depuis ce matin n’ayant plus d’activité de mes équipements je m’aperçois que Z2L me renvoit un message stipulant que le service et le client se sont arrêtés.
J’ai redémarrer, réparer via l’interface du plugin, réinstallé les dep et voilà ce qu’il en sort :
Dep
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://phoscon.de/apt/deconz buster InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Hit:5 https://repo.mosquitto.org/debian buster InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1+rpi2).
gcc is already the newest version (4:8.3.0-1+rpi2).
git is already the newest version (1:2.20.1-2+deb10u3).
make is already the newest version (4.2.1-1.2).
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
##### Install or update NodeJs
NodeJs 14 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (2.0.10-0mosquitto1~buster1).
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
##### Update : Download update from Zigbee2mqtt git
./install_z2m.sh: line 80: [: -en: binary operator expected
##### Compiling for NodeJS version 14
##### Updating...
Already up to date.
##### Installing dependencies...
npm WARN prepare removing existing node_modules/ before installation
> @serialport/bindings@9.0.4 install /opt/zigbee2mqtt/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=14.16.1 runtime=node arch=arm libc= platform=linux)
make: Entering directory '/opt/zigbee2mqtt/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
CXX(target) Release/obj.target/bindings/src/serialport.o
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:78:69: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:135:71: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:175:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:215:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:270:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:314:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:363:76: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':
../src/serialport.cpp:409:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
../src/serialport.cpp: At global scope:
../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses]
SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses]
SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
In file included from ../../../nan/nan.h:56,
from ../src/./serialport.h:6,
from ../src/serialport.cpp:1:
/root/.cache/node-gyp/14.16.1/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
(node::addon_register_func) (regfunc), \
/root/.cache/node-gyp/14.16.1/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X'
NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
../src/serialport.cpp:483:1: note: in expansion of macro 'NODE_MODULE'
NODE_MODULE(serialport, init);
CXX(target) Release/obj.target/bindings/src/serialport_unix.o
../src/serialport_unix.cpp: In function 'int setup(int, OpenBaton*)':
../src/serialport_unix.cpp:176:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:176:13: note: 'snprintf' output 20 or more bytes (assuming 1043) into a destination of size 1024
../src/serialport_unix.cpp: In function 'void EIO_Open(uv_work_t*)':
../src/serialport_unix.cpp:86:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:86:13: note: 'snprintf' output 22 or more bytes (assuming 1045) into a destination of size 1024
CXX(target) Release/obj.target/bindings/src/poller.o
CXX(target) Release/obj.target/bindings/src/serialport_linux.o
SOLINK_MODULE(target) Release/obj.target/bindings.node
COPY Release/bindings.node
make: Leaving directory '/opt/zigbee2mqtt/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
> serialport@9.0.6 postinstall /opt/zigbee2mqtt/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/serialport
> node thank-you.js
e[96me[1mThank you for using serialport!e[96me[1m
e[0me[96mIf you rely on this package, please consider supporting our open collective:e[22me[39m
> e[94mhttps://opencollective.com/serialport/donatee[0m
> @serialport/bindings@9.0.4 install /opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
make: Entering directory '/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
make: Leaving directory '/opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
> serialport@9.0.6 postinstall /opt/zigbee2mqtt/node_modules/zigbee-herdsman/node_modules/serialport
> node thank-you.js
> unix-dgram@2.0.3 install /opt/zigbee2mqtt/node_modules/unix-dgram
> node-gyp rebuild
make: Entering directory '/opt/zigbee2mqtt/node_modules/unix-dgram/build'
CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
In file included from ../../nan/nan.h:56,
from ../src/unix_dgram.cc:5:
/root/.cache/node-gyp/14.16.1/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
NODE_MODULE(unix_dgram, Initialize)
SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
COPY Release/unix_dgram.node
make: Leaving directory '/opt/zigbee2mqtt/node_modules/unix-dgram/build'
added 338 packages in 37.519s
##### Configure deamon and start it
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
daemon
[2021-05-29 12:20:41][INFO] : ##### Démarrage du service Client MQTT (Client MQTT Local) #####
[2021-05-29 12:20:42][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 1 seconde(s)
[2021-05-29 12:20:43][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 2 seconde(s)
[2021-05-29 12:20:44][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 3 seconde(s)
[2021-05-29 12:20:45][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 4 seconde(s)
[2021-05-29 12:20:46][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 5 seconde(s)
[2021-05-29 12:20:47][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 6 seconde(s)
[2021-05-29 12:20:48][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 7 seconde(s)
[2021-05-29 12:20:49][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 8 seconde(s)
[2021-05-29 12:20:50][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 9 seconde(s)
[2021-05-29 12:20:51][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 10 seconde(s)
[2021-05-29 12:20:52][INFO] : ##### --> Attent que le service Client MQTT (Client MQTT Local) démarre depuis 11 seconde(s)
[2021-05-29 12:20:52][INFO] : ##### Impossible de démarrer le service Client MQTT (Client MQTT Local) #####
[2021-05-29 12:20:53][INFO] : ##### Démarrage du service Zigbee2MQTT #####
[2021-05-29 12:20:54][INFO] : ##### Le service Zigbee2MQTT démarre... #####
[2021-05-29 12:20:56][INFO] : ##### Démarrage du service MQTT #####
[2021-05-29 12:20:57][INFO] : ##### --> Attent que le service MQTT démarre depuis 1 seconde(s)
[2021-05-29 12:20:58][INFO] : ##### --> Attent que le service MQTT démarre depuis 2 seconde(s)
[2021-05-29 12:21:00][INFO] : ##### --> Attent que le service MQTT démarre depuis 3 seconde(s)
[2021-05-29 12:21:01][INFO] : ##### --> Attent que le service MQTT démarre depuis 4 seconde(s)
[2021-05-29 12:21:02][INFO] : ##### --> Attent que le service MQTT démarre depuis 5 seconde(s)
[2021-05-29 12:21:03][INFO] : ##### --> Attent que le service MQTT démarre depuis 6 seconde(s)
[2021-05-29 12:21:04][INFO] : ##### --> Attent que le service MQTT démarre depuis 7 seconde(s)
[2021-05-29 12:21:05][INFO] : ##### --> Attent que le service MQTT démarre depuis 8 seconde(s)
[2021-05-29 12:21:06][INFO] : ##### --> Attent que le service MQTT démarre depuis 9 seconde(s)
[2021-05-29 12:21:07][INFO] : ##### --> Attent que le service MQTT démarre depuis 10 seconde(s)
[2021-05-29 12:21:08][INFO] : ##### --> Attent que le service MQTT démarre depuis 11 seconde(s)
[2021-05-29 12:21:09][INFO] : ##### --> Attent que le service MQTT démarre depuis 12 seconde(s)
[2021-05-29 12:21:10][INFO] : ##### --> Attent que le service MQTT démarre depuis 13 seconde(s)
[2021-05-29 12:21:11][INFO] : ##### --> Attent que le service MQTT démarre depuis 14 seconde(s)
[2021-05-29 12:21:13][INFO] : ##### --> Attent que le service MQTT démarre depuis 15 seconde(s)
[2021-05-29 12:21:14][INFO] : ##### --> Attent que le service MQTT démarre depuis 16 seconde(s)
[2021-05-29 12:21:15][INFO] : ##### --> Attent que le service MQTT démarre depuis 17 seconde(s)
[2021-05-29 12:21:16][INFO] : ##### --> Attent que le service MQTT démarre depuis 18 seconde(s)
[2021-05-29 12:21:17][INFO] : ##### --> Attent que le service MQTT démarre depuis 19 seconde(s)
[2021-05-29 12:21:18][INFO] : ##### --> Attent que le service MQTT démarre depuis 20 seconde(s)
[2021-05-29 12:21:19][INFO] : ##### --> Attent que le service MQTT démarre depuis 21 seconde(s)
[2021-05-29 12:21:20][INFO] : ##### --> Attent que le service MQTT démarre depuis 22 seconde(s)
[2021-05-29 12:21:21][INFO] : ##### --> Attent que le service MQTT démarre depuis 23 seconde(s)
[2021-05-29 12:21:22][INFO] : ##### --> Attent que le service MQTT démarre depuis 24 seconde(s)
[2021-05-29 12:21:23][INFO] : ##### --> Attent que le service MQTT démarre depuis 25 seconde(s)
[2021-05-29 12:21:24][INFO] : ##### --> Attent que le service MQTT démarre depuis 26 seconde(s)
[2021-05-29 12:21:25][INFO] : ##### --> Attent que le service MQTT démarre depuis 27 seconde(s)
[2021-05-29 12:21:27][INFO] : ##### --> Attent que le service MQTT démarre depuis 28 seconde(s)
[2021-05-29 12:21:28][INFO] : ##### --> Attent que le service MQTT démarre depuis 29 seconde(s)
[2021-05-29 12:21:29][INFO] : ##### --> Attent que le service MQTT démarre depuis 30 seconde(s)
[2021-05-29 12:21:30][INFO] : ##### --> Attent que le service MQTT démarre depuis 31 seconde(s)
[2021-05-29 12:21:30][INFO] : ##### Impossible de démarrer le service MQTT #####
[2021-05-29 12:21:30][INFO] : ##### Le service zigbee2mqtt a démarré #####
Resync, déplacement de clé, redémarrage de jeedom effectué, aucun changement.
Du côté d’MQTT Explorer, idem disconnected from server.
Auriez vous une piste à suivre pour moi svp?
