Bonsoir à tous
@Mips comme convenu un p’tit retour
Depuis deux jours ça refonctionne. J’ai débranché le rfxcom, redémarrer jeedom et rebranché le RFXcom après. Et depuis ca tourne. Va comprendre…
J’ai juste quelques erreurs dans les log. Ca pourrait etre des sondes ?
Bonne soirée
JM
[2024-02-22 21:16:32]DEBUG : Device is known id : 0D01
[2024-02-22 21:16:32]DEBUG : Send to jeedom : {'devices': {'0D0152': {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-15.2', 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}}}
[2024-02-22 21:16:32]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:16:32]DEBUG : {"devices":{"0D0152":{"packettype":"0x52","subtype":"0x0D","id":"0D01","temperature":"-15.2","humidity":54,"humidity_status":1,"battery":100,"rssi":8}}}
[2024-02-22 21:16:33]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:17:05]DEBUG : Message: 0b1100af001a53ba0a000070
[2024-02-22 21:17:05]DEBUG : Decode : 0b1100af001a53ba0a000070
[2024-02-22 21:17:05]DEBUG : Test message: 0b1100af001a53ba0a000070
[2024-02-22 21:17:05]DEBUG : PacketType: 0x11
[2024-02-22 21:17:05]DEBUG : Length: 12
[2024-02-22 21:17:05]DEBUG : Start decoding packet type 0x11
[2024-02-22 21:17:05]DEBUG : Subtype = AC KlikAanKlikUit,HomeEasyUK,Chacon,NEXA,Intertechno
[2024-02-22 21:17:05]DEBUG : Data : {'packetlen': '0x0B', 'packettype': '0x11', 'subtype': '0x00', 'seqnbr': '0xAF', 'id1': '0x00', 'filler1': '0x00', 'id2': '0x1A', 'id3': '0x53', 'id4': '0xBA', 'unitcode': 10, 'cmnd': 0, 'level': 0, 'filler2': 0, 'rssi': 7}
[2024-02-22 21:17:05]DEBUG : Decoded info : {'packettype': '0x11', 'subtype': '0x00', 'id': '001A53BA', 'unitcode': 10, 'cmnd': 0, 'level': 0.0, 'rssi': 7}
[2024-02-22 21:17:05]DEBUG : Device is known id : 001A53BA
[2024-02-22 21:17:05]DEBUG : Send to jeedom : {'devices': {'001A53BA11': {'packettype': '0x11', 'subtype': '0x00', 'id': '001A53BA', 'unitcode': 10, 'cmnd': 0, 'level': 0.0, 'rssi': 7}}}
[2024-02-22 21:17:05]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:17:05]DEBUG : {"devices":{"001A53BA11":{"packettype":"0x11","subtype":"0x00","id":"001A53BA","unitcode":10,"cmnd":0,"level":0,"rssi":7}}}
[2024-02-22 21:17:05]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:17:06]DEBUG : Message: 0b1100b0001a53ba0a000070
[2024-02-22 21:17:06]DEBUG : Decode : 0b1100b0001a53ba0a000070
[2024-02-22 21:17:06]DEBUG : Test message: 0b1100b0001a53ba0a000070
[2024-02-22 21:17:06]DEBUG : PacketType: 0x11
[2024-02-22 21:17:06]DEBUG : Length: 12
[2024-02-22 21:17:06]DEBUG : Start decoding packet type 0x11
[2024-02-22 21:17:06]DEBUG : Subtype = AC KlikAanKlikUit,HomeEasyUK,Chacon,NEXA,Intertechno
[2024-02-22 21:17:06]DEBUG : Data : {'packetlen': '0x0B', 'packettype': '0x11', 'subtype': '0x00', 'seqnbr': '0xB0', 'id1': '0x00', 'filler1': '0x00', 'id2': '0x1A', 'id3': '0x53', 'id4': '0xBA', 'unitcode': 10, 'cmnd': 0, 'level': 0, 'filler2': 0, 'rssi': 7}
[2024-02-22 21:17:06]DEBUG : Decoded info : {'packettype': '0x11', 'subtype': '0x00', 'id': '001A53BA', 'unitcode': 10, 'cmnd': 0, 'level': 0.0, 'rssi': 7}
[2024-02-22 21:17:06]DEBUG : Device is known id : 001A53BA
[2024-02-22 21:17:06]DEBUG : Send to jeedom : {'devices': {'001A53BA11': {'packettype': '0x11', 'subtype': '0x00', 'id': '001A53BA', 'unitcode': 10, 'cmnd': 0, 'level': 0.0, 'rssi': 7}}}
[2024-02-22 21:17:06]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:17:06]DEBUG : {"devices":{"001A53BA11":{"packettype":"0x11","subtype":"0x00","id":"001A53BA","unitcode":10,"cmnd":0,"level":0,"rssi":7}}}
[2024-02-22 21:17:07]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:17:07]DEBUG : Message: 0a520db10d018097360189
[2024-02-22 21:17:07]DEBUG : Decode : 0a520db10d018097360189
[2024-02-22 21:17:07]DEBUG : Test message: 0a520db10d018097360189
[2024-02-22 21:17:07]DEBUG : PacketType: 0x52
[2024-02-22 21:17:07]DEBUG : Length: 11
[2024-02-22 21:17:07]DEBUG : Start decoding packet type 0x52
[2024-02-22 21:17:07]DEBUG : Subtype = TH13 is Alecto WS1700 and compatibles
[2024-02-22 21:17:07]DEBUG : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0D', 'seqnbr': '0xB1', 'id1': '0x0D', 'id2': '0x01', 'temperaturesign': '-', 'temperature': 151, 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:17:07]DEBUG : Decoded info : {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-15.1', 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:17:07]DEBUG : Device is known id : 0D01
[2024-02-22 21:17:08]DEBUG : Send to jeedom : {'devices': {'0D0152': {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-15.1', 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}}}
[2024-02-22 21:17:08]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:17:08]DEBUG : {"devices":{"0D0152":{"packettype":"0x52","subtype":"0x0D","id":"0D01","temperature":"-15.1","humidity":54,"humidity_status":1,"battery":100,"rssi":8}}}
[2024-02-22 21:17:08]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:17:42]DEBUG : Message: 0a520db20d018095360189
[2024-02-22 21:17:42]DEBUG : Decode : 0a520db20d018095360189
[2024-02-22 21:17:42]DEBUG : Test message: 0a520db20d018095360189
[2024-02-22 21:17:42]DEBUG : PacketType: 0x52
[2024-02-22 21:17:42]DEBUG : Length: 11
[2024-02-22 21:17:42]DEBUG : Start decoding packet type 0x52
[2024-02-22 21:17:42]DEBUG : Subtype = TH13 is Alecto WS1700 and compatibles
[2024-02-22 21:17:42]DEBUG : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0D', 'seqnbr': '0xB2', 'id1': '0x0D', 'id2': '0x01', 'temperaturesign': '-', 'temperature': 149, 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:17:42]DEBUG : Decoded info : {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-14.9', 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:17:42]DEBUG : Device is known id : 0D01
[2024-02-22 21:17:43]DEBUG : Send to jeedom : {'devices': {'0D0152': {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-14.9', 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}}}
[2024-02-22 21:17:43]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:17:43]DEBUG : {"devices":{"0D0152":{"packettype":"0x52","subtype":"0x0D","id":"0D01","temperature":"-14.9","humidity":54,"humidity_status":1,"battery":100,"rssi":8}}}
[2024-02-22 21:17:43]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:20:08]DEBUG : Client connected to [127.0.0.1:46614]
[2024-02-22 21:20:08]DEBUG : Message read from socket: b'{"apikey":"thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O","cmd":"send","data":["0B1100AA0000A31C02000080"]}'
[2024-02-22 21:20:08]DEBUG : Client disconnected from [127.0.0.1:46614]
[2024-02-22 21:20:08]DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-02-22 21:20:08]DEBUG : Test message: 0B1100AA0000A31C02000080
[2024-02-22 21:20:08]DEBUG : flushOutput serial port
[2024-02-22 21:20:08]DEBUG : flushInput serial port
[2024-02-22 21:20:08]DEBUG : Write message to serial port
[2024-02-22 21:20:08]DEBUG : Write data to serial port : 0b1100aa0000a31c02000080
[2024-02-22 21:20:08]DEBUG : Write message ok : 0B1100AA0000A31C02000080
[2024-02-22 21:24:02]DEBUG : Client connected to [127.0.0.1:37478]
[2024-02-22 21:24:02]DEBUG : Message read from socket: b'{"apikey":"thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O","cmd":"send","data":["0B1100AA0000A31C02000080"]}'
[2024-02-22 21:24:02]DEBUG : Client disconnected from [127.0.0.1:37478]
[2024-02-22 21:24:02]DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-02-22 21:24:02]DEBUG : Test message: 0B1100AA0000A31C02000080
[2024-02-22 21:24:02]DEBUG : flushOutput serial port
[2024-02-22 21:24:02]DEBUG : flushInput serial port
[2024-02-22 21:24:02]DEBUG : Write message to serial port
[2024-02-22 21:24:02]DEBUG : Write data to serial port : 0b1100aa0000a31c02000080
[2024-02-22 21:24:02]DEBUG : Write message ok : 0B1100AA0000A31C02000080
[2024-02-22 21:50:23]DEBUG : Message: 00
[2024-02-22 21:50:23]DEBUG : Message: 8f3801890a520db9780100d44803690a520dba0d01808d3801890a520dbb780100d44803690a520dbc0d01808c3801890a520dbd780100d44803690a520d00be0d01808c3801890a520dbf780100d44803690a520dc00d01808b3801890a520dc10d01808a3801890a520dc20d01808a3801890a520dc3780100d3480300690a520dc40d0180893801890a520dc50d01
[2024-02-22 21:50:23]DEBUG : Decode : 8f3801890a520db9780100d44803690a520dba0d01808d3801890a520dbb780100d44803690a520dbc0d01808c3801890a520dbd780100d44803690a520d00be0d01808c3801890a520dbf780100d44803690a520dc00d01808b3801890a520dc10d01808a3801890a520dc20d01808a3801890a520dc3780100d3480300690a520dc40d0180893801890a520dc50d01
[2024-02-22 21:50:23]DEBUG : Test message: 8f3801890a520db9780100d44803690a520dba0d01808d3801890a520dbb780100d44803690a520dbc0d01808c3801890a520dbd780100d44803690a520d00be0d01808c3801890a520dbf780100d44803690a520dc00d01808b3801890a520dc10d01808a3801890a520dc20d01808a3801890a520dc3780100d3480300690a520dc40d0180893801890a520dc50d01
[2024-02-22 21:50:23]DEBUG : PacketType: 0x38
[2024-02-22 21:50:23]DEBUG : Length: 144
[2024-02-22 21:50:23]DEBUG : No decoder found
[2024-02-22 21:51:32]DEBUG : Message: 80893801890a520dc60d0180893801890a520dc7780100d34803690a520dc80d0180883801890a520dc90d010080883801890a520d700a520d1a0d0180a4350189040201aa000b11001b001600ea0a0000700a520d1c780100d04803690a520d1d0d0180a63501890a520d1e780100cf4803690a520d1f0d0180a7
[2024-02-22 21:51:32]ERROR : Error: Incoming packet not valid length (80893801890a520dc60d0180893801890a520dc7780100d34803690a520dc80d0180883801890a520dc90d010080883801890a520d700a520d1a0d0180a4350189040201aa000b11001b001600ea0a0000700a520d1c780100d04803690a520d1d0d0180a63501890a520d1e780100cf4803690a520d1f0d0180a7).
[2024-02-22 21:53:16]DEBUG : Message: 3501890a520d200d0180a73501890a520d21780100cf4803690a520d220d0180a83501890a520d23780100cf48
[2024-02-22 21:53:16]ERROR : Error: Incoming packet not valid length (3501890a520d200d0180a73501890a520d21780100cf4803690a520d220d0180a83501890a520d23780100cf48).
[2024-02-22 21:53:17]DEBUG : Message: 03690a52
[2024-02-22 21:53:17]DEBUG : Decode : 03690a52
[2024-02-22 21:53:17]DEBUG : Test message: 03690a52
[2024-02-22 21:53:17]DEBUG : PacketType: 0x69
[2024-02-22 21:53:17]DEBUG : Length: 4
[2024-02-22 21:53:17]DEBUG : No decoder found
[2024-02-22 21:53:51]DEBUG : Message: 0d240d0180a93501890a52
[2024-02-22 21:53:51]ERROR : Error: Incoming packet not valid length (0d240d0180a93501890a52).
[2024-02-22 21:53:52]DEBUG : Message: 0d25780100cf4803690a520d260d
[2024-02-22 21:53:52]DEBUG : Decode : 0d25780100cf4803690a520d260d
[2024-02-22 21:53:52]DEBUG : Test message: 0d25780100cf4803690a520d260d
[2024-02-22 21:53:52]DEBUG : PacketType: 0x25
[2024-02-22 21:53:52]DEBUG : Length: 14
[2024-02-22 21:53:52]DEBUG : No decoder found
[2024-02-22 21:53:52]DEBUG : Message: 0180
[2024-02-22 21:53:52]DEBUG : Decode : 0180
[2024-02-22 21:53:52]DEBUG : Test message: 0180
[2024-02-22 21:53:52]DEBUG : PacketType: 0x80
[2024-02-22 21:53:52]DEBUG : Length: 2
[2024-02-22 21:58:16]DEBUG : Message: a93501890a520d270d0180a93501890a520d28780100cf4803690a520d290d0180a93501890a520d2a0d0180a93501890a520d2b780100ce4803690a520d2c0d0180a83501890a520d2d0d0180a83501890a520d2e780100ce4803690a520d2f0d0180a73501890a520d30780100ce4803690a520d310d0180a73501890a520d32780100ce4803690a520d330d0180a6350189
[2024-02-22 21:58:16]ERROR : Error: Incoming packet not valid length (a93501890a520d270d0180a93501890a520d28780100cf4803690a520d290d0180a93501890a520d2a0d0180a93501890a520d2b780100ce4803690a520d2c0d0180a83501890a520d2d0d0180a83501890a520d2e780100ce4803690a520d2f0d0180a73501890a520d30780100ce4803690a520d310d0180a73501890a520d32780100ce4803690a520d330d0180a6350189).
[2024-02-22 21:58:31]DEBUG : Message: 0a520d34780100ce480369
[2024-02-22 21:58:31]DEBUG : Decode : 0a520d34780100ce480369
[2024-02-22 21:58:31]DEBUG : Test message: 0a520d34780100ce480369
[2024-02-22 21:58:31]DEBUG : PacketType: 0x52
[2024-02-22 21:58:31]DEBUG : Length: 11
[2024-02-22 21:58:31]DEBUG : Start decoding packet type 0x52
[2024-02-22 21:58:31]DEBUG : Subtype = TH13 is Alecto WS1700 and compatibles
[2024-02-22 21:58:31]DEBUG : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0D', 'seqnbr': '0x34', 'id1': '0x78', 'id2': '0x01', 'temperaturesign': '', 'temperature': 206, 'humidity': 72, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
[2024-02-22 21:58:31]DEBUG : Decoded info : {'packettype': '0x52', 'subtype': '0x0D', 'id': '7801', 'temperature': '20.6', 'humidity': 72, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
[2024-02-22 21:58:31]DEBUG : Device is known id : 7801
[2024-02-22 21:58:31]DEBUG : Send to jeedom : {'devices': {'780152': {'packettype': '0x52', 'subtype': '0x0D', 'id': '7801', 'temperature': '20.6', 'humidity': 72, 'humidity_status': 3, 'battery': 100, 'rssi': 6}}}
[2024-02-22 21:58:31]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:58:31]DEBUG : {"devices":{"780152":{"packettype":"0x52","subtype":"0x0D","id":"7801","temperature":"20.6","humidity":72,"humidity_status":3,"battery":100,"rssi":6}}}
[2024-02-22 21:58:31]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:58:32]DEBUG : Message: 0a520d350d0180a6350189
[2024-02-22 21:58:32]DEBUG : Decode : 0a520d350d0180a6350189
[2024-02-22 21:58:32]DEBUG : Test message: 0a520d350d0180a6350189
[2024-02-22 21:58:32]DEBUG : PacketType: 0x52
[2024-02-22 21:58:32]DEBUG : Length: 11
[2024-02-22 21:58:32]DEBUG : Start decoding packet type 0x52
[2024-02-22 21:58:32]DEBUG : Subtype = TH13 is Alecto WS1700 and compatibles
[2024-02-22 21:58:32]DEBUG : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0D', 'seqnbr': '0x35', 'id1': '0x0D', 'id2': '0x01', 'temperaturesign': '-', 'temperature': 166, 'humidity': 53, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:58:32]DEBUG : Decoded info : {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-16.6', 'humidity': 53, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:58:32]DEBUG : Device is known id : 0D01
[2024-02-22 21:58:33]DEBUG : Send to jeedom : {'devices': {'0D0152': {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-16.6', 'humidity': 53, 'humidity_status': 1, 'battery': 100, 'rssi': 8}}}
[2024-02-22 21:58:33]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:58:33]DEBUG : {"devices":{"0D0152":{"packettype":"0x52","subtype":"0x0D","id":"0D01","temperature":"-16.6","humidity":53,"humidity_status":1,"battery":100,"rssi":8}}}
[2024-02-22 21:58:33]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:59:07]DEBUG : Message: 0a520d360d0180a5360189
[2024-02-22 21:59:07]DEBUG : Decode : 0a520d360d0180a5360189
[2024-02-22 21:59:07]DEBUG : Test message: 0a520d360d0180a5360189
[2024-02-22 21:59:07]DEBUG : PacketType: 0x52
[2024-02-22 21:59:07]DEBUG : Length: 11
[2024-02-22 21:59:07]DEBUG : Start decoding packet type 0x52
[2024-02-22 21:59:07]DEBUG : Subtype = TH13 is Alecto WS1700 and compatibles
[2024-02-22 21:59:07]DEBUG : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0D', 'seqnbr': '0x36', 'id1': '0x0D', 'id2': '0x01', 'temperaturesign': '-', 'temperature': 165, 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:59:07]DEBUG : Decoded info : {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-16.5', 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}
[2024-02-22 21:59:07]DEBUG : Device is known id : 0D01
[2024-02-22 21:59:08]DEBUG : Send to jeedom : {'devices': {'0D0152': {'packettype': '0x52', 'subtype': '0x0D', 'id': '0D01', 'temperature': '-16.5', 'humidity': 54, 'humidity_status': 1, 'battery': 100, 'rssi': 8}}}
[2024-02-22 21:59:08]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:59:08]DEBUG : {"devices":{"0D0152":{"packettype":"0x52","subtype":"0x0D","id":"0D01","temperature":"-16.5","humidity":54,"humidity_status":1,"battery":100,"rssi":8}}}
[2024-02-22 21:59:08]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:59:41]DEBUG : Message: 0a520d37780100ce480369
[2024-02-22 21:59:41]DEBUG : Decode : 0a520d37780100ce480369
[2024-02-22 21:59:41]DEBUG : Test message: 0a520d37780100ce480369
[2024-02-22 21:59:41]DEBUG : PacketType: 0x52
[2024-02-22 21:59:41]DEBUG : Length: 11
[2024-02-22 21:59:41]DEBUG : Start decoding packet type 0x52
[2024-02-22 21:59:41]DEBUG : Subtype = TH13 is Alecto WS1700 and compatibles
[2024-02-22 21:59:41]DEBUG : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0D', 'seqnbr': '0x37', 'id1': '0x78', 'id2': '0x01', 'temperaturesign': '', 'temperature': 206, 'humidity': 72, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
[2024-02-22 21:59:41]DEBUG : Decoded info : {'packettype': '0x52', 'subtype': '0x0D', 'id': '7801', 'temperature': '20.6', 'humidity': 72, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
[2024-02-22 21:59:41]DEBUG : Device is known id : 7801
[2024-02-22 21:59:41]DEBUG : Send to jeedom : {'devices': {'780152': {'packettype': '0x52', 'subtype': '0x0D', 'id': '7801', 'temperature': '20.6', 'humidity': 72, 'humidity_status': 3, 'battery': 100, 'rssi': 6}}}
[2024-02-22 21:59:41]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-02-22 21:59:41]DEBUG : {"devices":{"780152":{"packettype":"0x52","subtype":"0x0D","id":"7801","temperature":"20.6","humidity":72,"humidity_status":3,"battery":100,"rssi":6}}}
[2024-02-22 21:59:41]DEBUG : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=thYaGh7tLrvqvTU7txQl6vVx8LWAUn3O HTTP/1.1" 200 0
[2024-02-22 21:59:42]DEBUG : Message: 0a520d380d0180a5360189
[2024-02-22 21:59:42]DEBUG : Decode : 0a520d380d0180a5360189
[2024-02-22 21:59:42]DEBUG : Test message: 0a520d380d0180a5360189
[2024-02-22 21:59:42]DEBUG : PacketType: 0x52
[2024-02-22 21:59:42]DEBUG : Length: 11
