Encore moi
Je désespère !
Je tente de configurer ESPHOME mais impossible de le mettre en lien avec mon ESP32,
J’ai installé python puis avec les lignes de commandes installer ESPHOME, ainsi que le dashboard, j’arrive a m’y connecter avec l’adresse locahsot:6052, je créé un new device, je connecte mon esp32, je le retrouve bien dans les COM mais apparait un message d’erreur :
Installation
Unable to compile the configuration
ESPHome will now create your configuration and install it on your device.
Connect your ESP8266 or ESP32 with a USB cable to your computer and click on connect. You need to do this once. Later updates install wirelessly. Learn more
Skip this step to install it on your device later or if you are using a Raspberry Pi Pico.
J’ai également des messages d’erreur qui s’affichent dans le cmd :
2023-02-15 21:04:47,476 ERROR Uncaught exception GET /compile (127.0.0.1)
HTTPServerRequest(protocol='http', host='localhost:6052', method='GET', uri='/compile', version='HTTP/1.1', remote_ip='127.0.0.1')
File "C:\Users\rodol\AppData\Local\Programs\Python\Python311\Lib\site-packages\tornado\websocket.py", line 635, in _run_callback
result = callback(*args, **kwargs)
File "C:\Users\rodol\AppData\Local\Programs\Python\Python311\Lib\site-packages\esphome\dashboard\dashboard.py", line 138, in decorator
return func(self, *args, **kwargs)
File "C:\Users\rodol\AppData\Local\Programs\Python\Python311\Lib\site-packages\esphome\dashboard\dashboard.py", line 212, in on_message
handlers[type_](self, json_message)
File "C:\Users\rodol\AppData\Local\Programs\Python\Python311\Lib\site-packages\esphome\dashboard\dashboard.py", line 221, in handle_spawn
self._proc = tornado.process.Subprocess(
File "C:\Users\rodol\AppData\Local\Programs\Python\Python311\Lib\site-packages\tornado\process.py", line 226, in __init__
self.stdin = PipeIOStream(in_w)
File "C:\Users\rodol\AppData\Local\Programs\Python\Python311\Lib\site-packages\tornado\iostream.py", line 1640, in __init__
raise AssertionError("PipeIOStream is not supported on Windows")
AssertionError: PipeIOStream is not supported on Windows
Existe t’il un moyen plus simple d’obtenir les remontées ESP32 vers jeedom car je suis totalement pommé dans cet environnement et ne comprends même pas ce que je fait !
