[RESOLU][MQTT] pb d'erreur en boucle
j’ai un soucis je pense suite a une mauvaise creation de commande sur un sonoff en ESPeasy.
j’ai un message qui tourne en boucle sur les log du plugin MQTT:
[2019-12-09 11:30:59][ERROR] : Le nom de la commande ne peut pas être vide :MQTTCmd Object (     [id:protected] =>      [logicalId:protected] =>      [generic_type:protected] =>      [eqType:protected] => MQTT     [name:protected] =>      [order:protected] =>      [type:protected] => info     [subType:protected] => string     [eqLogic_id:protected] => 1308     [isHistorized:protected] => 0     [unite:protected] =>      [configuration:protected] => Array         (             [topic] => /ESP_chauffage_bureau/cmd/         )      [template:protected] =>      [display:protected] =>      [value:protected] =>      [isVisible:protected] => 1     [alert:protected] =>      [_collectDate:protected] =>      [_valueDate:protected] =>      [_eqLogic:protected] =>      [_needRefreshWidget:protected] =>      [_needRefreshAlert:protected] =>      [_changed:protected] => 1 )
[2019-12-09 11:31:00][ERROR] : Le nom de la commande ne peut pas être vide :MQTTCmd Object (     [id:protected] =>      [logicalId:protected] =>      [generic_type:protected] =>      [eqType:protected] => MQTT     [name:protected] =>      [order:protected] =>      [type:protected] => info     [subType:protected] => string     [eqLogic_id:protected] => 1308     [isHistorized:protected] => 0     [unite:protected] =>      [configuration:protected] => Array         (             [topic] => /ESP_chauffage_bureau/cmd/         )      [template:protected] =>      [display:protected] =>      [value:protected] =>      [isVisible:protected] => 1     [alert:protected] =>      [_collectDate:protected] =>      [_valueDate:protected] =>      [_eqLogic:protected] =>      [_needRefreshWidget:protected] =>      [_needRefreshAlert:protected] =>      [_changed:protected] => 1 )
[2019-12-09 11:31:01][ERROR] : Le nom de la commande ne peut pas être vide :MQTTCmd Object (     [id:protected] =>      [logicalId:protected] =>      [generic_type:protected] =>      [eqType:protected] => MQTT     [name:protected] =>      [order:protected] =>      [type:protected] => info     [subType:protected] => string     [eqLogic_id:protected] => 1308     [isHistorized:protected] => 0     [unite:protected] =>      [configuration:protected] => Array         (             [topic] => /ESP_chauffage_bureau/cmd/         )      [template:protected] =>      [display:protected] =>      [value:protected] =>      [isVisible:protected] => 1     [alert:protected] =>      [_collectDate:protected] =>      [_valueDate:protected] =>      [_eqLogic:protected] =>      [_needRefreshWidget:protected] =>      [_needRefreshAlert:protected] =>      [_changed:protected] => 1 )
je ne sais pas comment arreter ca!
j’ai arreté le plugin redemarrer mosquitto faire un reboot de mon jeedom
tout ca sans succés le plugin tourne en rond
si quelqu’un a une solution je suis preneur merci d’avance
Tu as lu ton log ?
Il se plaint d’un nom vide, et ton topic fini par /
CQFD, corrige ton topic, rien à voir avec le plugin, un topic MQTT ne fini pas par /
Merci pour ton retour
j’ai reglé le probleme en virant les topics inutilisés
