### What happened?
I am working on setting up the Conbee III. I have tried all …three versions of firmware released. I have a test network with the latest-dev tagged image from Docker. I have a single Philips Hue light to test with. When I use the SkyConnect or Sonoff adapters with EZSP, there are no issues at all. If I try the Conbee III, the device joins and after joining it does not get anymore messages from the adapter.
### What did you expect to happen?
For the Conbee III to work like the other adapters
### How to reproduce it (minimal and precise)
New Z2M install.
Connect Conbee III and configure the network.
Join Philips Hue light.
Try to have the light do anything.
### Zigbee2MQTT version
1.35.3-dev commit: 55653c9
### Adapter firmware version
0x26450900 and 0x264e0900 and 0x264f0900
### Adapter
Conbee III
### Setup
Docker
### Debug log
debug 2024-02-08 12:29:02: Publishing 'set' 'color' to '0x001788010d18eaf6'
debug 2024-02-08 12:29:05: Received MQTT message on 'zigbee2mqtt/0x001788010d18eaf6/set' with data '{"state":"OFF"}'
debug 2024-02-08 12:29:05: Publishing 'set' 'state' to '0x001788010d18eaf6'
error 2024-02-08 12:29:09: Publish 'set' 'color' to '0x001788010d18eaf6' failed: 'Error: Command 0x001788010d18eaf6/11 lightingColorCtrl.moveToColor({"transtime":0,"colorx":8880,"colory":2615}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (16))'
debug 2024-02-08 12:29:09: Error: Command 0x001788010d18eaf6/11 lightingColorCtrl.moveToColor({"transtime":0,"colorx":8880,"colory":2615}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (16))
at DeconzAdapter.sendZclFrameToEndpoint (/app/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:666:23)
at Request.send (/app/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20)
at Endpoint.command (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:746:28)
at Object.convertSet (/app/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:146:13)
at Object.convertSet (/app/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1204:32)
at Publish.onMQTTMessage (/app/lib/extension/publish.ts:266:36)
at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:174:17)
error 2024-02-08 12:29:12: Publish 'set' 'color' to '0x001788010d18eaf6' failed: 'Error: Command 0x001788010d18eaf6/11 lightingColorCtrl.moveToColor({"transtime":0,"colorx":8880,"colory":2615}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (17))'
debug 2024-02-08 12:29:12: Error: Command 0x001788010d18eaf6/11 lightingColorCtrl.moveToColor({"transtime":0,"colorx":8880,"colory":2615}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (17))
error 2024-02-08 12:29:15: Publish 'set' 'state' to '0x001788010d18eaf6' failed: 'Error: Command 0x001788010d18eaf6/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (18))'
debug 2024-02-08 12:29:15: Error: Command 0x001788010d18eaf6/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (18))
at Object.convertSet (/app/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:46:17)
at Object.convertSet (/app/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1116:32)
debug 2024-02-08 12:30:39: Saving state to file /app/data/state.json
debug 2024-02-08 12:34:48: Received Zigbee message from '0x001788010d18eaf6', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"fileVersion":16785412,"imageType":287,"manufacturerCode":4107}' from endpoint 11 with groupID null
debug 2024-02-08 12:34:48: Device '0x001788010d18eaf6' requested OTA
debug 2024-02-08 12:34:48: OTA: Checking if an update is available for '0x001788010d18eaf6' (1741930V7)
debug 2024-02-08 12:34:48: OTA: Is new image available for '0x001788010d18eaf6' (1741930V7), current '{"fieldControl":0,"manufacturerCode":4107,"imageType":287,"fileVersion":16785412}'
debug 2024-02-08 12:34:48: ZigbeeOTA: Getting image metadata for '1741930V7'
debug 2024-02-08 12:34:48: ZigbeeOTA: Downloaded main index
debug 2024-02-08 12:34:48: OTA: Is new image available for '0x001788010d18eaf6' (1741930V7), latest meta '{"fileVersion":16785412,"fileSize":423942,"url":"https://otau.meethue.com/storage/ZGB_100B_011F/38f5ed2b-119a-4d6c-9852-2e6470fecf0e/100B-011F-01002004-ConfLightBLE-ModuLumV3-EFR32MG21.zigbee","sha512":"68b70b7f152b246dc34086982c2961eb5bc2a4f4c30d3276619e8db9458549177b3ea391cccaa825821268c0f4be8f86d3a1dc66d55876aa3119755ea8aabde0"}'
debug 2024-02-08 12:34:48: OTA: Update available for '0x001788010d18eaf6' (1741930V7): NO
info 2024-02-08 12:34:48: MQTT publish: topic 'zigbee2mqtt/0x001788010d18eaf6', payload '{"color_mode":"xy","linkquality":187,"power_on_behavior":null,"state":"ON","update":{"installed_version":16785412,"latest_version":16785412,"state":"idle"},"update_available":null}'
debug 2024-02-08 12:34:48: Responded to OTA request of '0x001788010d18eaf6' with 'NO_IMAGE_AVAILABLE'
