Si vous avez l’intention de traiter rtd > forrule pour avoir la description de la météo en anglais, voici un widget code à affecter à la commande du plugin script.
Widget code: cmd.info.string.MeteoPiDescription.html
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="string" data-template="meteopi" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
<div class="content-xs">
<span class="cmdName #hide_name#">#name_display#</span> <span class="value"></span> <strong class="unit"></strong>
</div>
<div class="timeCmd label label-default #history#" data-type="info"></div>
<template>
<div>time : duration|date ({{Affiche durée ou date de la valeur}})</div>
</template>
<script>
function forecast(frule){
switch(parseInt(frule)){
case 0: return "Mostly clear and cooler.";break;
case 1: return "Mostly clear with little temperature change.";break;
case 2: return "Mostly clear for 12 hrs. with little temperature change.";break;
case 3: return "Mostly clear for 12 to 24 hrs. and cooler.";break;
case 4: return "Mostly clear with little temperature change.";break;
case 5: return "Partly cloudy and cooler.";break;
case 6: return "Partly cloudy with little temperature change.";break;
case 7: return "Partly cloudy with little temperature change.";break;
case 8: return "Mostly clear and warmer.";break;
case 9: return "Partly cloudy with little temperature change.";break;
case 10: return "Partly cloudy with little temperature change.";break;
case 11: return "Mostly clear with little temperature change.";break;
case 12: return "Increasing clouds and warmer. Precipitation possible within 24 to 48 hrs.";break;
case 13: return "Partly cloudy with little temperature change.";break;
case 14: return "Mostly clear with little temperature change.";break;
case 15: return "Increasing clouds with little temperature change. Precipitation possible within 24 hrs.";break;
case 16: return "Mostly clear with little temperature change.";break;
case 17: return "Partly cloudy with little temperature change.";break;
case 18: return "Mostly clear with little temperature change.";break;
case 19: return "Increasing clouds with little temperature change. Precipitation possible within 12 hrs.";break;
case 20: return "Mostly clear with little temperature change.";break;
case 21: return "Partly cloudy with little temperature change.";break;
case 22: return "Mostly clear with little temperature change.";break;
case 23: return "Increasing clouds and warmer. Precipitation possible within 24 hrs.";break;
case 24: return "Mostly clear and warmer. Increasing winds.";break;
case 25: return "Partly cloudy with little temperature change.";break;
case 26: return "Mostly clear with little temperature change.";break;
case 27: return "Increasing clouds and warmer. Precipitation possible within 12 hrs. Increasing winds.";break;
case 28: return "Mostly clear and warmer. Increasing winds.";break;
case 29: return "Increasing clouds and warmer.";break;
case 30: return "Partly cloudy with little temperature change.";break;
case 31: return "Mostly clear with little temperature change.";break;
case 32: return "Increasing clouds and warmer. Precipitation possible within 12 hrs. Increasing winds.";break;
case 33: return "Mostly clear and warmer. Increasing winds.";break;
case 34: return "Increasing clouds and warmer.";break;
case 35: return "Partly cloudy with little temperature change.";break;
case 36: return "Mostly clear with little temperature change.";break;
case 37: return "Increasing clouds and warmer. Precipitation possible within 12 hrs. Increasing winds.";break;
case 38: return "Partly cloudy with little temperature change.";break;
case 39: return "Mostly clear with little temperature change.";break;
case 40: return "Mostly clear and warmer. Precipitation possible within 48 hrs.";break;
case 41: return "Mostly clear and warmer.";break;
case 42: return "Partly cloudy with little temperature change.";break;
case 43: return "Mostly clear with little temperature change.";break;
case 44: return "Increasing clouds with little temperature change. Precipitation possible within 24 to 48 hrs.";break;
case 45: return "Increasing clouds with little temperature change.";break;
case 46: return "Partly cloudy with little temperature change.";break;
case 47: return "Mostly clear with little temperature change.";break;
case 48: return "Increasing clouds and warmer. Precipitation possible within 12 to 24 hrs.";break;
case 49: return "Partly cloudy with little temperature change.";break;
case 50: return "Mostly clear with little temperature change.";break;
case 51: return "Increasing clouds and warmer. Precipitation possible within 12 to 24 hrs. Windy.";break;
case 52: return "Partly cloudy with little temperature change.";break;
case 53: return "Mostly clear with little temperature change.";break;
case 54: return "Increasing clouds and warmer. Precipitation possible within 12 to 24 hrs. Windy.";break;
case 55: return "Partly cloudy with little temperature change.";break;
case 56: return "Mostly clear with little temperature change.";break;
case 57: return "Increasing clouds and warmer. Precipitation possible within 6 to 12 hrs.";break;
case 58: return "Partly cloudy with little temperature change.";break;
case 59: return "Mostly clear with little temperature change.";break;
case 60: return "Increasing clouds and warmer. Precipitation possible within 6 to 12 hrs. Windy.";break;
case 61: return "Partly cloudy with little temperature change.";break;
case 62: return "Mostly clear with little temperature change.";break;
case 63: return "Increasing clouds and warmer. Precipitation possible within 12 to 24 hrs. Windy.";break;
case 64: return "Partly cloudy with little temperature change.";break;
case 65: return "Mostly clear with little temperature change.";break;
case 66: return "Increasing clouds and warmer. Precipitation possible within 12 hrs.";break;
case 67: return "Partly cloudy with little temperature change.";break;
case 68: return "Mostly clear with little temperature change.";break;
case 69: return "Increasing clouds and warmer. Precipitation likely.";break;
case 70: return "clearing and cooler. Precipitation ending within 6 hrs.";break;
case 71: return "Partly cloudy with little temperature change.";break;
case 72: return "clearing and cooler. Precipitation ending within 6 hrs.";break;
case 73: return "Mostly clear with little temperature change.";break;
case 74: return "Clearing and cooler. Precipitation ending within 6 hrs.";break;
case 75: return "Partly cloudy and cooler.";break;
case 76: return "Partly cloudy with little temperature change.";break;
case 77: return "Mostly clear and cooler.";break;
case 78: return "clearing and cooler. Precipitation ending within 6 hrs.";break;
case 79: return "Mostly clear with little temperature change.";break;
case 80: return "Clearing and cooler. Precipitation ending within 6 hrs.";break;
case 81: return "Mostly clear and cooler.";break;
case 82: return "Partly cloudy with little temperature change.";break;
case 83: return "Mostly clear with little temperature change.";break;
case 84: return "Increasing clouds with little temperature change. Precipitation possible within 24 hrs.";break;
case 85: return "Mostly cloudy and cooler. Precipitation continuing.";break;
case 86: return "Partly cloudy with little temperature change.";break;
case 87: return "Mostly clear with little temperature change.";break;
case 88: return "Mostly cloudy and cooler. Precipitation likely.";break;
case 89: return "Mostly cloudy with little temperature change. Precipitation continuing.";break;
case 90: return "Mostly cloudy with little temperature change. Precipitation likely.";break;
case 91: return "Partly cloudy with little temperature change.";break;
case 92: return "Mostly clear with little temperature change.";break;
case 93: return "Increasing clouds and cooler. Precipitation possible and windy within 6 hrs.";break;
case 94: return "Increasing clouds with little temperature change. Precipitation possible and windy within 6 hrs.";break;
case 95: return "Mostly cloudy and cooler. Precipitation continuing. Increasing winds.";break;
case 96: return "Partly cloudy with little temperature change.";break;
case 97: return "Mostly clear with little temperature change.";break;
case 98: return "Mostly cloudy and cooler. Precipitation likely. Increasing winds.";break;
case 99: return "Mostly cloudy with little temperature change. Precipitation continuing. Increasing winds.";break;
case 100: return "Mostly cloudy with little temperature change. Precipitation likely. Increasing winds.";break;
case 101: return "Partly cloudy with little temperature change.";break;
case 102: return "Mostly clear with little temperature change.";break;
case 103: return "Increasing clouds and cooler. Precipitation possible within 12 to 24 hrs. Possible wind shift to the W, NW, or N.";break;
case 104: return "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hrs. Possible wind shift to the W, NW, or N.";break;
case 105: return "Partly cloudy with little temperature change.";break;
case 106: return "Mostly clear with little temperature change.";break;
case 107: return "Increasing clouds and cooler. Precipitation possible within 6 hrs. Possible wind shift to the W, NW, or N.";break;
case 108: return "Increasing clouds with little temperature change. Precipitation possible within 6 hrs. Possible wind shift to the W, NW, or N.";break;
case 109: return "Mostly cloudy and cooler. Precipitation ending within 12 hrs. Possible wind shift to the W, NW, or N.";break;
case 110: return "Mostly cloudy and cooler. Possible wind shift to the W, NW, or N.";break;
case 111: return "Mostly cloudy with little temperature change. Precipitation ending within 12 hrs. Possible wind shift to the W, NW, or N.";break;
case 112: return "Mostly cloudy with little temperature change. Possible wind shift to the W, NW, or N.";break;
case 113: return "Mostly cloudy and cooler. Precipitation ending within 12 hrs. Possible wind shift to the W, NW, or N.";break;
case 114: return "Partly cloudy with little temperature change.";break;
case 115: return "Mostly clear with little temperature change.";break;
case 116: return "Mostly cloudy and cooler. Precipitation possible within 24 hrs. Possible wind shift to the W, NW, or N.";break;
case 117: return "Mostly cloudy with little temperature change. Precipitation ending within 12 hrs. Possible wind shift to the W, NW, or N.";break;
case 118: return "Mostly cloudy with little temperature change. Precipitation possible within 24 hrs. Possible wind shift to the W, NW, or N.";break;
case 119: return "clearing, cooler and windy. Precipitation ending within 6 hrs.";break;
case 120: return "clearing, cooler and windy.";break;
case 121: return "Mostly cloudy and cooler. Precipitation ending within 6 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 122: return "Mostly cloudy and cooler. Windy with possible wind shift to the W, NW, or N.";break;
case 123: return "clearing, cooler and windy.";break;
case 124: return "Partly cloudy with little temperature change.";break;
case 125: return "Mostly clear with little temperature change.";break;
case 126: return "Mostly cloudy with little temperature change. Precipitation possible within 12 hrs. Windy.";break;
case 127: return "Partly cloudy with little temperature change.";break;
case 128: return "Mostly clear with little temperature change.";break;
case 129: return "Increasing clouds and cooler. Precipitation possible within 12 hrs., possibly heavy at times. Windy.";break;
case 130: return "Mostly cloudy and cooler. Precipitation ending within 6 hrs. Windy.";break;
case 131: return "Partly cloudy with little temperature change.";break;
case 132: return "Mostly clear with little temperature change.";break;
case 133: return "Mostly cloudy and cooler. Precipitation possible within 12 hrs. Windy.";break;
case 134: return "Mostly cloudy and cooler. Precipitation ending in 12 to 24 hrs.";break;
case 135: return "Mostly cloudy and cooler.";break;
case 136: return "Mostly cloudy and cooler. Precipitation continuing, possible heavy at times. Windy.";break;
case 137: return "Partly cloudy with little temperature change.";break;
case 138: return "Mostly clear with little temperature change.";break;
case 139: return "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hrs. Windy.";break;
case 140: return "Mostly cloudy with little temperature change. Precipitation continuing, possibly heavy at times. Windy.";break;
case 141: return "Partly cloudy with little temperature change.";break;
case 142: return "Mostly clear with little temperature change.";break;
case 143: return "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hrs. Windy.";break;
case 144: return "Partly cloudy with little temperature change.";break;
case 145: return "Mostly clear with little temperature change.";break;
case 146: return "Increasing clouds with little temperature change. Precipitation possible within 12 hrs., possibly heavy at times. Windy.";break;
case 147: return "Mostly cloudy and cooler. Windy.";break;
case 148: return "Mostly cloudy and cooler. Precipitation continuing, possibly heavy at times. Windy.";break;
case 149: return "Partly cloudy with little temperature change.";break;
case 150: return "Mostly clear with little temperature change.";break;
case 151: return "Mostly cloudy and cooler. Precipitation likely, possibly heavy at times. Windy.";break;
case 152: return "Mostly cloudy with little temperature change. Precipitation continuing, possibly heavy at times. Windy.";break;
case 153: return "Mostly cloudy with little temperature change. Precipitation likely, possibly heavy at times. Windy.";break;
case 154: return "Partly cloudy with little temperature change.";break;
case 155: return "Mostly clear with little temperature change.";break;
case 156: return "Increasing clouds and cooler. Precipitation possible within 6 hrs. Windy.";break;
case 157: return "Increasing clouds with little temperature change. Precipitation possible within 6 hrs. windy";break;
case 158: return "Increasing clouds and cooler. Precipitation continuing. Windy with possible wind shift to the W, NW, or N.";break;
case 159: return "Partly cloudy with little temperature change.";break;
case 160: return "Mostly clear with little temperature change.";break;
case 161: return "Mostly cloudy and cooler. Precipitation likely. Windy with possible wind shift to the W, NW, or N.";break;
case 162: return "Mostly cloudy with little temperature change. Precipitation continuing. Windy with possible wind shift to the W, NW, or N.";break;
case 163: return "Mostly cloudy with little temperature change. Precipitation likely. Windy with possible wind shift to the W, NW, or N.";break;
case 164: return "Increasing clouds and cooler. Precipitation possible within 6 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 165: return "Partly cloudy with little temperature change.";break;
case 166: return "Mostly clear with little temperature change.";break;
case 167: return "Increasing clouds and cooler. Precipitation possible within 6 hrs. Possible wind shift to the W, NW, or N.";break;
case 168: return "Increasing clouds with little temperature change. Precipitation possible within 6 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 169: return "Increasing clouds with little temperature change. Precipitation possible within 6 hrs. Possible wind shift to the W, NW, or N.";break;
case 170: return "Partly cloudy with little temperature change.";break;
case 171: return "Mostly clear with little temperature change.";break;
case 172: return "Increasing clouds and cooler. Precipitation possible within 6 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 173: return "Increasing clouds with little temperature change. Precipitation possible within 6 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 174: return "Partly cloudy with little temperature change.";break;
case 175: return "Mostly clear with little temperature change.";break;
case 176: return "Increasing clouds and cooler. Precipitation possible within 12 to 24 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 177: return "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 178: return "Mostly cloudy and cooler. Precipitation possibly heavy at times and ending within 12 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 179: return "Partly cloudy with little temperature change.";break;
case 180: return "Mostly clear with little temperature change.";break;
case 181: return "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hrs., possibly heavy at times. Windy with possible wind shift to the W, NW, or N.";break;
case 182: return "Mostly cloudy with little temperature change. Precipitation ending within 12 hrs. Windy with possible wind shift to the W, NW, or N.";break;
case 183: return "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hrs., possibly heavy at times. Windy with possible wind shift to the W, NW, or N.";break;
case 184: return "Mostly cloudy and cooler. Precipitation continuing.";break;
case 185: return "Partly cloudy with little temperature change.";break;
case 186: return "Mostly clear with little temperature change.";break;
case 187: return "Mostly cloudy and cooler. Precipitation likely, windy with possible wind shift to the W, NW, or N.";break;
case 188: return "Mostly cloudy with little temperature change. Precipitation continuing.";break;
case 189: return "Mostly cloudy with little temperature change. Precipitation likely.";break;
case 190: return "Partly cloudy with little temperature change.";break;
case 191: return "Mostly clear with little temperature change.";break;
case 192: return "Mostly cloudy and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy.";break;
case 193: return "FORECAST REQUIRES 3 HRS. OF RECENT DATA";break;
case 194: return "Mostly clear and cooler.";break;
default: return '---'; break;
jeedom.cmd.addUpdateFunction('#id#', function(_options) {
if (is_object(cmd = document.querySelector('.cmd[data-cmd_uid="#uid#"]'))) {
cmd.querySelector('.content-xs').setAttribute('title', '{{Date de valeur}}: ' + _options.valueDate + '<br>{{Date de collecte}}: ' + _options.collectDate)
if ('#time#' == 'duration' || '#time#' == 'date') {
jeedom.cmd.displayDuration(_options.valueDate, cmd.querySelector('.timeCmd'), '#time#')
cmd.querySelector('.value').innerHTML = forecast(_options.display_value);
cmd.querySelector('.unit').innerHTML = _options.unit
if (_options.alertLevel == 'warning') {
cmd.querySelector('.value').innerHTML = '<span class="label label-warning"><i class="fas fa-bell"></i> ' + _options.value + '</span>'
} else if (_options.alertLevel == 'danger') {
cmd.querySelector('.value').innerHTML = '<span class="label label-danger"><i class="fas fa-exclamation"></i> ' + _options.value + '</span>'
jeedom.cmd.refreshValue([{ cmd_id: '#id#', value: '#value#', display_value: '#state#', valueDate: '#valueDate#', collectDate: '#collectDate#', alertLevel: '#alertLevel#', unit: '#unite#' }])
</script>
</div>
A sauvegarder dans data/customTemplates/dashboard/
La cmd à créer dans le plugin script:
