"id": "3",
"name": null,
"type": "if",
"options": [],
"order": "0",
"subElements": [
"id": "7",
"name": null,
"scenarioElement_id": "3",
"type": "if",
"subtype": "condition",
"options": {
"collapse": "0",
"enable": "1",
"allowRepeatCondition": "0"
"order": "0",
"expressions": [
"id": "10",
"scenarioSubElement_id": "7",
"type": "condition",
"subtype": null,
"expression": "#[ObjetPompe][Eq_Virtuel_Pompe][Etat]#",
"options": [],
"order": "0"
"id": "8",
"name": null,
"type": "then",
"subtype": "action",
"options": [],
"order": "1",
"expressions": [
"id": "11",
"scenarioSubElement_id": "8",
"type": "action",
"subtype": null,
"expression": "#[ObjetPompe][Mail_Pompe_Cave][Mail_pompe]#",
"options": {
"enable": "1",
"background": "0",
"title": "----- Pompe cave int\u00e9rieur enclench\u00e9e! -----",
"message": "La pompe cave int\u00e9rieur est enclench\u00e9e!\n\nD\u00e9marrage: #sjour# #jour# #smois# #annee# date('H:i')\n\nVariable: #[ObjetPompe][Eq_Virtuel_Pompe][Etat]#\n\nPuissance consomm\u00e9e: #[ObjetPompe][Prise_Pompe_Interieur][Puissance]# Watt!"
"order": "0"
"id": "9",
"name": null,
"type": "else",
"options": [],
"order": "2",
"expressions": [
"id": "12",
"scenarioSubElement_id": "9",
"type": "action",
"subtype": null,
"options": {
"enable": "1",
"background": "0",
"title": "+++++ Pompe cave int\u00e9rieur arr\u00eat +++++",
"message": "La pompe cave int\u00e9rieur s'est arr\u00eat\u00e9e!\n\nArr\u00eat: #sjour# #jour# #smois# #annee# date('H:i')\n\nVariable: #[ObjetPompe][Eq_Virtuel_Pompe][Etat]#\n\nPuissance consomm\u00e9e: #[ObjetPompe][Prise_Pompe_Interieur][Puissance]# Watt!"
"order": "0"
Et si tu testes la formule de ta commande état dans le testeur d’expression, ca donne quoi ? (outils >> testeur d’expression)
Fait le test pompe allumée et eteinte
Norbert
Je ne vois pas de variable ici, à part que vous avez écrit :
Mais cela ne ferais qu’afficher ;
variable : 0 ou variable : 1
Ce n’est pas cela une variable au sens Jeedom.
C’est quelque chose que vous initiez, pour être utilisé dans un autre scénario par exemple, ou dans celui-ci (il y a des variables persistantes (variable) et des non persistantes (tag)).
j’ai suivi le conseil de ngrataloup plus haut. En passant par le plugin virtuel et un binaire.
Je confirme, plusieurs tests et ça fonctionne comme souhaité!!!
Je fais un test demain sur la pompe pour confirmer tout ça!
En tout cas merci à tous!
Je reviens demain vous donner des news!
Ravi pour toi … tu as donc vu les commandes virtuelles, les expressions booléennes et les scenarios avec déclencheurs, le testeur d’expressions…
Maintenant, tu as tout ce qu’il faut pour faire plein d’autres trucs !!!
Bon courage
Norbert
