merci pour ta réponse oui peut d’info parce-que je ne vois pas d’erreurs vraiment tout semble ok voici un extrait :
Du log général:
[2022-10-14 13:45:03][DEBUG] : API Token OK
[2022-10-14 13:45:03][DEBUG] : Rafraichissement des informations de la caméra...
[2022-10-14 13:45:03][DEBUG] : Envoi 1/10 payload multiple GetSetting = {"cmd":"GetPerformance","param":{"channel":0}},{"cmd":"GetPushV20","action":0,"param":{"channel":0}}
[2022-10-14 13:45:03][DEBUG] : URL de requête => http://192.168.1.48:80/cgi-bin/api.cgi?token=e8671a31a876c24
[2022-10-14 13:45:03][DEBUG] : Payload => [{"cmd":"GetPerformance","param":{"channel":0}},{"cmd":"GetPushV20","action":0,"param":{"channel":0}}]
[2022-10-14 13:45:03][DEBUG] : HTTP code 200 OK
[2022-10-14 13:45:03][DEBUG] : Réponse caméra >> [{"cmd":"GetPerformance","code":0,"value":{"Performance":{"codecRate":6991,"cpuUsed":49,"netThroughput":0}}},{"cmd":"GetPushV20","code":0,"value":{"Push":{"enable":1,"schedule":{"channel":0,"table":{"AI_PEOPLE":"xxx","AI_VEHICLE":"xxx","MD":"xxx"}}}}}]
[2022-10-14 13:45:03][DEBUG] : Lecture info > Array([cmd]=>GetPerformance[code]=>0[value]=>Array([Performance]=>Array([codecRate]=>6991[cpuUsed]=>49[netThroughput]=>0)))
[2022-10-14 13:45:03][DEBUG] : Lecture info > Array([cmd]=>GetPushV20[code]=>0[value]=>Array([Push]=>Array([enable]=>1[schedule]=>Array([channel]=>0[table]=>Array([AI_PEOPLE]=>xx[AI_VEHICLE]=>xx[MD]=>xx)))))
[2022-10-14 13:45:03][DEBUG] : Envoi 2/10 payload multiple GetSetting = {"cmd":"GetPushCfg","action":0,"param":{"channel":0}},{"cmd":"GetRecV20","action":0,"param":{"channel":0}}
[2022-10-14 13:45:03][DEBUG] : Payload => [{"cmd":"GetPushCfg","action":0,"param":{"channel":0}},{"cmd":"GetRecV20","action":0,"param":{"channel":0}}]
[2022-10-14 13:45:03][DEBUG] : Réponse caméra >> [{"cmd":"GetPushCfg","code":0,"value":{"PushCfg":{"pushInterval":20}}},{"cmd":"GetRecV20","code":0,"value":{"Rec":{"enable":1,"overwrite":1,"packTime":"","postRec":"1Minute","preRec":1,"schedule":{"channel":0,"table":{"AI_PEOPLE":"xx","MD":"xx","TIMING":"xx"}}}}}]
[2022-10-14 13:45:03][DEBUG] : Lecture info > Array([cmd]=>GetPushCfg[code]=>0[value]=>Array([PushCfg]=>Array([pushInterval]=>20)))
[2022-10-14 13:45:03][DEBUG] : Lecture info > Array([cmd]=>GetRecV20[code]=>0[value]=>Array([Rec]=>Array([enable]=>1[overwrite]=>1[packTime]=>[postRec]=>1Minute[preRec]=>1[schedule]=>Array([channel]=>0[table]=>Array([AI_PEOPLE]=>xx[AI_VEHICLE]=>xx[MD]=>xx[TIMING]=>xx)))))
[2022-10-14 13:45:03][DEBUG] : Envoi 3/10 payload multiple GetSetting = {"cmd":"GetEmailV20","action":0,"param":{"channel":0}},{"cmd":"GetHddInfo"}
[2022-10-14 13:45:03][DEBUG] : Payload => [{"cmd":"GetEmailV20","action":0,"param":{"channel":0}},{"cmd":"GetHddInfo"}]
[2022-10-14 13:45:03][DEBUG] : Réponse caméra >> [{"cmd":"GetMdAlarm","code":0,"value":{"MdAlarm":{"channel":0,"newSens":{"sens":[{"beginHour":0,"beginMin":0,"enable":0,"endHour":0,"endMin":0,"id":0,"priority":0,"sensitivity":0},{"beginHour":0,"beginMin":0,"enable":0,"endHour":0,"endMin":0,"id":1,"priority":0,"sensitivity":0},{"beginHour":0,"beginMin":0,"enable":0,"endHour":0,"endMin":0,"id":2,"priority":0,"sensitivity":0},{"beginHour":0,"beginMin":0,"enable":0,"endHour":0,"endMin":0,"id":3,"priority":0,"sensitivity":0}],"sensDef":15},"scope":{"cols":80,"rows":60,"table":"xxx"},"sens":[{"beginHour":0,"beginMin":0,"endHour":6,"endMin":0,"id":0,"sensitivity":10},{"beginHour":6,"beginMin":0,"endHour":12,"endMin":0,"id":1,"sensitivity":10},{"beginHour":12,"beginMin":0,"endHour":18,"endMin":0,"id":2,"sensitivity":10},{"beginHour":18,"beginMin":0,"endHour":23,"endMin":59,"id":3,"sensitivity":10}],"useNewSens":1}}},{"cmd":"GetAiAlarm","code":0,"value":{"AiAlarm":{"ai_type":"people","channel":0,"max_target_height":0.0,"max_target_width":0.0,"min_target_height":0.0,"min_target_width":0.0,"scope":{"area":"xxx","cols":80,"rows":60},"sensitivity":61,"stay_time":0}}}]
[2022-10-14 13:45:03][DEBUG] : Lecture info > Array([cmd]=>GetMdAlarm[code]=>0[value]=>Array([MdAlarm]=>Array([channel]=>0[newSens]=>Array([sens]=>Array([0]=>Array([beginHour]=>0[beginMin]=>0[enable]=>0[endHour]=>0[endMin]=>0[id]=>0[priority]=>0[sensitivity]=>0)[1]=>Array([beginHour]=>0[beginMin]=>0[enable]=>0[endHour]=>0[endMin]=>0[id]=>1[priority]=>0[sensitivity]=>0)[2]=>Array([beginHour]=>0[beginMin]=>0[enable]=>0[endHour]=>0[endMin]=>0[id]=>2[priority]=>0[sensitivity]=>0)[3]=>Array([beginHour]=>0[beginMin]=>0[enable]=>0[endHour]=>0[endMin]=>0[id]=>3[priority]=>0[sensitivity]=>0))[sensDef]=>15)[scope]=>Array([cols]=>80[rows]=>60[table]=>xxx)[sens]=>Array([0]=>Array([beginHour]=>0[beginMin]=>0[endHour]=>6[endMin]=>0[id]=>0[sensitivity]=>10)[1]=>Array([beginHour]=>6[beginMin]=>0[endHour]=>12[endMin]=>0[id]=>1[sensitivity]=>10)[2]=>Array([beginHour]=>12[beginMin]=>0[endHour]=>18[endMin]=>0[id]=>2[sensitivity]=>10)[3]=>Array([beginHour]=>18[beginMin]=>0[endHour]=>23[endMin]=>59[id]=>3[sensitivity]=>10))[useNewSens]=>1)))
[2022-10-14 13:45:03][DEBUG] : Lecture info > Array([cmd]=>GetAiAlarm[code]=>0[value]=>Array([AiAlarm]=>Array([ai_type]=>people[channel]=>0[max_target_height]=>0[max_target_width]=>0[min_target_height]=>0[min_target_width]=>0[scope]=>Array([area]=>xx[cols]=>80[rows]=>60)[sensitivity]=>61[stay_time]=>0)))
[2022-10-14 13:45:03][DEBUG] : ai_type check : people
[2022-10-14 13:45:03][DEBUG] : Envoi 10/10 payload multiple GetSetting = {"cmd":"GetAiAlarm","action":0,"param":{"channel":0,"ai_type":"vehicle"}}
[2022-10-14 13:45:03][DEBUG] : Payload => [{"cmd":"GetAiAlarm","action":0,"param":{"channel":0,"ai_type":"vehicle"}}]
[2022-10-14 13:45:03][DEBUG] : Réponse caméra >> [{"cmd":"GetAiAlarm","code":0,"value":{"AiAlarm":{"ai_type":"vehicle","channel":0,"max_target_height":0.0,"max_target_width":0.0,"min_target_height":0.0,"min_target_width":0.0,"scope":{"area":"xxx","cols":80,"rows":60},"sensitivity":60,"stay_time":8}}}]
[2022-10-14 13:45:03][DEBUG] : Lecture info > Array([cmd]=>GetAiAlarm[code]=>0[value]=>Array([AiAlarm]=>Array([ai_type]=>vehicle[channel]=>0[max_target_height]=>0[max_target_width]=>0[min_target_height]=>0[min_target_width]=>0[scope]=>Array([area]=>xxxx[cols]=>80[rows]=>60)[sensitivity]=>60[stay_time]=>8)))
[2022-10-14 13:45:03][DEBUG] : ai_type check : vehicle
et du demon:
2022-10-14 12:50:04][DEBUG] : Client disconnected from [127.0.0.1:60792]
[2022-10-14 12:50:04][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-10-14 12:50:04][DEBUG] : Requested to set the webhook inside CAM IP=192.168.1.48
[2022-10-14 12:50:04][DEBUG] : Using selector: EpollSelector
[2022-10-14 12:50:04][DEBUG] : Request subscription_manager to set webhook on camera = 192.168.1.48:8000
[2022-10-14 12:50:04][DEBUG] : SMAN : Reolink host 192.168.1.48 (Subscription) request
[2022-10-14 12:50:04][DEBUG] : SMAN : Reolink host 192.168.1.48 (Subscription) got response status: 200.
[2022-10-14 12:50:04][DEBUG] : SMAN : Local time: 2022-10-14 11:50, camera time: 2022-10-14 11:50 (difference: 1.4085969924926758), termination time: 2022-10-14 12:05
[2022-10-14 12:50:04][DEBUG] : Starting local hook on : http://192.168.1.45:44010/inbound_events
[2022-10-14 12:50:04][DEBUG] : Subscribe OK
[2022-10-14 12:50:04][DEBUG] : Send to jeedom : {'message': 'subscription', 'ip': '192.168.1.48', 'state': 1}
[2022-10-14 12:50:04][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2022-10-14 12:50:04][DEBUG] : http://127.0.0.1:80 "POST /plugins/reolink/core/php/jeeReolink.php?apikey=censuré HTTP/1.1" 403 199
[2022-10-14 13:00:04][DEBUG] : Client connected to [127.0.0.1:60924]
[2022-10-14 13:00:04][DEBUG] : Client disconnected from [127.0.0.1:60924]
[2022-10-14 13:00:04][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-10-14 13:00:04][DEBUG] : Requested to set the webhook inside CAM IP=192.168.1.48
[2022-10-14 13:00:04][DEBUG] : Using selector: EpollSelector
[2022-10-14 13:00:04][DEBUG] : Request subscription_manager to set webhook on camera = 192.168.1.48:8000
[2022-10-14 13:00:04][DEBUG] : SMAN : Reolink host 192.168.1.48 (Subscription) request
[2022-10-14 13:00:04][DEBUG] : SMAN : Reolink host 192.168.1.48 (Subscription) got response status: 200.
[2022-10-14 13:00:04][DEBUG] : SMAN : Local time: 2022-10-14 12:00, camera time: 2022-10-14 12:00 (difference: 1.11757493019104), termination time: 2022-10-14 12:15
[2022-10-14 13:00:04][DEBUG] : Starting local hook on : http://192.168.1.45:44010/inbound_events
[2022-10-14 13:00:04][DEBUG] : Subscribe OK
[2022-10-14 13:00:04][DEBUG] : Send to jeedom : {'message': 'subscription', 'ip': '192.168.1.48', 'state': 1}
[2022-10-14 13:00:04][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2022-10-14 13:00:04][DEBUG] : http://127.0.0.1:80 "POST /plugins/reolink/core/php/jeeReolink.php?apikey=censuré HTTP/1.1" 403 199
je ne vois d’erreurs nulle part sauf peut etre quand j’ai installé le plugin dans le log reolink_update : cette unique phrase :
anyio 3.6.1 has requirement idna>=2.8, but you'll have idna 2.6 which is incompatible.
