D’accord merci.
J’ai un peu avancé en passant le projet Google de Test à Production.
Voici les logs à ce stade:
[2024-05-14 23:02:47][ALERT] : Starting task (Backup_GDrive/Backup_Gdrive #1558)
[2024-05-14 23:02:57][ERROR] : Erreur exécution de la commande [Aucun][Backup_GDrive][Backup_Gdrive] : Task finished on Error (Backup_GDrive/Backup_Gdrive #1558)
[2024-05-14 23:03:53][ALERT] : Starting task (Backup_GDrive/Backup_Gdrive #1558)
[2024-05-14 23:04:03][ERROR] : Erreur exécution de la commande [Aucun][Backup_GDrive][Backup_Gdrive] : Task finished on Error (Backup_GDrive/Backup_Gdrive #1558)
En Debug
[2024-05-14 23:18:40][DEBUG] : execute:: options:NULL
[2024-05-14 23:18:40][DEBUG] : execute:: this:cloudsyncproCmd::__set_state(array( 'id' => '1558', 'logicalId' => NULL, 'generic_type' => NULL, 'eqType' => 'cloudsyncpro', 'name' => 'Backup_Gdrive', 'order' => '0', 'type' => 'action', 'subType' => 'other', 'eqLogic_id' => '110', 'isHistorized' => '0', 'unite' => '', 'configuration' => array ( 'command' => 'copy', 'source' => '/var/www/html/backup', 'destination' => '/sauvegarde Jeedom', 'include' => '*.gz', 'exclude' => '', 'minage' => '', 'maxage' => '', ), 'template' => '{"dashboard":"core::default","mobile":"core::default"}', 'display' => '{"showStatsOnmobile":0,"showStatsOndashboard":0}', 'value' => NULL, 'isVisible' => '1', 'alert' => '[]', '_collectDate' => '', '_valueDate' => '', '_eqLogic' => cloudsyncpro::__set_state(array( 'id' => '110', 'name' => 'Backup_GDrive', 'logicalId' => '', 'generic_type' => NULL, 'object_id' => NULL, 'eqType_name' => 'cloudsyncpro', 'isVisible' => '1', 'isEnable' => '1', 'configuration' => '{"createtime":"2020-08-27 11:02:21","comment":"","type":"drive","updatetime":"2024-05-14 23:03:38","client_id":"10282093541-2nka3viaggfkubrh3a380klc6th0em8r.apps.googleusercontent.com","client_secret":"--eROPQuebN7jPjCWDmYj1vG7w0se","expiry":1715724217,"access_token":"ya29.a0AXooCgveDD596sot6HJWlUytL-UJ9tQj3spi9hkTkd--lxukhCFv8oyeTu6nnax9WhsJq3nnxK3xFZw4EDOkZ5u458U56CkaTGlyFcf7aMMaspWmnBG2E4BqVF0sjV0HsdQ9oRpnyu_KA3QKuMhEXKdKU-k3-BlZheB0aCgYKAZkSARMSFQHGX2MiUdA8tA013IHcJVfmm88VaQ0171","refresh_token":"1\/\/03y40ZN0d36VvCgYIARAAGAMSNwF-L9IrFxHW9C63Wy0nOwb7ZIJmFwpPjcgX2SkLG-hkg7gecoQg8fwCRFKZxOoKMhJQ4Tn6QXQ"}', 'timeout' => NULL, 'category' => '{"heating":"0","security":"0","energy":"0","light":"0","automatism":"0","multimedia":"0","default":"0","opening":"0"}', 'display' => '{"height":"110px","width":"230px"}', 'order' => '9999', 'comment' => NULL, 'tags' => NULL, '_debug' => false, '_object' => NULL, '_needRefreshWidget' => false, '_timeoutUpdated' => false, '_batteryUpdated' => false, '_changed' => false, )), '_needRefreshWidget' => NULL, '_needRefreshAlert' => NULL, '_changed' => false, ))
[2024-05-14 23:18:40][DEBUG] : execute:: this:array ( 'command' => 'copy', 'source' => '/var/www/html/backup', 'destination' => '/sauvegarde Jeedom', 'include' => '*.gz', 'exclude' => '', 'minage' => '', 'maxage' => '', )
[2024-05-14 23:18:40][ALERT] : Starting task (Backup_GDrive/Backup_Gdrive #1558)
[2024-05-14 23:18:40][DEBUG] : execute:: pid:'81743' rclone:'/var/www/html/plugins/cloudsyncpro/3rparty/rclone-v1.57.0-linux-arm64/rclone -v --log-file /var/www/html/core/class/../../log/cloudsyncpro.#1558 --config /var/www/html/plugins/cloudsyncpro/data/rclone.conf --filter \'+ *.gz\' --filter \'- *\' copy \'/var/www/html/backup\' 110:\'/sauvegarde Jeedom\''
[2024-05-14 23:18:50][DEBUG] : execute:: value:', accessNotConfigured '
[2024-05-14 23:18:50][DEBUG] : execute:: value:'] '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' } '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "reason": "SERVICE_DISABLED" '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' }, '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "service": "drive.googleapis.com" '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "consumer": "projects/10282093541", '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "metadata": { '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "domain": "googleapis.com", '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "@type": "type.googleapis.com/google.rpc.ErrorInfo", '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' { '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' ] '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "url": "https://console.developers.google.com/apis/api/drive.googleapis.com/overview?project=10282093541" '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "description": "Google developers console API activation", '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "links": [ '
[2024-05-14 23:18:50][DEBUG] : execute:: value:' "@type": "type.googleapis.com/google.rpc.Help", '
[2024-05-14 23:18:50][DEBUG] : execute:: value:'[ '
[2024-05-14 23:18:50][DEBUG] : execute:: value:'Details: '
[2024-05-14 23:18:50][DEBUG] : execute:: value:'2024/05/14 23:18:41 Failed to create file system for "110:/sauvegarde Jeedom": couldn\'t find root directory ID: googleapi: Error 403: Google Drive API has not been used in project 1028209354171 before or it is disabled. Enable it by visiting https://console.developers.google.com/apis/api/drive.googleapis.com/overview?project=10282093541 then retry. If you enabled this API recently, wait a few minutes for the action to propagate to our systems and retry. '
[2024-05-14 23:18:50][DEBUG] : execute:: statistics:array ( 'Errors' => NULL, 'Checks' => NULL, 'Transferred' => NULL, 'Elapsed time' => NULL, )
[2024-05-14 23:18:50][ERROR] : Erreur exécution de la commande [Aucun][Backup_GDrive][Backup_Gdrive] : Task finished on Error (Backup_GDrive/Backup_Gdrive #1558)
