Je déplace mon post dans un nouveau sujet.
Le réseau Z-Wave fonctionne de mieux en mieux, mais de temps en temps, il y a des ratés avec les capteurs de mouvement Fibaro Motion Sensor comme ci-dessous
2020-05-18 11:32:59.007 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2020-05-18 11:32:59.089 Info, Node124, Received SensorBinary report: Sensor:73 State=On
2020-05-18 11:32:59.123 Info, Node124, Received SensorBinary report: Sensor:65 State=On
2020-05-18 11:33:57.253 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2020-05-18 11:33:57.335 Info, Node124, Received SensorBinary report: Sensor:182 State=Off
2020-05-18 11:33:57.368 Info, Node124, Received SensorBinary report: Sensor:190 State=Off
2020-05-18 11:34:13.090 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2020-05-18 11:34:13.173 Info, Node124, Received SensorBinary report: Sensor:73 State=On
2020-05-18 11:34:13.206 Info, Node124, Received SensorBinary report: Sensor:65 State=On
2020-05-18 11:34:50.006 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2020-05-18 11:34:50.088 Info, Node124, Received SensorBinary report: Sensor:182 State=Off
2020-05-18 11:34:50.122 Info, Node124, Received SensorBinary report: Sensor:190 State=Off
2020-05-18 11:35:52.969 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2020-05-18 11:35:53.051 Info, Node124, Received SensorBinary report: Sensor:73 State=On
2020-05-18 11:35:53.085 Info, Node124, Received SensorBinary report: Sensor:65 State=On
2020-05-18 11:36:35.519 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2020-05-18 11:51:33.420 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2020-05-18 11:51:33.502 Info, Node124, Received SensorBinary report: Sensor:73 State=On
2020-05-18 11:51:33.536 Info, Node124, Received SensorBinary report: Sensor:65 State=On
2020-05-18 11:52:10.412 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2020-05-18 11:52:10.495 Info, Node124, Received SensorBinary report: Sensor:182 State=Off
2020-05-18 11:52:10.529 Info, Node124, Received SensorBinary report: Sensor:190 State=Off
2020-05-18 11:53:59.534 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2020-05-18 11:53:59.616 Info, Node124, Received SensorBinary report: Sensor:73 State=On
2020-05-18 11:53:59.650 Info, Node124, Received SensorBinary report: Sensor:65 State=On
2020-05-18 11:54:40.444 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2020-05-18 11:54:40.527 Info, Node124, Received SensorBinary report: Sensor:182 State=Off
2020-05-18 11:54:40.560 Info, Node124, Received SensorBinary report: Sensor:190 State=Off
2020-05-18 11:56:25.392 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2020-05-18 11:56:25.474 Info, Node124, Received SensorBinary report: Sensor:73 State=On
2020-05-18 11:56:25.507 Info, Node124, Received SensorBinary report: Sensor:65 State=On
2020-05-18 11:58:01.191 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2020-05-18 11:58:01.274 Info, Node124, Received SensorBinary report: Sensor:182 State=Off
2020-05-18 11:58:01.307 Info, Node124, Received SensorBinary report: Sensor:190 State=Off
2020-05-18 12:06:12.706 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2020-05-18 12:06:12.789 Info, Node124, Received SensorBinary report: Sensor:73 State=On
2020-05-18 12:06:12.823 Info, Node124, Received SensorBinary report: Sensor:65 State=On
2020-05-18 12:06:53.656 Info, Node124, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2020-05-18 12:06:53.738 Info, Node124, Received SensorBinary report: Sensor:182 State=Off
2020-05-18 12:06:53.772 Info, Node124, Received SensorBinary report: Sensor:190 State=Off
Que s’est-il passé à 11:36:35 ?
Le module a envoyé un Alarm report mais pas de SensorBinary report. Normalement, avec un Burglar event:0, c’est un State=Off pour le SensorBinary. Résultat le capteur est resté actif 15 min jusqu’à ce qu’on repasse devant à 11:51:33. Il n’y a d’erreur nulle part dans les statistiques. On observe juste dans l’historique que la Présence passe 2 fois à 1 sans passer par 0.
À votre avis, est-ce le module qui n’a pas envoyé l’info ou openzwave qui n’a pas décodé ?
Perso, je pencherais pour le premier et dans ce cas, pourquoi le SensorBinary report n’est pas envoyé à tous les coups ?
Pourquoi ne pas utiliser le Burglar=8 ou 0 (classe 113) dans la commande Présence au lieu du SensorBinary, un peu comme l’Access control=22 ou 23 pour les capteurs de porte ?
