Remotec ZXT-600 Inclusion mais sans aucune valeur
J’inclus un module Remotec ZXT-600, mais ce dernier ne crée aucune commandes
j’ai testé sous jeedom 3.3.51 et v4.0.60
et pourtant sous arbre zwave
"state" : "ok",
"code" : 0,
"result" : {
"associations" : [
"instances" : {
"1" : {
"updateTime" : 1,
"commandClasses" : {
"94" : {
"data" : {
"0" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Byte",
"genre" : "System",
"read_only" : true,
"expected_data" : null,
"poll_intensity" : 0,
"name" : "ZWave+ Version",
"val" : 0,
"pendingState" : null,
"type" : "int",
"data_items" : "Read only",
"value_id" : 72057596384083970,
"units" : "",
"write_only" : false
"1" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"read_only" : true,
"name" : "InstallerIcon",
"val" : 0,
"type" : "int",
"value_id" : 72057596384083980,
"units" : "",
"2" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"read_only" : true,
"name" : "UserIcon",
"val" : 0,
"type" : "int",
"value_id" : 72057596384084000,
"units" : "",
"updateTime" : 1
"name" : "COMMAND_CLASS_ZWAVE_PLUS_INFO"
"115" : {
"data" : {
"0" : {
"updateTime" : 1594219367,
"help" : "",
"typeZW" : "List",
"genre" : "System",
"read_only" : false,
"name" : "Powerlevel",
"val" : "Normal",
"type" : "List",
"data_items" : "-1dB;-2dB;-3dB;-4dB;-5dB;-6dB;-7dB;-8dB;-9dB;Normal",
"value_id" : 72057596384428030,
"units" : "dB",
"1" : {
"help" : "",
"typeZW" : "Byte",
"genre" : "System",
"name" : "Timeout",
"val" : 0,
"type" : "int",
"data_items" : "A byte between 0 and 255",
"value_id" : 72057596384428050,
"units" : "seconds",
"2" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Button",
"genre" : "System",
"name" : "Set Powerlevel",
"val" : null,
"type" : "bool",
"data_items" : "True or False",
"value_id" : 72057596384428060,
"units" : "",
"write_only" : true
"3" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Byte",
"genre" : "System",
"name" : "Test Node",
"val" : 0,
"type" : "int",
"value_id" : 72057596384428080,
"units" : "",
"4" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "List",
"genre" : "System",
"name" : "Test Powerlevel",
"val" : "Normal",
"type" : "List",
"value_id" : 72057596384428100,
"units" : "dB",
"5" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"name" : "Frame Count",
"val" : 0,
"type" : "int",
"data_items" : "A short between 4294934528 and 32767",
"value_id" : 72057596384428110,
"units" : "",
"6" : {
"updateTime" : 1,
"help" : "",
"genre" : "System",
"name" : "Test",
"val" : null,
"type" : "bool",
"value_id" : 72057596384428130,
"units" : "",
"write_only" : true
"7" : {
"updateTime" : 1,
"help" : "",
"genre" : "System",
"name" : "Report",
"val" : null,
"type" : "bool",
"value_id" : 72057596384428160,
"units" : "",
"write_only" : true
"8" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "List",
"genre" : "System",
"read_only" : true,
"name" : "Test Status",
"val" : "Failed",
"type" : "List",
"units" : "",
"9" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Short",
"genre" : "System",
"read_only" : true,
"name" : "Acked Frames",
"val" : 0,
"type" : "int",
"value_id" : 72057596384428180,
"units" : "",
"updateTime" : 1
"name" : "COMMAND_CLASS_POWERLEVEL"
"128" : {
"data" : {
"0" : {
"updateTime" : 1594219259,
"help" : "",
"typeZW" : "Byte",
"genre" : "User",
"read_only" : true,
"name" : "Battery Level",
"val" : 100,
"type" : "int",
"value_id" : 72057596376252420,
"units" : "%",
"name" : "COMMAND_CLASS_BATTERY"
"134" : {
"data" : {
"0" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "String",
"genre" : "System",
"read_only" : true,
"name" : "Library Version",
"val" : "Unknown",
"type" : "String",
"value_id" : 72057596384739330,
"units" : "",
"1" : {
"updateTime" : 1,
"help" : "",
"genre" : "System",
"read_only" : true,
"name" : "Protocol Version",
"val" : "Unknown",
"type" : "String",
"value_id" : 72057596384739340,
"units" : "",
"2" : {
"updateTime" : 1,
"help" : "",
"genre" : "System",
"read_only" : true,
"name" : "Application Version",
"val" : "Unknown",
"type" : "String",
"value_id" : 72057596384739360,
"units" : "",
"updateTime" : 1
"name" : "COMMAND_CLASS_VERSION"
"152" : {
"data" : {
"0" : {
"updateTime" : 1,
"help" : "",
"typeZW" : "Bool",
"genre" : "System",
"read_only" : true,
"name" : "Secured",
"val" : false,
"type" : "bool",
"value_id" : 72057596385034240,
"units" : "",
"updateTime" : 1
"name" : "COMMAND_CLASS_SECURITY"
"updateTime" : 1,
"data" : {
"updateTime" : 1
"groups" : {
"command_classes" : {
"0" : {
"hex" : "0x00",
"name" : "COMMAND_CLASS_NO_OPERATION"
"32" : {
"hex" : "0x20",
"name" : "COMMAND_CLASS_BASIC"
"34" : {
"hex" : "0x22",
"name" : "COMMAND_CLASS_APPLICATION_STATUS"
"49" : {
"hex" : "0x31",
"name" : "COMMAND_CLASS_SENSOR_MULTILEVEL"
"64" : {
"hex" : "0x40",
"name" : "COMMAND_CLASS_THERMOSTAT_MODE"
"67" : {
"hex" : "0x43",
"name" : "COMMAND_CLASS_THERMOSTAT_SETPOINT"
"68" : {
"hex" : "0x44",
"name" : "COMMAND_CLASS_THERMOSTAT_FAN_MODE"
"90" : {
"hex" : "0x5a",
"name" : "COMMAND_CLASS_DEVICE_RESET_LOCALLY"
"94" : {
"hex" : "0x5e",
"112" : {
"hex" : "0x70",
"name" : "COMMAND_CLASS_CONFIGURATION"
"114" : {
"hex" : "0x72",
"name" : "COMMAND_CLASS_MANUFACTURER_SPECIFIC"
"115" : {
"hex" : "0x73",
"128" : {
"hex" : "0x80",
"133" : {
"hex" : "0x85",
"name" : "COMMAND_CLASS_ASSOCIATION"
"134" : {
"hex" : "0x86",
"152" : {
"hex" : "0x98",
"last_notification" : {
"code" : 1,
"help" : "Messages that timeout will send a Notification with this code",
"description" : "Timeout",
"next_wakeup" : null,
"receiveTime" : 1594219328
"data" : {
"isReady" : {
"value" : true
"isRouting" : {
"value" : true
"isZwavePlus" : {
"value" : false
"basicType" : {
"value" : 4
"isListening" : {
"value" : false
"is_enable" : {
"value" : true
"is_manufacturer_specific_ok" : {
"enabled" : true,
"value" : false
"genericType" : {
"value" : 8
"isAwake" : {
"value" : true
"manufacturerProductId" : {
"hex" : "0x0000",
"value" : 0
"statistics" : {
"delivered" : 100,
"total" : 21,
"deliveryTime" : 28
"isEnable" : {
"value" : true
"specificType" : {
"value" : 6
"neighbours" : {
"value" : [
1,
35,
36,
37,
100,
72,
73,
12,
50,
52,
55,
56,
57,
26
"maxBaudRate" : {
"value" : 40000
"isSecurity" : {
"value" : false
"state" : {
"value" : "Complete"
"version" : {
"value" : 4
"location" : {
"value" : "aucun"
"manufacturerId" : {
"hex" : "0x0000",
"value" : 0
"type" : {
"value" : "General Thermostat V2"
"product_name" : {
"value" : ""
"pending_changes" : {
"count" : 0
"battery_level" : {
"value" : 100
"description" : {
"product_name" : "",
"name" : "Device 139",
"location" : "aucun"
"isVirtual" : {
"value" : ""
"isFrequentListening" : {
"value" : true
"wakeup_interval" : {
"value" : null
"is_neighbours_ok" : {
"neighbors" : 14,
"enabled" : false,
"value" : true
"can_wake_up" : {
"value" : false
"lastReceived" : {
"isBeaming" : {
"value" : true
"name" : {
"value" : "Device 139"
"manufacturerProductType" : {
"hex" : "0x0000",
"value" : 0
"is_groups_ok" : {
"enabled" : false,
"value" : false
"isSecured" : {
"enabled" : true,
"value" : false
"vendorString" : {
"value" : ""
"isInfoReceived" : {
"value" : true
"isFailed" : {
"value" : false
"security" : {
"value" : 0
"multi_instance" : {
"instances" : 1,
"support" : false
Bon testé sous domoticz, et même problème, alors retour chez Amazon.
