malgré mes recherches sur le forum, je ne parviens pas à faire fonctionner de nouveau mon RFlink, suite à une réinstallation complète de Jeedom (plantage complet!)
Il m’est impossible d’installer les dépendances. J’ai testé plusieurs solutions proposées par la communauté, mais rien ne fonctionne…
Si quelqu’un pouvait m’aider …
Début de l'installation
--2021-09-16 23:03:15-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.109.133, 185.199.111.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1510 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 1.06M=0.001s
2021-09-16 23:03:15 (1.06 MB/s) - 'dependencies.sh' saved [1510/1510]
dependencies.sh: 3: [: rflink: unexpected operator
Nodejs non installé
Get:1 http://deb.debian.org/debian buster InRelease [122 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Get:3 http://deb.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:4 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Reading package lists...
E: Repository 'http://deb.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://deb.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://deb.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
dependencies.sh: 29: dependencies.sh: [[: not found
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'nodejs' is not installed, so not removed
Package 'npm' is not installed, so not removed
dependencies.sh: 38: [: aarch64: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 14.x repo...
## Populating apt-get cache...
+ apt-get update
Error executing command, exiting
The following additional packages will be installed:
libc-ares2 libnode64 libuv1 nodejs-doc
Suggested packages:
npm
libc-ares2 libnode64 libuv1 nodejs nodejs-doc
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 6328 kB/6514 kB of archives.
After this operation, 30.7 MB of additional disk space will be used.
Ign:1 http://deb.debian.org/debian buster/main arm64 libnode64 arm64 10.21.0~dfsg-1~deb10u1
Ign:2 http://deb.debian.org/debian buster/main arm64 nodejs arm64 10.21.0~dfsg-1~deb10u1
Ign:3 http://deb.debian.org/debian buster/main arm64 nodejs-doc all 10.21.0~dfsg-1~deb10u1
Err:1 http://deb.debian.org/debian buster/main arm64 libnode64 arm64 10.21.0~dfsg-1~deb10u1
404 Not Found [IP: 2a04:4e42:6c::644 80]
Err:2 http://deb.debian.org/debian buster/main arm64 nodejs arm64 10.21.0~dfsg-1~deb10u1
Err:3 http://deb.debian.org/debian buster/main arm64 nodejs-doc all 10.21.0~dfsg-1~deb10u1
E: Failed to fetch http://deb.debian.org/debian-security/pool/updates/main/n/nodejs/libnode64_10.21.0~dfsg-1~deb10u1_arm64.deb 404 Not Found [IP: 2a04:4e42:6c::644 80]
E: Failed to fetch http://deb.debian.org/debian-security/pool/updates/main/n/nodejs/nodejs_10.21.0~dfsg-1~deb10u1_arm64.deb 404 Not Found [IP: 2a04:4e42:6c::644 80]
E: Failed to fetch http://deb.debian.org/debian-security/pool/updates/main/n/nodejs/nodejs-doc_10.21.0~dfsg-1~deb10u1_all.deb 404 Not Found [IP: 2a04:4e42:6c::644 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
dependencies.sh: 1: dependencies.sh: nodejs: not found
Version actuelle :
dependencies.sh: 60: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
Merci pour votre aide… !
