beta rechargé, log ci dessous
[2020-12-04 10:48:00][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2020-12-04 10:47:19
[2020-12-04 10:48:27][DEBUG] : >>>>Daemon Started
[2020-12-04 10:48:27][DEBUG] : Memory used :2384 ko 616 o
[2020-12-04 10:48:27][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-04 10:48:27][DEBUG] : ****** Device NOT listenable Ventilation - Class: Sonoff *****
[2020-12-04 10:48:27][DEBUG] : start retsatus
[2020-12-04 10:48:27][DEBUG] : Cmd : {"deviceid": "1000", "data": {}}
[2020-12-04 10:48:27][DEBUG] : Receive after decode :{"seq":212,"error":0,"data":{"switch":"on","startup":"stay","pulse":"off","pulseWidth":500,"ssid":"FontLouis","otaUnlock":false,"fwVersion":"3.6.0","deviceid":"1000aa2885","bssid":"60:32:b1:99:d9:f7","signalStrength":-26}}
[2020-12-04 10:48:27][DEBUG] : end getsatus
[2020-12-04 10:48:27][DEBUG] : return:$res
[2020-12-04 10:48:27][DEBUG] : Start update
[2020-12-04 10:48:27][DEBUG] : state OK
[2020-12-04 10:48:27][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-04 10:48:27][DEBUG] : Memory used :2495 ko 248 o
[2020-12-04 10:48:37][DEBUG] : Cmd : {"deviceid": "1000", "data": {"switch": "on"}}
[2020-12-04 10:48:37][DEBUG] : Receive after decode :{"seq":212,"error":0}
[2020-12-04 10:48:37][DEBUG] : - name:eWeLink_1000aa2885._ewelink._tcp.local - packet:8081 ip:192.168.0.31 data:{"txtvers":"1","id":"1000aa2885","type":"diy_plug","apivers":"1","seq":"212","data1":"{"switch":"on","startup":"stay","pulse":"off","sledOnline":"on","fwVersion":"3.6.0","pulseWidth":500,"rssi":-26}"} - End mDNS
[2020-12-04 10:48:38][DEBUG] : - name:eWeLink_1000aa2885._ewelink._tcp.local - packet:8081 ip:192.168.0.31 data:{"txtvers":"1","id":"1000aa2885","type":"diy_plug","apivers":"1","seq":"212","data1":"{"switch":"on","startup":"stay","pulse":"off","sledOnline":"on","fwVersion":"3.6.0","pulseWidth":500,"rssi":-26}"} - End mDNS
[2020-12-04 10:48:41][DEBUG] : Cmd : {"deviceid": "1000", "data": {"switch": "off"}}
[2020-12-04 10:48:41][DEBUG] : - name:eWeLink_1000aa2885._ewelink._tcp.local - packet:8081 ip:192.168.0.31 data:{"txtvers":"1","id":"1000aa2885","type":"diy_plug","apivers":"1","seq":"213","data1":"{"switch":"off","startup":"stay","pulse":"off","sledOnline":"on","fwVersion":"3.6.0","pulseWidth":500,"rssi":-26}"} - End mDNS
[2020-12-04 10:48:41][DEBUG] : Receive after decode :{"seq":213,"error":0}
[2020-12-04 10:48:42][DEBUG] : - name:eWeLink_1000aa2885._ewelink._tcp.local - packet:8081 ip:192.168.0.31 data:{"txtvers":"1","id":"1000aa2885","type":"diy_plug","apivers":"1","seq":"213","data1":"{"switch":"off","startup":"stay","pulse":"off","sledOnline":"on","fwVersion":"3.6.0","pulseWidth":500,"rssi":-26}"} - End mDNS
[2020-12-04 10:48:43][DEBUG] : - name:eWeLink_1000aa2885._ewelink._tcp.local - packet:8081 ip:192.168.0.31 data:{"txtvers":"1","id":"1000aa2885","type":"diy_plug","apivers":"1","seq":"213","data1":"{"switch":"off","startup":"stay","pulse":"off","sledOnline":"on","fwVersion":"3.6.0","pulseWidth":500,"rssi":-26}"} - End mDNS
