Bonjour, je viens d’installer une prise shelly plug s pas de remontées d’info puissance ni etat
y a t il une solution? j’ai essayer le plugin en beta et stable pareil, j’ai mis aussi le firmware a jour.
On en parle ici et sans retour
Tu as appliqué le bon template ?
Y aurait pas des logs en débug car jusqu’ici personne en donne histoire de voir si y a un truc.
voici un log
[2023-10-03 20:34:43][DEBUG] : Call : http://192.168.1.81/relay/0?turn=on, return : 200, content : {"ison": true, "has_timer":false, "timer_started_at": 0, "timer_duration": 0.00, "timer_remaining": 0.00, "overpower": false, "source": "http"}
[2023-10-03 20:34:43][DEBUG] : Call : http://192.168.1.81/status, return : 404, content : Not Found
[2023-10-03 20:34:45][DEBUG] : Call : http://192.168.1.81/relay/0?turn=off, return : 200, content : {"ison": false, "has_timer":false, "timer_started_at": 0, "timer_duration": 0.00, "timer_remaining": 0.00, "overpower": false, "source": "http"}
[2023-10-03 20:34:45][DEBUG] : Call : http://192.168.1.81/status, return : 404, content : Not Found
[2023-10-03 20:35:11][DEBUG] : Call : http://192.168.1.18/status, return : 200, content : {"wifi_sta":{"connected":true,"ssid":"Livebox-AB02","ip":"192.168.1.18","rssi":-68},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"20:35","unixtime":1696358111,"serial":999,"has_update":true,"mac":"C45BBE78C605","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"http"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":0}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"pending","has_update":true,"new_version":"20230913-112003/v1.14.0-gcb84623","old_version":"20221027-091427/v1.12.1-ga9117d3"},"ram_total":51688,"ram_free":40376,"fs_size":233681,"fs_free":150851,"uptime":3457497}
[2023-10-03 20:35:11][DEBUG] : Call : http://192.168.1.81/status, return : 404, content : Not Found
[2023-10-03 20:35:16][DEBUG] : Call : http://192.168.1.76/status, return : 0, content :
comment verifier le template, desolé je suis novice
Je m’aperçois que le Template shelly plusplugS n’apparait pas dans les type donc c’est peut être normal que les infos ne remontent pas, j’ai donc copié le Template _PlusPlugS.json trouvé sur forum dans plugin shelly/core/device
mais il n’apparait toujours pas dans les type, y a t il une autre manip a realiser, ?
Es-tu sûr que tu utilises le plugin-shelly, car à ma connaissance, il n’utilise pas MQTT ?
