RPI3B+
root SSD
jeedom v4.0.49
Linux Jeedom 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux [9.9]
Clé Conbee 2 FW 0x264a0700
Dernière version Deconz
Je viens de m’acheter une clé conbee 2
Je n’arrive pas à inclure un seul appareil.
Pour info mes appareils sont des interrupteurs aqara
J’ai suivi la doc, la clé apparaît bien, les dépendances sont OK.
Quand je me mets en inclusion pour la première fois j’ai un appareil (conbee) qui se crée tout seul
On dirait que quelque-chose cloche dans l’installation
* Installation deconz *
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Hit:3 https://deb.nodesource.com/node_12.x stretch InRelease
Fetched 25.4 kB in 2s (9605 B/s)
Reading package lists...
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
It's armv7l, RPI
--2020-04-09 17:25:07-- https://images.jeedom.com/resources/deconz/rpi/deconz.deb
Resolving images.jeedom.com (images.jeedom.com)... 213.32.73.75
Connecting to images.jeedom.com (images.jeedom.com)|213.32.73.75|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5251098 (5.0M) [application/x-debian-package]
Saving to: '/tmp/deconz.deb'
0K .......... .......... .......... .......... .......... 0% 1.64M 3s
50K .......... .......... .......... .......... .......... 1% 4.27M 2s
100K .......... .......... .......... .......... .......... 2% 9.92M 2s
150K .......... .......... .......... .......... .......... 3% 4.50M 1s
200K .......... .......... .......... .......... .......... 4% 3.45M 1s
250K .......... .......... .......... .......... .......... 5% 8.25M 1s
300K .......... .......... .......... .......... .......... 6% 8.97M 1s
350K .......... .......... .......... .......... .......... 7% 2.98M 1s
400K .......... .......... .......... .......... .......... 8% 6.79M 1s
450K .......... .......... .......... .......... .......... 9% 9.80M 1s
500K .......... .......... .......... .......... .......... 10% 10.8M 1s
550K .......... .......... .......... .......... .......... 11% 6.72M 1s
600K .......... .......... .......... .......... .......... 12% 9.65M 1s
650K .......... .......... .......... .......... .......... 13% 8.53M 1s
700K .......... .......... .......... .......... .......... 14% 9.46M 1s
750K .......... .......... .......... .......... .......... 15% 9.90M 1s
800K .......... .......... .......... .......... .......... 16% 8.15M 1s
850K .......... .......... .......... .......... .......... 17% 10.9M 1s
900K .......... .......... .......... .......... .......... 18% 7.01M 1s
950K .......... .......... .......... .......... .......... 19% 7.80M 1s
1000K .......... .......... .......... .......... .......... 20% 7.74M 1s
1050K .......... .......... .......... .......... .......... 21% 10.4M 1s
1100K .......... .......... .......... .......... .......... 22% 10.1M 1s
1150K .......... .......... .......... .......... .......... 23% 562K 1s
1200K .......... .......... .......... .......... .......... 24% 7.97M 1s
1250K .......... .......... .......... .......... .......... 25% 9.83M 1s
1300K .......... .......... .......... .......... .......... 26% 2.74M 1s
1350K .......... .......... .......... .......... .......... 27% 8.94M 1s
1400K .......... .......... .......... .......... .......... 28% 7.88M 1s
1450K .......... .......... .......... .......... .......... 29% 9.12M 1s
1500K .......... .......... .......... .......... .......... 30% 9.59M 1s
1550K .......... .......... .......... .......... .......... 31% 8.13M 1s
1600K .......... .......... .......... .......... .......... 32% 9.48M 1s
1650K .......... .......... .......... .......... .......... 33% 8.48M 1s
1700K .......... .......... .......... .......... .......... 34% 10.1M 1s
1750K .......... .......... .......... .......... .......... 35% 9.12M 1s
1800K .......... .......... .......... .......... .......... 36% 7.42M 1s
1850K .......... .......... .......... .......... .......... 37% 7.38M 1s
1900K .......... .......... .......... .......... .......... 38% 7.12M 1s
1950K .......... .......... .......... .......... .......... 39% 9.81M 1s
2000K .......... .......... .......... .......... .......... 39% 5.77M 1s
2050K .......... .......... .......... .......... .......... 40% 7.71M 1s
2100K .......... .......... .......... .......... .......... 41% 10.9M 1s
2150K .......... .......... .......... .......... .......... 42% 8.84M 1s
2200K .......... .......... .......... .......... .......... 43% 10.5M 1s
2250K .......... .......... .......... .......... .......... 44% 9.83M 1s
2300K .......... .......... .......... .......... .......... 45% 9.42M 0s
2350K .......... .......... .......... .......... .......... 46% 486K 1s
2400K .......... .......... .......... .......... .......... 47% 8.34M 1s
2450K .......... .......... .......... .......... .......... 48% 3.15M 1s
2500K .......... .......... .......... .......... .......... 49% 7.34M 1s
2550K .......... .......... .......... .......... .......... 50% 5.87M 1s
2600K .......... .......... .......... .......... .......... 51% 5.64M 1s
2650K .......... .......... .......... .......... .......... 52% 8.11M 1s
2700K .......... .......... .......... .......... .......... 53% 6.28M 0s
2750K .......... .......... .......... .......... .......... 54% 6.61M 0s
2800K .......... .......... .......... .......... .......... 55% 7.97M 0s
2850K .......... .......... .......... .......... .......... 56% 5.53M 0s
2900K .......... .......... .......... .......... .......... 57% 7.73M 0s
2950K .......... .......... .......... .......... .......... 58% 7.13M 0s
3000K .......... .......... .......... .......... .......... 59% 5.20M 0s
3050K .......... .......... .......... .......... .......... 60% 8.25M 0s
3100K .......... .......... .......... .......... .......... 61% 4.08M 0s
3150K .......... .......... .......... .......... .......... 62% 9.16M 0s
3200K .......... .......... .......... .......... .......... 63% 9.70M 0s
3250K .......... .......... .......... .......... .......... 64% 7.85M 0s
3300K .......... .......... .......... .......... .......... 65% 6.79M 0s
3350K .......... .......... .......... .......... .......... 66% 5.83M 0s
3400K .......... .......... .......... .......... .......... 67% 8.45M 0s
3450K .......... .......... .......... .......... .......... 68% 7.15M 0s
3500K .......... .......... .......... .......... .......... 69% 7.18M 0s
3550K .......... .......... .......... .......... .......... 70% 686K 0s
3600K .......... .......... .......... .......... .......... 71% 6.08M 0s
3650K .......... .......... .......... .......... .......... 72% 9.90M 0s
3700K .......... .......... .......... .......... .......... 73% 6.93M 0s
3750K .......... .......... .......... .......... .......... 74% 10.9M 0s
3800K .......... .......... .......... .......... .......... 75% 7.98M 0s
3850K .......... .......... .......... .......... .......... 76% 6.67M 0s
3900K .......... .......... .......... .......... .......... 77% 10.7M 0s
3950K .......... .......... .......... .......... .......... 78% 7.99M 0s
4000K .......... .......... .......... .......... .......... 78% 11.0M 0s
4050K .......... .......... .......... .......... .......... 79% 8.23M 0s
4100K .......... .......... .......... .......... .......... 80% 8.29M 0s
4150K .......... .......... .......... .......... .......... 81% 6.17M 0s
4200K .......... .......... .......... .......... .......... 82% 6.36M 0s
4250K .......... .......... .......... .......... .......... 83% 5.84M 0s
4300K .......... .......... .......... .......... .......... 84% 7.47M 0s
4350K .......... .......... .......... .......... .......... 85% 6.88M 0s
4400K .......... .......... .......... .......... .......... 86% 7.12M 0s
4450K .......... .......... .......... .......... .......... 87% 7.16M 0s
4500K .......... .......... .......... .......... .......... 88% 11.1M 0s
4550K .......... .......... .......... .......... .......... 89% 9.00M 0s
4600K .......... .......... .......... .......... .......... 90% 9.75M 0s
4650K .......... .......... .......... .......... .......... 91% 10.6M 0s
4700K .......... .......... .......... .......... .......... 92% 8.80M 0s
4750K .......... .......... .......... .......... .......... 93% 473K 0s
4800K .......... .......... .......... .......... .......... 94% 8.48M 0s
4850K .......... .......... .......... .......... .......... 95% 10.3M 0s
4900K .......... .......... .......... .......... .......... 96% 5.92M 0s
4950K .......... .......... .......... .......... .......... 97% 10.5M 0s
5000K .......... .......... .......... .......... .......... 98% 8.79M 0s
5050K .......... .......... .......... .......... .......... 99% 6.24M 0s
5100K .......... .......... ........ 100% 9.63M=1.1s
2020-04-09 17:25:08 (4.77 MB/s) - '/tmp/deconz.deb' saved [5251098/5251098]
dpkg: error: dpkg status database is locked by another process
Fetched 25.4 kB in 2s (8796 B/s)
* Installation terminée *
* Installation des dépendances *
Fetched 25.4 kB in 2s (9706 B/s)
Uninstalling websocket-client-0.57.0:
Successfully uninstalled websocket-client-0.57.0
Cannot uninstall requirement websocket, not installed
Requirement already satisfied: setuptools in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: wheel in /usr/lib/python3/dist-packages
Requirement already satisfied: serial in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: pyyaml>=3.13 in /usr/local/lib/python3.5/dist-packages (from serial)
Requirement already satisfied: iso8601>=0.1.12 in /usr/local/lib/python3.5/dist-packages (from serial)
Requirement already satisfied: future>=0.17.1 in /usr/local/lib/python3.5/dist-packages (from serial)
Requirement already satisfied: pyudev in /usr/lib/python3/dist-packages
Requirement already satisfied: requests in /usr/lib/python3/dist-packages
Collecting websocket-client
Using cached https://files.pythonhosted.org/packages/4c/5f/f61b420143ed1c8dc69f9eaec5ff1ac36109d52c80de49d66e0c36c3dfdf/websocket_client-0.57.0-py2.py3-none-any.whl
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from websocket-client)
Installing collected packages: websocket-client
Successfully installed websocket-client-0.57.0
