Suite a l’achat de Smart Air Box
j’ai du suivre la procédure d’intégration de zigbee2mqtt pour que ce produit soit reconnu.
à faire :
créer dans le même dossier que configuration.yaml
un fichier SEA802-Zigbee.js
contenu du fichier :
edit swap du dp 2 et 22
const fz = require("zigbee-herdsman-converters/converters/fromZigbee");
const tz = require("zigbee-herdsman-converters/converters/toZigbee");
const exposes = require("zigbee-herdsman-converters/lib/exposes");
const {
calibrateAndPrecisionRoundOptions,
} = require("zigbee-herdsman-converters/lib/utils");
const reporting = require("zigbee-herdsman-converters/lib/reporting");
const extend = require("zigbee-herdsman-converters/lib/extend");
const tuya = require("zigbee-herdsman-converters/lib/tuya");
const e = exposes.presets;
const ea = exposes.access;
const definition = {
// Since a lot of Tuya devices use the same modelID, but use different data points
// it's usually necessary to provide a fingerprint instead of a zigbeeModel
fingerprint: [
// The model ID from: Device with modelID 'TS0601' is not supported
// You may need to add \u0000 at the end of the name in some cases
modelID: "TS0601",
// The manufacturer name from: Device with modelID 'TS0601' is not supported.
// manufacturerName: "_TZE200_8ygsuhe1",
manufacturerName: "_TZE200_ryfmq5rl",
model: "SEA802-Zigbee",
vendor: "Tuya",
description: "Smart air box",
supports: "temperature, humidity",
fromZigbee: [
fz.ignore_basic_report,
cluster: "manuSpecificTuya",
type: [
"commandSetDataResponse",
"commandGetData",
"commandActiveStatusReport",
convert: (model, msg, publish, options, meta) => {
const dp = msg.data.dp;
const value = tuya.getDataValue(msg.data.datatype, msg.data.data);
switch (dp) {
case 22:
return { co2: value };
case 18:
return {
temperature: calibrateAndPrecisionRoundOptions(
value / 10.0,
options,
"temperature"
case 19:
return {
humidity: calibrateAndPrecisionRoundOptions(
value / 10.0,
options,
"humidity"
case 21:
return { hcho: value };
case 2:
return { voc: value };
default:
meta.logger.warn(`zigbee-herdsman-converters:SaswellThermostat: NOT RECOGNIZED DP #${dp} with data ${JSON.stringify(msg.data)} => (${value})`);
return null;
toZigbee: [
//tz.tuya_data_point_test, // Another debug converter
onEvent: tuya.setTime, // Add this if you are getting no converter for 'commandSetTimeRequest'
/* meta: {
configureKey: 1,
/* configure: async (device, coordinatorEndpoint, logger) => {
const endpoint = device.getEndpoint(1);
await bind(endpoint, coordinatorEndpoint, ["genBasic"]);
exposes: [e.temperature(), e.humidity(), e.co2(), e.voc(), e.hcho()],
module.exports = definition;
Verifiez bien le nom du constructeur dans la ligne
(j’ai du la mettre en phase avec qui était en debug)
Une fois fait allez dans setting onglet External Converters
cliquez sur +
ajouter le nom de votre fichier js ici SEA802-Zigbee.js
puis SUBMIT
Redémarrez
setting tools restart zigbee2mqtt
Voila
Have a fun
Bon Dimanche
