Scan des domaines
Je rencontre un soucis avec ce plugin.
Depuis le mois d’août, il ne renouvelle pas mes noms de domaine et ne semble plus établir la connexion.
Je viens de supprimer puis réinstaller le plugin, et je constate que rien n’apparait après le scan.
Voici les logs :
log update :
Launch install of noip dependencies
-- Current OS version :
Description:	Debian GNU/Linux 10 (buster)
-- Updating repo...
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster-updates InRelease
Get:3 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
Get:5 http://security.debian.org/debian-security buster/updates/main Sources [347 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [551 kB]
Get:7 http://security.debian.org/debian-security buster/updates/main Translation-en [294 kB]
Fetched 1227 kB in 3s (421 kB/s)
Reading package lists...
-- Installation of python3 and dependencies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
The following packages were automatically installed and are no longer required:
  python-bcrypt python-blinker python-fasteners python-jwt python-lockfile
  python-monotonic python-nacl python-oauthlib python-paramiko python-pexpect
  python-ptyprocess python-pyasn1
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
-- Installed version of Python :
Python 3.7.3
  Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
python-requests is already the newest version (2.21.0-1+deb10u1).
-- Installation of chromium
E: Unable to locate package chromium-chromedriver
chromium-driver is already the newest version (90.0.4430.212-1~deb10u1).
Package chromium-browser is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'chromium-browser' has no installation candidate
-- Installed version of pip :
pip 23.2.1 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
-- Installation of python library 'selenium' with command pip3.7
DEPRECATION: reportbug 7.5.3-deb10u1 has a non-standard version number. pip 23.3 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of reportbug or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
cat: /tmp/jeedom/noip/dependancy_noip: No such file or directory
-- Installation of dependencies is done !
et enfin les logs du plugin:
[2023-09-12 14:08:19]INFO : Début de synchronisation
[2023-09-12 14:08:19]INFO : Starting daemon with cmd >>python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user *@gmail.com --pwd "***************" --threshold 6 --renew 0 --noip_path /var/www/html/plugins/noip/core/class/../..<<
[2023-09-12 14:08:19]INFO : Log level : info
[2023-09-12 14:08:19]INFO : User : *@gmail.com
[2023-09-12 14:08:19]INFO : Threshold : 6
[2023-09-12 14:08:19]INFO : Renew : 0
[2023-09-12 14:08:20]ERROR : Exception has been thrown. Timeout value connect was , but it must be an int, float or None.
[2023-09-12 14:08:21]ERROR : [appareillage][No-IP] file content empty
[2023-09-12 14:08:21]INFO : Fin de la synchronisation
[2023-09-12 14:16:08]INFO : Début d'activation du plugin
[2023-09-12 14:16:09]INFO : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2023-09-12 14:18:09]INFO : Début de synchronisation
[2023-09-12 14:18:09]INFO : Starting daemon with cmd >>python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user *@gmail.com --pwd "***************" --threshold 7 --renew 0 --noip_path /var/www/html/plugins/noip/core/class/../..<<
[2023-09-12 14:18:10]INFO : Log level : info
[2023-09-12 14:18:10]INFO : User : *@gmail.com
[2023-09-12 14:18:10]INFO : Threshold : 7
[2023-09-12 14:18:10]INFO : Renew : 0
[2023-09-12 14:18:11]ERROR : Exception has been thrown. Timeout value connect was , but it must be an int, float or None.
[2023-09-12 14:18:11]ERROR : [appareillage][NO-IP] file content empty
[2023-09-12 14:18:11]INFO : Fin de la synchronisation
[2023-09-12 14:31:20]INFO : Starting daemon with cmd >>python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user *@gmail.com --pwd "***************" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../..<<
[2023-09-12 14:31:20]INFO : Log level : info
[2023-09-12 14:31:20]INFO : User : *@gmail.com
[2023-09-12 14:31:20]INFO : Threshold : 7
[2023-09-12 14:31:20]INFO : Renew : 1
[2023-09-12 14:31:21]ERROR : Exception has been thrown. Timeout value connect was , but it must be an int, float or None.
[2023-09-12 14:31:21]ERROR : [appareillage][NO-IP] file content empty
[2023-09-12 14:32:53]INFO : Début de synchronisation
[2023-09-12 14:32:53]INFO : Starting daemon with cmd >>python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user *@gmail.com --pwd "***************" --threshold 7 --renew 0 --noip_path /var/www/html/plugins/noip/core/class/../..<<
[2023-09-12 14:32:54]INFO : Log level : info
[2023-09-12 14:32:54]INFO : User : *@gmail.com
[2023-09-12 14:32:54]INFO : Threshold : 7
[2023-09-12 14:32:54]INFO : Renew : 0
[2023-09-12 14:32:55]ERROR : Exception has been thrown. Timeout value connect was , but it must be an int, float or None.
[2023-09-12 14:32:55]ERROR : [appareillage][NO-IP] file content empty
[2023-09-12 14:32:55]INFO : Fin de la synchronisation
Merci pour votre aide !
pour partager des logs (de façon globale sur le forum), peux tu utiliser le bouton « texte préformaté » (bouton </>), afin que va soit plus lisible stp ?
merci,
J’ai le même soucis.
J’ai mis à jour les dépendances, mais j’ai toujours cette erreur :
Le log complet :
[2023-10-10 14:58:30]DEBUG : Execution de la commande refresh
[2023-10-10 14:58:30]INFO : Starting daemon with cmd >>python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel debug --user ***@gmail.com --pwd "***********" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../..<<
[2023-10-10 14:58:32]INFO : Log level : debug
[2023-10-10 14:58:32]INFO : User : ***@gmail.com
[2023-10-10 14:58:32]INFO : Threshold : 7
[2023-10-10 14:58:32]INFO : Renew : 1
[2023-10-10 14:58:32]DEBUG : POST http://localhost:47299/session {"capabilities": {"firstMatch": [{}], "alwaysMatch": {"browserName": "chrome", "pageLoadStrategy": "normal", "goog:chromeOptions": {"extensions": [], "args": ["disable-features=VizDisplayCompositor", "headless", "no-sandbox", "window-size=1200x800", "user-agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:64.0) Gecko/20100101 Firefox/64.0"]}}}, "desiredCapabilities": {"browserName": "chrome", "pageLoadStrategy": "normal", "goog:chromeOptions": {"extensions": [], "args": ["disable-features=VizDisplayCompositor", "headless", "no-sandbox", "window-size=1200x800", "user-agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:64.0) Gecko/20100101 Firefox/64.0"]}}}
[2023-10-10 14:58:32]ERROR : Exception has been thrown. Timeout value connect was , but it must be an int, float or None.
[2023-10-10 14:58:32]DEBUG : [Surveillance IP][No-Ip] file content:
[2023-10-10 14:58:32]ERROR : [Surveillance IP][No-Ip] file content empty
[2023-10-10 14:59:12]DEBUG : Task 'syncNoIp' executed now
[2023-10-10 14:59:13]INFO : Début de synchronisation
[2023-10-10 14:59:13]INFO : Starting daemon with cmd >>python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel debug --user ***@gmail.com --pwd "***" --threshold 7 --renew 0 --noip_path /var/www/html/plugins/noip/core/class/../..<<
[2023-10-10 14:59:14]INFO : Log level : debug
[2023-10-10 14:59:14]INFO : User : ***@gmail.com
[2023-10-10 14:59:14]INFO : Threshold : 7
[2023-10-10 14:59:14]INFO : Renew : 0
[2023-10-10 14:59:15]DEBUG : POST http://localhost:48367/session {"capabilities": {"firstMatch": [{}], "alwaysMatch": {"browserName": "chrome", "pageLoadStrategy": "normal", "goog:chromeOptions": {"extensions": [], "args": ["disable-features=VizDisplayCompositor", "headless", "no-sandbox", "window-size=1200x800", "user-agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:64.0) Gecko/20100101 Firefox/64.0"]}}}, "desiredCapabilities": {"browserName": "chrome", "pageLoadStrategy": "normal", "goog:chromeOptions": {"extensions": [], "args": ["disable-features=VizDisplayCompositor", "headless", "no-sandbox", "window-size=1200x800", "user-agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:64.0) Gecko/20100101 Firefox/64.0"]}}}
[2023-10-10 14:59:15]ERROR : Exception has been thrown. Timeout value connect was , but it must be an int, float or None.
[2023-10-10 14:59:15]DEBUG : [Surveillance IP][No-Ip] file content:
[2023-10-10 14:59:15]ERROR : [Surveillance IP][No-Ip] file content empty
[2023-10-10 14:59:15]INFO : Fin de la synchronisation
Bonjour a tous j’ai exactement le même sosie que vous :pensive:, Quelqu’un a t’il trouvez une piste
à cloturer @GrosJo
merci
