J’ai installé le plugin Reolink en complément du plugin caméra pour avoir accés aux commandes de ma caméra E1 Zoom. L’installation c’est bien passé j’ai bien pu remonter toutes mes commandes, et je me sert essentiellement de la commande « détection de mouvement », pour déclencher mon alarme. Globalement cela marche, mais j’ai des messages d’erreur qui remontent en permanence:
J’ai filtré par « error » le log:
0053|[2024-01-31 20:00:08][DEBUG] : Réponse caméra >> [{"cmd":"GetZoomFocus","code":0,"value":{"ZoomFocus":{"channel":0,"focus":{"pos":216},"zoom":{"pos":24}}}},{"cmd":"Unknown","code":1,"error":{"detail":"notsupport","rspCode":-9}}]
0055|[2024-01-31 20:00:08][DEBUG] : Lecture info > Array([cmd]=>Unknown[code]=>1[error]=>Array([detail]=>notsupport[rspCode]=>-9))
0056|[2024-01-31 20:00:08][ERROR] : Switch command not found : Array ( [cmd] => Unknown [code] => 1 [error] => Array ( [detail] => not support [rspCode] => -9 ) )
0258|[2024-01-31 20:15:06][DEBUG] : Réponse caméra >> [{"cmd":"GetZoomFocus","code":0,"value":{"ZoomFocus":{"channel":0,"focus":{"pos":216},"zoom":{"pos":24}}}},{"cmd":"Unknown","code":1,"error":{"detail":"notsupport","rspCode":-9}}]
0260|[2024-01-31 20:15:06][DEBUG] : Lecture info > Array([cmd]=>Unknown[code]=>1[error]=>Array([detail]=>notsupport[rspCode]=>-9))
0261|[2024-01-31 20:15:06][ERROR] : Switch command not found : Array ( [cmd] => Unknown [code] => 1 [error] => Array ( [detail] => not support [rspCode] => -9 ) )
0470|[2024-01-31 20:30:08][DEBUG] : Réponse caméra >> [{"cmd":"GetZoomFocus","code":0,"value":{"ZoomFocus":{"channel":0,"focus":{"pos":216},"zoom":{"pos":24}}}},{"cmd":"Unknown","code":1,"error":{"detail":"notsupport","rspCode":-9}}]
0472|[2024-01-31 20:30:08][DEBUG] : Lecture info > Array([cmd]=>Unknown[code]=>1[error]=>Array([detail]=>notsupport[rspCode]=>-9))
0473|[2024-01-31 20:30:08][ERROR] : Switch command not found : Array ( [cmd] => Unknown [code] => 1 [error] => Array ( [detail] => not support [rspCode] => -9 ) )
Pouvez vous m’aider à trouver la cause de ces remontées
merci d’avance
