Salut Dams, merci d’avance de ton aide, voici le log :
Tue Jul 18 2023 15:05:03 GMT+0200 (heure d’été d’Europe centrale) - Jeedom url : http://127.0.0.1:80/plugins/rflink/core/api/rflink.php?apikey=PxrseP6Nvul6eEkNctH2lpASUaSCMR6U, gwAddress : /dev/ttyUSB0
/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:121
throw e;
Error: The module ‹ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/Release/bindings.node ›
was compiled against a different Node.js version using
NODE_MODULE_VERSION 83. This version of Node.js requires
NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
the module (for instance, using npm rebuild or npm install).
at Object.Module._extensions…node (node:internal/modules/cjs/loader:1282:18)
at Module.load (node:internal/modules/cjs/loader:1076:32)
at Function.Module._load (node:internal/modules/cjs/loader:911:12)
at Module.require (node:internal/modules/cjs/loader:1100:19)
at require (node:internal/modules/cjs/helpers:108:18)
at bindings (/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:112:48)
at Object. (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (node:internal/modules/cjs/loader:1198:14)
at Object.Module._extensions…js (node:internal/modules/cjs/loader:1252:10)
at Object. (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/index.js:14:22)
at Object.Module._extensions…js (node:internal/modules/cjs/loader:1252:10) {
code: ‹ ERR_DLOPEN_FAILED ›
Je n’ai pas osé lancer la commande npm rebuild sans consulter le forum par prudence d’abord
