OK
J’ai tout vidé les Log et relancé le démon du RFXCOM et curieusement c’est reparti… ??
Les Log:
rfxcom :
0000|[2024-07-26 22:30:25] INFO : Lancement démon rfxcomd : /usr/bin/python3 /var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py --device /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1Y06XE5-if00-port0 --loglevel debug --socketport 55000 --serialrate 38400 --protocol 4,18,21 --callback http://127.0.0.1:80/plugins/rfxcom/core/php/jeeRfxcom.php --apikey ZqljguiN1DTMQlcWun5L3wO7TtqvyfR8pwdmnhwhpTkTIknR --cycle 0.3 --pid /tmp/jeedom/rfxcom/deamon.pid
0001|[2024-07-26 22:30:28] INFO : Démon RFXcom lancé
0002|[2024-07-26 22:30:31] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.5","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0003|[2024-07-26 22:30:43] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":5}}}
0004|[2024-07-26 22:30:50] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0005|[2024-07-26 22:31:11] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.5","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0006|[2024-07-26 22:31:26] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":5}}}
0007|[2024-07-26 22:31:29] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0008|[2024-07-26 22:31:52] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.5","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0009|[2024-07-26 22:32:08] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0010|[2024-07-26 22:32:09] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":5}}}
0011|[2024-07-26 22:32:33] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.5","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0012|[2024-07-26 22:32:47] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0013|[2024-07-26 22:32:52] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":5}}}
0014|[2024-07-26 22:33:14] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.5","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0015|[2024-07-26 22:33:26] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0016|[2024-07-26 22:33:35] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":6}}}
0017|[2024-07-26 22:33:55] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.5","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0018|[2024-07-26 22:34:05] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0019|[2024-07-26 22:34:18] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":6}}}
0020|[2024-07-26 22:34:36] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.4","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0021|[2024-07-26 22:34:44] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0022|[2024-07-26 22:35:01] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":6}}}
0023|[2024-07-26 22:35:17] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.4","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0024|[2024-07-26 22:35:23] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0025|[2024-07-26 22:35:44] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":6}}}
0026|[2024-07-26 22:35:58] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.4","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
0027|[2024-07-26 22:36:02] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0028|[2024-07-26 22:36:27] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":6}}}
0029|[2024-07-26 22:36:39] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.4","humidity":90,"humidity_status":3,"battery":100,"rssi":6}}}
0030|[2024-07-26 22:36:41] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0031|[2024-07-26 22:37:10] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":5}}}
0032|[2024-07-26 22:37:53] DEBUG : {"devices":{"F10452":{"packettype":"0x52","subtype":"0x01","id":"F104","temperature":"21.0","humidity":76,"humidity_status":3,"battery":10,"rssi":6}}}
0033|[2024-07-26 22:37:59] DEBUG : {"devices":{"F70152":{"packettype":"0x52","subtype":"0x01","id":"F701","temperature":"22.8","humidity":75,"humidity_status":3,"battery":100,"rssi":5}}}
0034|[2024-07-26 22:38:01] DEBUG : {"devices":{"BC0252":{"packettype":"0x52","subtype":"0x01","id":"BC02","temperature":"21.4","humidity":90,"humidity_status":3,"battery":100,"rssi":5}}}
rfxcomd :
[rfxcomd.txt|attachment](upload://lUWhjsbUzQ9IzsPD595O7L8PuVY.txt) (59,8 Ko)
