Remplacer dongle ZigBee
jeezigbee c’est sur jeedom.
akenad :slight_smile:
C’est bizarre ça passe NOK puis OK puis NOK sans que je ne fasse rien.
Je viens aussi de changer le câble ethernet mais ça ne semble pas améliorer les choses.
Log z2md ?
[2026-03-20 13:34:01] e[31merrore[39m: 	zh:ember:uart:ash: Received ERROR from adapter, with code=RESET_ASSERT.
[2026-03-20 13:34:01] e[31merrore[39m: 	zh:ember:uart:ash: ASH disconnected | Adapter status: ASH_NCP_FATAL_ERROR
[2026-03-20 13:34:01] e[31merrore[39m: 	zh:ember:ezsp: Fatal error, status=ASH_NCP_FATAL_ERROR. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=76 Len=10]
[2026-03-20 13:34:01] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
> zigbee2mqtt@2.9.1 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2026-03-20 13:35:13] e[31merrore[39m: 	zh:ember:uart:ash: Received ERROR from adapter, with code=RESET_ASSERT.
[2026-03-20 13:35:13] e[31merrore[39m: 	zh:ember:uart:ash: ASH disconnected | Adapter status: ASH_NCP_FATAL_ERROR
[2026-03-20 13:35:13] e[31merrore[39m: 	zh:ember:ezsp: Fatal error, status=ASH_NCP_FATAL_ERROR. Last Frame: [FRAME: ID=38:"GET_EUI64" Seq=33 Len=13]
[2026-03-20 13:35:13] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
> node index.js
[2026-03-20 13:42:12] e[31merrore[39m: 	zh:ember:uart:ash: Received ERROR from adapter, with code=RESET_ASSERT.
[2026-03-20 13:42:12] e[31merrore[39m: 	zh:ember:uart:ash: ASH disconnected | Adapter status: ASH_NCP_FATAL_ERROR
[2026-03-20 13:42:12] e[31merrore[39m: 	zh:ember:ezsp: Fatal error, status=ASH_NCP_FATAL_ERROR. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=61 Len=10]
[2026-03-20 13:42:12] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
> node index.js
[2026-03-20 13:46:22] e[31merrore[39m: 	zh:ember:uart:ash: Port Error: read ETIMEDOUT
[2026-03-20 13:46:22] e[31merrore[39m: 	zh:ember:ezsp: Fatal error, status=ERROR_SERIAL_INIT. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=46 Len=10]
[2026-03-20 13:46:22] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
Débrancher la clé puis rebrancher pour voir.
Comment est-elle alimenté électriquement ?
déjà demandé : par le POE du switch.
Donc débrancher le câble réseau (du SLZB-MR1U) puis rebrancher.
Redémarrer le démon jeezigbee.
Désolé il a fallu que je m’absente quelques minutes.
Ça aussi c’est déjà fait quand j’ai changé le câble ethernet mais pas grave je vais recommencer.
J’ai débranché/rebranché le câble ethernet POE. J’ai aussi remplacé le câble ethernet qui relie le premier switch au switch POE. Rien n’y fait.
Est-ce que ma version de Zigbee2MQTT 2.9.1 pourrait être en cause ?
Il me semble qu’il est possible de le brancher en usb, non?
C’est facile à tester.
D’autres erreurs sont apparues dans le log z2m :
[2026-03-20 15:02:25] e[31merrore[39m: 	zh:ember:uart:ash: Received ERROR from adapter, with code=RESET_ASSERT.
[2026-03-20 15:02:25] e[31merrore[39m: 	zh:ember:uart:ash: ASH disconnected | Adapter status: ASH_NCP_FATAL_ERROR
[2026-03-20 15:02:25] e[31merrore[39m: 	zh:ember:ezsp: Fatal error, status=ASH_NCP_FATAL_ERROR. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=59 Len=10]
[2026-03-20 15:02:25] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
> node index.js
[2026-03-20 15:07:02] e[31merrore[39m: 	zh:ember:uart:ash: Port Error: read ECONNRESET
[2026-03-20 15:07:02] e[31merrore[39m: 	zh:ember:ezsp: Fatal error, status=ERROR_SERIAL_INIT. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=48 Len=10]
[2026-03-20 15:07:02] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
> node index.js
[2026-03-20 15:10:37] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2026-03-20 15:10:37] e[31merrore[39m: 	z2m: Failed to start zigbee-herdsman
[2026-03-20 15:10:37] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-03-20 15:10:37] e[31merrore[39m: 	z2m: Exiting...
[2026-03-20 15:10:37] e[31merrore[39m: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
at EmberAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@9.0.9/node_modules/zigbee-herdsman/src/controller/controller.ts:145:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:70:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:111:29)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:156:5)
Autre curiosité, ma clé SONOFF reste sélectionnable alors qu’elle n’est plus branchée.
Je ne vais pas pouvoir continuer aujourd’hui. En attendant, est-il envisageable que je débranche le SLZB-MR1U pour remettre ma clé SONOFF et que mes modules ZigBee continuent à fonctionner ?
Aujourd’hui la situation est toujours la même. J’ai même essayé de faire fonctionner la bête en USB mais ça ne marche pas non plus. Ma Jeedom est une VM installée sur un NAS Synology. Le SLZB-MR1U est bien inclus au niveau des périphériques USB de la VM en revanche, Jeedom ne l’a jamais détecté en tant que contrôleur.
Bref ! ne trouvant aucune solution, j’ai installé le plugin JeeZigbee sur une autre Jeedom (Pi 3) et ô miracle ça a fonctionné du premier coup (en ethernet). Voilà 1 heure que le daemon est OK sans aucune coupure.
Évidemment, j’ai perdu tous mes modules mais si c’est le prix à payer pour que cela fonctionne sur la première Jeedom pourquoi pas ? Je n’ai qu’une douzaine de module à ré-inclure.
A partir de la première Jeedom, j’envisage donc de supprimer tous les modules, de désinstaller/ré-installer JeeZigbee et enfin de ré-inclure les modules.
Qu’en pensez-vous ?
Pour mettre fin ce fil, sachez que je n’ai pas réussi à conserver mes modules en flashant l’IEEE de la puce EFR32MG21. Peut-être m’y suis-je mal pris ?
Bref ! Je n’allais pas y passer ma vie.
A partir de la clé SONOFF, j’ai donc exclus tous les modules pour les inclure à nouveau avec le SLZB-MR1U.
Le plus long aura été de reconfigurer toutes les commandes pour, autant que possible, les mettre en français.
J’en ai profité pour flasher la clé SONOFF avec un firmware « routeur » comme ça elle n’est pas perdue.
A présent mon réseau ZigBee est stable et fonctionne parfaitement.
Merci à tous de votre aide.
