2024-04-11 07:37:15] ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-04-11 07:37:18] INFO : Lancement démon rfxcomd : /usr/bin/python3 /var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py --device /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0-port0 --loglevel debug --socketport 55000 --serialrate 38400 --protocol 12,13,18,20,21,22,23 --callback http://127.0.0.1:80/plugins/rfxcom/core/php/jeeRfxcom.php --apikey RR0JvGJqJwSClMYZj4scqcNrbWBHgtLK --cycle 0.3 --pid /tmp/jeedom/rfxcom/deamon.pid
Error: importing module jeedom.jeedom
[2024-04-11 07:38:01] ERROR : Impossible de lancer le démon RFXcom, vérifiez le log rfxcmd
Informations Jeedom
Core : 4.4.3 (V4-stable)
DNS Jeedom : non
Plugin : RFXcom
Version : 2024-01-04 01:02:50 (stable)
Statut Démon : Stoppé - (2024-04-11 07:31:42)
Hello je viens d’essayer sur alpha 4.4.7 debian 12.5 a jour
root@jeedom12:~# python3 -m pip install --force-reinstall --ignore-installed --no-cache-dir pyserial
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
une idée ?
REPONSE →
cd /usr/lib/python3.11
sudo rm EXTERNALLY-MANAGED
Bonjour, je n’en doutes pas mais Loic ne sait pas quand il aura le droit de faire la mise à jour et sa dernière communication c’était pas avant la 4.5 en alpha
Pourrais tu me fournir stp les 4 fichiers corrigés en PM ?
tu vas avoir le « problème » avec tous les plugins ayant un démon python car le core installe dorénavant les dépendances dans un virtual environnement sous debian12 et plus en global
ici cela ne s’est manifesté que sur une des dépendances car les autres étaient déjà installées.
