Rfxcom ne demarre plus
J’ai mis aujourd’hui jeedom (qui tourne sur une machine virtuelle sur synology) à jour et depuis rfxcom ne demarre plus
Voici le rfxcomd :
0001|File "/var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py", line 23, in <module>
0002|from jeedomdaemon.base_config import BaseConfig
0003|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/__init__.py", line 1, in <module>
0004|from .base_daemon import BaseDaemon
0005|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/base_daemon.py", line 15, in <module>
0006|from .aio_connector import Publisher, Listener
0007|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/aio_connector.py", line 9, in <module>
0008|import aiohttp
0009|File "/usr/local/lib/python3.9/dist-packages/aiohttp/__init__.py", line 6, in <module>
0010|from .client import (
0011|File "/usr/local/lib/python3.9/dist-packages/aiohttp/client.py", line 87, in <module>
0012|from .connector import (
0013|File "/usr/local/lib/python3.9/dist-packages/aiohttp/connector.py", line 64, in <module>
0014|from .resolver import DefaultResolver
0015|File "/usr/local/lib/python3.9/dist-packages/aiohttp/resolver.py", line 12, in <module>
0016|import aiodns
0017|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 60, in <module>
0018|class DNSResolver:
0019|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 162, in DNSResolver
0020|) -> asyncio.Future[list[pycares.ares_query_a_result]]: ...
0021|AttributeError: module 'pycares' has no attribute 'ares_query_a_result'
0022|Traceback (most recent call last):
0023|File "/var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py", line 23, in <module>
0024|from jeedomdaemon.base_config import BaseConfig
0025|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/__init__.py", line 1, in <module>
0026|from .base_daemon import BaseDaemon
0027|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/base_daemon.py", line 15, in <module>
0028|from .aio_connector import Publisher, Listener
0029|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/aio_connector.py", line 9, in <module>
0030|import aiohttp
0031|File "/usr/local/lib/python3.9/dist-packages/aiohttp/__init__.py", line 6, in <module>
0032|from .client import (
0033|File "/usr/local/lib/python3.9/dist-packages/aiohttp/client.py", line 87, in <module>
0034|from .connector import (
0035|File "/usr/local/lib/python3.9/dist-packages/aiohttp/connector.py", line 64, in <module>
0036|from .resolver import DefaultResolver
0037|File "/usr/local/lib/python3.9/dist-packages/aiohttp/resolver.py", line 12, in <module>
0038|import aiodns
0039|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 60, in <module>
0040|class DNSResolver:
0041|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 162, in DNSResolver
0042|) -> asyncio.Future[list[pycares.ares_query_a_result]]: ...
0043|AttributeError: module 'pycares' has no attribute 'ares_query_a_result'
0044|Traceback (most recent call last):
0045|File "/var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py", line 23, in <module>
0046|from jeedomdaemon.base_config import BaseConfig
0047|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/__init__.py", line 1, in <module>
0048|from .base_daemon import BaseDaemon
0049|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/base_daemon.py", line 15, in <module>
0050|from .aio_connector import Publisher, Listener
0051|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/aio_connector.py", line 9, in <module>
0052|import aiohttp
0053|File "/usr/local/lib/python3.9/dist-packages/aiohttp/__init__.py", line 6, in <module>
0054|from .client import (
0055|File "/usr/local/lib/python3.9/dist-packages/aiohttp/client.py", line 87, in <module>
0056|from .connector import (
0057|File "/usr/local/lib/python3.9/dist-packages/aiohttp/connector.py", line 64, in <module>
0058|from .resolver import DefaultResolver
0059|File "/usr/local/lib/python3.9/dist-packages/aiohttp/resolver.py", line 12, in <module>
0060|import aiodns
0061|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 60, in <module>
0062|class DNSResolver:
0063|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 162, in DNSResolver
0064|) -> asyncio.Future[list[pycares.ares_query_a_result]]: ...
0065|AttributeError: module 'pycares' has no attribute 'ares_query_a_result'
0066|Traceback (most recent call last):
0067|File "/var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py", line 23, in <module>
0068|from jeedomdaemon.base_config import BaseConfig
0069|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/__init__.py", line 1, in <module>
0070|from .base_daemon import BaseDaemon
0071|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/base_daemon.py", line 15, in <module>
0072|from .aio_connector import Publisher, Listener
0073|File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/aio_connector.py", line 9, in <module>
0074|import aiohttp
0075|File "/usr/local/lib/python3.9/dist-packages/aiohttp/__init__.py", line 6, in <module>
0076|from .client import (
0077|File "/usr/local/lib/python3.9/dist-packages/aiohttp/client.py", line 87, in <module>
0078|from .connector import (
0079|File "/usr/local/lib/python3.9/dist-packages/aiohttp/connector.py", line 64, in <module>
0080|from .resolver import DefaultResolver
0081|File "/usr/local/lib/python3.9/dist-packages/aiohttp/resolver.py", line 12, in <module>
0082|import aiodns
0083|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 60, in <module>
0084|class DNSResolver:
0085|File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 162, in DNSResolver
0086|) -> asyncio.Future[list[pycares.ares_query_a_result]]: ...
0087|AttributeError: module 'pycares' has no attribute 'ares_query_a_result'
Merci à tous pour votre aide
Bonsoir.
Pouvez vous placer la page santé votre Jeedom ici.
Vous n’êtes peut-être pas sur Debian 12.
Ne pas hésiter à lire les derniers sujets d’un plugin avant de poster, surtout quand le titre est le même ou presque :wink:
il y a ssi rfxcom qui est nok
Merci j’arrete pas de lire des choses sur ce sujet je n’arrive a rien. je vais essayer cette solution
J’ai choisi la methode un peu bourrin, j’ai reinstallé jeddom 4.4.12 sur une machine virtuelle synology et restauré une très vieille sauvegarde. Rfxcom remarche sans probleme et meme avec gsh.J’ai donc voulu mettre a jour jeedom en version 4.5.3 et là rfxcom je refonctionne plus avec gsh
Par contre homebridge plus rien: j’ai desinstallé le pont dans Maison, j’ai lancé une réparation, j’ai ajouté le point, tous les accessoires se sont installés mais ils restent tous sans réponse.Je vais donc essayer la methode on supprime homebridge et on refait tout.
Je pense que vous n’avez pas lu le post que je vous ai indiqué qui donne la commande a exécuter pour solutioner le problème…
