.722,33.021],"minute_ts":1719141904},"temperature":{"tC":61.1, "tF":142.1}},"switch:2":{"id":2, "source":"http", "output":false, "apower":0.0, "voltage":229.9, "current":0.000, "pf":0.00, "aenergy":{"total":0.003,"by_minute":[0.000,0.000,0.000],"minute_ts":1719141904},"temperature":{"tC":61.1, "tF":142.1}},"switch:3":{"id":3, "source":"UI", "output":true, "apower":1.9, "voltage":229.9, "current":0.019, "pf":0.64, "aenergy":{"total":52.908,"by_minute":[2.659,32.837,32.512],"minute_ts":1719141904},"temperature":{"tC":61.1, "tF":142.1}},"sys":{"mac":"C8F09E87D99C","restart_required":true,"time":"13:25","unixtime":1719141905,"uptime":2938243,"ram_size":246752,"ram_free":101116,"fs_size":524288,"fs_free":167936,"cfg_rev":19,"kvs_rev":7,"schedule_rev":0,"webhook_rev":0,"available_updates":{"stable":{"version":"1.3.2"}}},"ui":{},"wifi":{"sta_ip":null,"status":"disconnected","ssid":null,"rssi":0},"ws":{"connected":false}}
0023|[2024-06-23 13:30:06]DEBUG : Call : http://192.168.1.239/rpc/Shelly.GetStatus, return : 200, content : {"ble":{},"cloud":{"connected":true},"em1:0":{"id":0,"current":2.450,"voltage":227.9,"act_power":548.1,"aprt_power":558.8,"pf":0.98, "freq":50.0,"calibration":"factory"},"em1:1":{"id":1,"current":0.032,"voltage":228.1,"act_power":2.4,"aprt_power":7.3,"pf":0.39, "freq":50.0,"calibration":"factory"},"em1:2":{"id":2,"current":0.028,"voltage":227.9,"act_power":0.0,"aprt_power":6.5,"pf":0.00, "freq":50.0,"calibration":"factory"},"em1data:0":{"id":0,"total_act_energy":902.47,"total_act_ret_energy":0.00},"em1data:1":{"id":1,"total_act_energy":4.67,"total_act_ret_energy":0.00},"em1data:2":{"id":2,"total_act_energy":0.01,"total_act_ret_energy":0.02},"eth":{"ip":"192.168.1.239"},"modbus":{},"mqtt":{"connected":false},"sys":{"mac":"08F9E0EA2BC4","restart_required":false,"time":"13:30","unixtime":1719142206,"uptime":5911,"ram_size":241264,"ram_free":113504,"fs_size":524288,"fs_free":184320,"cfg_rev":12,"kvs_rev":1,"schedule_rev":1,"webhook_rev":1,"available_updates":{},"reset_reason":1},"temperature:0":{"id": 0,"tC":70.0, "tF":158.0},"wifi":{"sta_ip":null,"status":"disconnected","ssid":null,"rssi":0},"ws":{"connected":false}}
0024|[2024-06-23 13:30:06]DEBUG : Call : http://192.168.1.238/rpc/Shelly.GetStatus, return : 200, content : {"ble":{},"cloud":{"connected":true},"eth":{"ip":"192.168.1.238"},"input:0":{"id":0,"state":false},"input:1":{"id":1,"state":false},"input:2":{"id":2,"state":false},"input:3":{"id":3,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"http", "output":true, "apower":2.2, "voltage":228.1, "current":0.011, "pf":0.89, "aenergy":{"total":644.367,"by_minute":[3.747,37.698,38.166],"minute_ts":1719142205},"temperature":{"tC":61.4, "tF":142.6}},"switch:1":{"id":1, "source":"http", "output":true, "apower":1.9, "voltage":228.1, "current":0.015, "pf":-0.51, "aenergy":{"total":654.957,"by_minute":[3.218,32.317,32.632],"minute_ts":1719142205},"temperature":{"tC":61.4, "tF":142.6}},"switch:2":{"id":2, "source":"http", "output":false, "apower":0.0, "voltage":228.1, "current":0.000, "pf":0.00, "aenergy":{"total":0.003,"by_minute":[0.000,0.000,0.000],"minute_ts":1719142205},"temperature":{"tC":61.4, "tF":142.6}},"switch:3":{"id":3, "source":"UI", "output":true, "apower":1.7, "voltage":228.1, "current":0.019, "pf":0.64, "aenergy":{"total":53.071,"by_minute":[3.235,32.365,32.276],"minute_ts":1719142205},"temperature":{"tC":61.4, "tF":142.6}},"sys":{"mac":"C8F09E87D99C","restart_required":true,"time":"13:30","unixtime":1719142206,"uptime":2938544,"ram_size":246752,"ram_free":101116,"fs_size":524288,"fs_free":167936,"cfg_rev":19,"kvs_rev":7,"schedule_rev":0,"webhook_rev":0,"available_updates":{"stable":{"version":"1.3.2"}}},"ui":{},"wifi":{"sta_ip":null,"status":"disconnected","ssid":null,"rssi":0},"ws":{"connected":false}}
